Обфускация кода java proguard
мне нужно обфусцировать код с помощью proguard. добавил в мавен <plugin> <groupId>com.pyx4me</groupId> <artifactId>proguard-maven-plugin</artifactId> <executions> <execution> <phase>package</phase> <goals><goal>proguard</goal></goals> </execution> </executions> <configuration> <proguardVersion>4.0betta1</proguardVersion> <libs> <lib>${java.home}/lib/rt.jar</lib> </libs> </configuration> </plugin> при сборке mvn package выдает следующее [INFO] Failed to resolve artifact. Missing: ---------- 1) net.sf.proguard:proguard:jar:4.0betta1 Try downloading the file manually from the project website. Then, install it using the command: mvn install:install-file -DgroupId=net.sf.proguard -DartifactId=proguard -Dversion=4.0betta1 -Dpackaging=jar -Dfile=/path/to/file Alternatively, if you host your own repository you can deploy the file there: mvn deploy:deploy-file -DgroupId=net.sf.proguard -DartifactId=proguard -Dversion=4.0betta1 -Dpackaging=jar -Dfile=/path/to/file -Durl= -DrepositoryId=[id] Path to dependency: 1) Product:Product:jar:1.0 2) net.sf.proguard:proguard:jar:4.0betta1 ---------- 1 required artifact is missing. for artifact: Product:Product:jar:1.0 from the specified remote repositories: central ( http://repo1.maven.org/maven2) как сделать чтобы обфусцировать при запуске mvn package ? ... |
| 14.12.2014, 00:01:46 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126087]: |
56ms |
68ms |
| others: | 353ms |
| total: | 558ms |
