не запускается jsp страница
При запуске JSP страницы, тестовой выходит ошибка Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. HTTP Status 500 - Unable to compile class for JSP: type Exception report message Unable to compile class for JSP: description The server encountered an internal error that prevented it from fulfilling this request. exception org.apache.jasper.JasperException: Unable to compile class for JSP: An error occurred at line: [15] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type test_jsp must implement the inherited abstract method JspSourceDependent.getDependants() An error occurred at line: [21] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type Map is not generic; it cannot be parameterized with arguments <String, Long> An error occurred at line: [26] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type Map is not generic; it cannot be parameterized with arguments <String, Long> An error occurred at line: [27] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] _jspx_dependants cannot be resolved to a variable Stacktrace: org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:103) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:199) org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:450) org.apache.jasper.compiler.Compiler.compile(Compiler.java:361) org.apache.jasper.compiler.Compiler.compile(Compiler.java:336) org.apache.jasper.compiler.Compiler.compile(Compiler.java:323) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:564) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340) javax.servlet.http.HttpServlet.service(HttpServlet.java:725) org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) note The full stack trace of the root cause is available in the Apache Tomcat/8.0.14 logs. Apache Tomcat/8.0.14 сервлеты запукаются а вот что то c jsp в чем может быть дело? ... |
| 23.10.2014, 08:07:18 |
У блока try пустое тело. Он не может выкинуть исключения. Возможно это бага Tomcat в том что он так падает на кривых JSP, вместо того чтобы выдать внятную ошибку. ... |
| 23.10.2014, 09:15:24 |
BlazkowiczУ блока try пустое тело. Он не может выкинуть исключения. Возможно это бага Tomcat в том что он так падает на кривых JSP, вместо того чтобы выдать внятную ошибку. написал еще проще код. но все равно выдает ошибки Код: java 1. 2. 3. HTTP Status 500 - Unable to compile class for JSP: type Exception report message Unable to compile class for JSP: description The server encountered an internal error that prevented it from fulfilling this request. exception org.apache.jasper.JasperException: Unable to compile class for JSP: An error occurred at line: [15] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type test_jsp must implement the inherited abstract method JspSourceDependent.getDependants() An error occurred at line: [21] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type Map is not generic; it cannot be parameterized with arguments <String, Long> An error occurred at line: [26] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] The type Map is not generic; it cannot be parameterized with arguments <String, Long> An error occurred at line: [27] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] _jspx_dependants cannot be resolved to a variable Stacktrace: org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:103) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:199) org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:450) org.apache.jasper.compiler.Compiler.compile(Compiler.java:361) org.apache.jasper.compiler.Compiler.compile(Compiler.java:336) org.apache.jasper.compiler.Compiler.compile(Compiler.java:323) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:564) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340) javax.servlet.http.HttpServlet.service(HttpServlet.java:725) org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) note The full stack trace of the root cause is available in the Apache Tomcat/8.0.14 logs. Apache Tomcat/8.0.14 ... |
| 23.10.2014, 09:28:59 |
В библиотеки ничего лишнего не напихали? ... |
| 23.10.2014, 09:38:13 |
ЕлдосAn error occurred at line: [27] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] Можно посмотреть этот generated java file и попытаться понять чего же там Томкат наумничал. ... |
| 23.10.2014, 09:47:53 |
Alexander A. SakМожно посмотреть этот generated java file и попытаться понять чего же там Томкат наумничал. Так там всё написано же: test_jsp must implement, Map is not generic, etc. ... |
| 23.10.2014, 09:49:02 |
BlazkowiczВ библиотеки ничего лишнего не напихали? я даже не знаю, там есть библиотек которые использовались, а потом не используется, как понять лишнего? ... |
| 23.10.2014, 09:51:00 |
Alexander A. SakЕлдосAn error occurred at line: [27] in the generated java file: [C:\Tomcat 8.0\work\Catalina\localhost\ROOT\org\apache\jsp\jsp\about\test_jsp.java] Можно посмотреть этот generated java file и попытаться понять чего же там Томкат наумничал. я не понял что он сгенерировал, может посмотрите Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. ... |
| 23.10.2014, 09:57:11 |
Елдос, Какую JDK использует Tomcat и какая версия у Tomcat? Почитайте тут, ситуация похожа на вашу: http://stackoverflow.com/questions/22552244/tomcat-7-fails-to-compile-jsp-pages ... |
| 23.10.2014, 11:35:45 |
Елдося даже не знаю, там есть библиотек которые использовались, а потом не используется, как понять лишнего? Где именно в Tomcat или в вашем war модуле? Если вы не знаете что там, то зачем вы туда это поместили? ... |
| 23.10.2014, 11:41:21 |
BlazkowiczAlexander A. SakМожно посмотреть этот generated java file и попытаться понять чего же там Томкат наумничал. Так там всё написано же: test_jsp must implement, Map is not generic, etc. Действительно. Map is not generic. Получается, Томкат запустился на джаве до-генериковой версии. В 1.5 вроде их добавили. Елдос, на какой джаве Томкат запущен? Только честно. А то, знаете, версия может быть установлена 1.8, а в System лежит древний файлик, который запускает 1.4. ... |
| 23.10.2014, 12:11:13 |
Ан нет. Подводит меня хрустальный шар. 1.4-то вообще про генерики знать не должна. ... |
| 23.10.2014, 12:14:19 |
В 2009 это тоже обсуждали: http://www.sql.ru/forum/666723/pomogite-razobratsya-chto-proishodit-s-tomcat ... |
| 23.10.2014, 12:17:34 |
SherstЕлдос, Какую JDK использует Tomcat и какая версия у Tomcat? Почитайте тут, ситуация похожа на вашу: http://stackoverflow.com/questions/22552244/tomcat-7-fails-to-compile-jsp-pages Версия томката 8, версия jdk 1.8, ... |
| 23.10.2014, 12:37:32 |
BlazkowiczЕлдося даже не знаю, там есть библиотек которые использовались, а потом не используется, как понять лишнего? Где именно в Tomcat или в вашем war модуле? Если вы не знаете что там, то зачем вы туда это поместили? у меня библиотеки и в томкате и в приложении хранятся, кое что там кое что там. ... |
| 23.10.2014, 12:38:40 |
Елдосу меня библиотеки и в томкате и в приложении хранятся, кое что там кое что там. Список предалагается нам угадать? Или сами будете удалять по одной пока не заработает? ... |
| 23.10.2014, 12:45:04 |
BlazkowiczЕлдосу меня библиотеки и в томкате и в приложении хранятся, кое что там кое что там. Список предалагается нам угадать? Или сами будете удалять по одной пока не заработает? да удалял по одной, мешается одна библиотека называется rt весит она 25 мегабайт. там лежали стандартные классы, нужны ли они мне, удалил их. программа функционирует нормально, и чем же эта библиотека мешалась томкату, спасибо вам всем за помощь ... |
| 23.10.2014, 12:58:56 |
Елдосда удалял по одной, мешается одна библиотека называется rt весит она 25 мегабайт. Вам бы стоило больно ударить того человека кто её туда скопировал. ... |
| 23.10.2014, 13:11:47 |
BlazkowiczУ блока try пустое тело. Он не может выкинуть исключения. Возможно это бага Tomcat в том что он так падает на кривых JSP, вместо того чтобы выдать внятную ошибку. Exception всегда ловить можно!!! ... |
| 23.10.2014, 13:19:39 |
BlazkowiczЕлдосда удалял по одной, мешается одна библиотека называется rt весит она 25 мегабайт. Вам бы стоило больно ударить того человека кто её туда скопировал. почему, она раньше не мешалась, лишь после обновления томката так произошло ... |
| 23.10.2014, 13:22:47 |
ЕлдосBlazkowiczпропущено... Вам бы стоило больно ударить того человека кто её туда скопировал. почему, она раньше не мешалась, лишь после обновления томката так произошло это же просто та же самая библиотека что и в java. или я что не допонимаю ... |
| 23.10.2014, 13:23:40 |
Да, это рантайм джавы. Возникают подозрения, что там же лежит и все остальное из jre/lib. :) ... |
| 23.10.2014, 15:03:20 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126407]: |
283ms |
75ms |
| others: | 363ms |
| total: | 778ms |
