проблема в выводе данных из базы
есть страничка в которой нужно ввести номер авто а в ответ должен с базы вытащить данные у меня выдает такое сообщение может что то пропустил ? в логе SEVERE: Servlet.service() for servlet jsp threw exception org.apache.jasper.JasperException: Unable to compile class for JSP: An error occurred at line: 69 in the jsp file: /electricity/electricity.jsp VEHICLE_ID cannot be resolved 66: Logger.info(Logger.COMMON, "[electricity.jsp] payment session state switched to PROCESSING: " + paymentSession.getSessionId()); 67: statement = connection.createStatement(); 68: 69: resultSet = statement.executeQuery("SELECT vehicle_id, TIME, VIOLATION_LOCATION, VIOLATION, PROCESS_STATUS from [dbo].[GAIAccount] where VEHICLE_ID = "+ VEHICLE_ID +""); 70: 71: if (resultSet.next()) { 72: Logger.info(Logger.COMMON, "[electricity.jsp] account information found, parsing"); в коде String account = paymentRequest.getRequestProperty("VEHICLE_ID"); Logger.info(Logger.COMMON, "[electricity.jsp] check started"); connection = DriverManager.getConnection("jdbc:sqlserver://" + msSqlServer + ";databaseName=" + msSqlDatabase + ";user=" + msSqlUser + ";password=" + msSqlPassword); Logger.info(Logger.COMMON, "[electricity.jsp] input connection created"); paymentSession = PaymentSessionFactory.getInstance().newSession(paymentRequest.getSessionId()); Logger.info(Logger.COMMON, "[electricity.jsp] payment session created: " + paymentSession.getSessionId()); PaymentSessionFactory.setSessionState(paymentSession, PaymentSession.STATE_PROCESSING); Logger.info(Logger.COMMON, "[electricity.jsp] payment session state switched to PROCESSING: " + paymentSession.getSessionId()); statement = connection.createStatement(); resultSet = statement.executeQuery("SELECT vehicle_id, TIME, VIOLATION_LOCATION, VIOLATION, PROCESS_STATUS from [dbo].[GAIAccount] where VEHICLE_ID = "+ VEHICLE_ID +""); if (resultSet.next()) { Logger.info(Logger.COMMON, "[electricity.jsp] account information found, parsing"); paymentRequest.setResponseProperty("VEHICLE_ID", resultSet.getString("VEHICLE_ID")); paymentRequest.setResponseProperty("TIME", resultSet.getString("TIME")); paymentRequest.setResponseProperty("VIOLATION_LOCATION", resultSet.getString("VIOLATION_LOCATION")); paymentRequest.setResponseProperty("VIOLATION", resultSet.getString("VIOLATION")); paymentRequest.setResponseProperty("PROCESS_STATUS", resultSet.getString("PROCESS_STATUS")); } else { Logger.info(Logger.COMMON, "[electricity.jsp] no results in database for this account, exiting"); paymentRequest.setErrorCode(17); PaymentSessionFactory.setSessionState(paymentSession, PaymentSession.STATE_ERROR); Logger.info(Logger.COMMON, "[electricity.jsp] payment session state switched to ERROR: " + paymentSession.getSessionId()); } ... |
| 08.11.2014, 09:48:41 |
проверь VEHICLE_ID пред выполнением запроса ... |
| 08.11.2014, 10:00:12 |
rema174, код чучуть подправил теперь возвращает только не понятно что if (resultSet.next()) { Logger.info(Logger.COMMON, "[electricity.jsp] account information found, parsing"); paymentRequest.setResponseProperty("VEHICLE_ID", resultSet.getString("VEHICLE_ID")); paymentRequest.setResponseProperty("TIME", resultSet.getString("TIME")); paymentRequest.setResponseProperty("VIOLATION_LOCATION", resultSet.getString("VIOLATION_LOCATION")); paymentRequest.setResponseProperty("VIOLATION", resultSet.getString("VIOLATION")); paymentRequest.setResponseProperty("PROCESS_STATUS", resultSet.getString("PROCESS_STATUS")); } else { Logger.info(Logger.COMMON, "[electricity.jsp] no results in database for this account, exiting"); paymentRequest.setErrorCode(17); PaymentSessionFactory.setSessionState(paymentSession, PaymentSession.STATE_ERROR); Logger.info(Logger.COMMON, "[electricity.jsp] payment session state switched to ERROR: " + paymentSession.getSessionId()); } из конструкции отрабатывается else ... |
| 08.11.2014, 11:17:23 |
понятия не имею что ты там подправил убедись что перед запросом в vehicle_id корректное значение, если да, то убедись в правильности этого [dbo].[GAIAccount] ... |
| 08.11.2014, 11:30:48 |
или для начала можно проверить что запрос SELECT vehicle_id, TIME, VIOLATION_LOCATION, VIOLATION, PROCESS_STATUS from [dbo].[GAIAccount] действительно работает ... |
| 08.11.2014, 11:33:40 |
rema174, работает если селектить SELECT vehicle_id, TIME, VIOLATION_LOCATION, VIOLATION, PROCESS_STATUS from [dbo].[GAIAccount] where vehicle_id='5848b01'; а не переменная :( ... |
| 08.11.2014, 11:39:44 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126310]: |
39ms |
37ms |
| others: | 330ms |
| total: | 449ms |
