A fatal error has been detected by the Java Runtime Environment
При запуске майнкрафта (на всех версиях) мне выдает вот такую ошибку (скопировал log): # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x26678176, pid=7616, tid=1592 # # JRE version: Java(TM) SE Runtime Environment (8.0-b92) (build 1.8.0-ea-b92) # Java VM: Java HotSpot(TM) Client VM (25.0-b34 mixed mode windows-x86 ) # Problematic frame: # C [.DLL+0x48176] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x003dd800): JavaThread "Client thread" [_thread_in_native, id=1592, stack(0x017a0000,0x017f0000)] siginfo: ExceptionCode=0xc0000005, reading address 0x01abf000 Registers: EAX=0x002d6eb0, EBX=0x2763e880, ECX=0x277d0020, EDX=0x00000000 ESP=0x017e4f00, EBP=0x017e9138, ESI=0x7e7f71fa, EDI=0x2763e92c EIP=0x26678176, EFLAGS=0x00010283 Top of Stack: (sp=0x017e4f00) 0x017e4f00: 2763e958 2763e878 2763e880 0002d6eb 0x017e4f10: 00000000 00000000 00000000 00000000 0x017e4f20: 00000000 00000000 00000000 00000000 0x017e4f30: 7e7f71fa 7e7f71fc 00000000 64011611 0x017e4f40: 00000000 00000000 00000000 00000000 0x017e4f50: 00000000 00000000 00000000 00000000 0x017e4f60: 00000000 00000000 00000000 00000000 0x017e4f70: 00000000 00000000 00000000 00000000 Instructions: (pc=0x26678176) 0x26678156: 8b 91 14 07 00 00 89 74 24 30 89 54 24 34 c7 44 0x26678166: 24 0c 00 00 00 00 0f 86 f5 00 00 00 33 c0 8b 0f 0x26678176: 8b 94 04 50 32 00 00 89 14 08 8b 94 04 54 32 00 0x26678186: 00 89 54 08 04 8b 0f 8b 94 04 58 32 00 00 89 54 Register to memory mapping: EAX=0x002d6eb0 is an unknown value EBX=0x2763e880 is an unknown value ECX=0x277d0020 is an unknown value EDX=0x00000000 is an unknown value ESP=0x017e4f00 is pointing into the stack for thread: 0x003dd800 EBP=0x017e9138 is pointing into the stack for thread: 0x003dd800 ESI=0x7e7f71fa is an unknown value EDI=0x2763e92c is an unknown value Stack: [0x017a0000,0x017f0000], sp=0x017e4f00, free space=275k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [.DLL+0x48176] C [.DLL+0xb41bd] Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+0 j org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+15 j org.lwjgl.opengl.WindowsDisplay.createWindow(Lorg/lwjgl/opengl/DrawableLWJGL;Lorg/lwjgl/opengl/DisplayMode;Ljava/awt/Canvas;II)V+196 j org.lwjgl.opengl.Display.createWindow()V+71 j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+72 j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+12 j net.minecraftforge.client.ForgeHooksClient.createDisplay()V+23 j net.minecraft.client.Minecraft.func_71384_a()V+264 j net.minecraft.client.Minecraft.func_99999_d()V+6 j net.minecraft.client.main.Main.main([Ljava/lang/String;)V+826 v ~StubRoutines::call_stub j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0 j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87 j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6 j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+56 j net.minecraft.launchwrapper.Launch.launch([Ljava/lang/String;)V+664 j net.minecraft.launchwrapper.Launch.main([Ljava/lang/String;)V+8 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0x25949400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=8160, stack(0x251d0000,0x25220000)] 0x258b0400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=7376, stack(0x26200000,0x26250000)] 0x25741800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=4560, stack(0x25270000,0x252c0000)] 0x24521000 JavaThread "Service Thread" daemon [_thread_blocked, id=7328, stack(0x248e0000,0x24930000)] 0x016eec00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6904, stack(0x247e0000,0x24830000)] 0x016e9000 JavaThread "Attach Listener" daemon [_thread_blocked, id=1540, stack(0x24870000,0x248c0000)] 0x016e5c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4076, stack(0x243d0000,0x24420000)] 0x016db000 JavaThread "Finalizer" daemon [_thread_blocked, id=7908, stack(0x24720000,0x24770000)] 0x016d6000 JavaThread "Reference Handler" daemon [_thread_blocked, id=1584, stack(0x003e0000,0x00430000)] =>0x003dd800 JavaThread "Client thread" [_thread_in_native, id=1592, stack(0x017a0000,0x017f0000)] Other Threads: 0x016d0800 VMThread [stack: 0x24340000,0x24390000] [id=6620] 0x24533c00 WatcherThread [stack: 0x24790000,0x247e0000] [id=5476] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap: def new generation total 33472K, used 14261K [0x04120000, 0x06570000, 0x0ebc0000) eden space 29760K, 47% used [0x04120000, 0x04f0d408, 0x05e30000) from space 3712K, 0% used [0x05e30000, 0x05e30000, 0x061d0000) to space 3712K, 0% used [0x061d0000, 0x061d0000, 0x06570000) tenured generation total 74292K, used 44574K [0x0ebc0000, 0x1344d000, 0x24120000) the space 74292K, 59% used [0x0ebc0000, 0x11747bd0, 0x11747c00, 0x1344d000) Metaspace total 13289K, used 12895K, reserved 14720K data space 11413K, used 11239K, reserved 12672K class space 1876K, used 1656K, reserved 2048K Card table byte_map: [0x24120000,0x24230000] byte_map_base: 0x240ff700 Polling page: 0x00340000 CodeCache: size=32768Kb used=3052Kb max_used=3052Kb free=29715Kb bounds [0x01f20000, 0x02220000, 0x03f20000] total_blobs=1769 nmethods=1554 adapters=149 compilation: enabled Compilation events (10 events): Event: 11.940 Thread 0x016eec00 1580 com.sun.imageio.plugins.png.PNGImageReader::decodeUpFilter (53 bytes) Event: 11.940 Thread 0x016eec00 nmethod 1580 0x02218748 code [0x02218850, 0x02218960] Event: 11.940 Thread 0x016eec00 1581 sun.awt.image.ByteInterleavedRaster::getDataElements (132 bytes) Event: 11.941 Thread 0x016eec00 nmethod 1581 0x02218ac8 code [0x02218bf0, 0x02218e8c] Event: 11.941 Thread 0x016eec00 1582 java.awt.image.ComponentColorModel::getRGBComponent (111 bytes) Event: 11.942 Thread 0x016eec00 nmethod 1582 0x022190c8 code [0x02219240, 0x022194a8] Event: 11.942 Thread 0x016eec00 1583 java.awt.image.ComponentColorModel::extractComponent (530 bytes) Event: 11.944 Thread 0x016eec00 nmethod 1583 0x02219748 code [0x022199a0, 0x0221a370] Event: 11.944 Thread 0x016eec00 1584 java.nio.HeapByteBuffer::_put (8 bytes) Event: 11.944 Thread 0x016eec00 nmethod 1584 0x0221af48 code [0x0221b040, 0x0221b0e0] GC Heap History (10 events): Event: 10.970 GC heap before {Heap before GC invocations=42 (full 5): def new generation total 20032K, used 18928K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 100% used [0x04120000, 0x05290000, 0x05290000) from space 2176K, 49% used [0x054b0000, 0x055bc228, 0x056d0000) to space 2176K, 0% used [0x05290000, 0x05290000, 0x054b0000) tenured generation total 44324K, used 40658K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 91% used [0x0ebc0000, 0x11374a20, 0x11374c00, 0x11709000) Metaspace total 11669K, used 11320K, reserved 13696K data space 10037K, used 9882K, reserved 11648K class space 1632K, used 1437K, reserved 2048K Event: 10.983 GC heap after Heap after GC invocations=43 (full 5): def new generation total 20032K, used 1897K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 0% used [0x04120000, 0x04120000, 0x05290000) from space 2176K, 87% used [0x05290000, 0x0546a400, 0x054b0000) to space 2176K, 0% used [0x054b0000, 0x054b0000, 0x056d0000) tenured generation total 44324K, used 40658K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 91% used [0x0ebc0000, 0x11374a20, 0x11374c00, 0x11709000) Metaspace total 11669K, used 11320K, reserved 13696K data space 10037K, used 9882K, reserved 11648K class space 1632K, used 1437K, reserved 2048K } Event: 11.116 GC heap before {Heap before GC invocations=43 (full 5): def new generation total 20032K, used 19753K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 100% used [0x04120000, 0x05290000, 0x05290000) from space 2176K, 87% used [0x05290000, 0x0546a400, 0x054b0000) to space 2176K, 0% used [0x054b0000, 0x054b0000, 0x056d0000) tenured generation total 44324K, used 40658K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 91% used [0x0ebc0000, 0x11374a20, 0x11374c00, 0x11709000) Metaspace total 11865K, used 11527K, reserved 13696K data space 10197K, used 10056K, reserved 11648K class space 1668K, used 1471K, reserved 2048K Event: 11.130 GC heap after Heap after GC invocations=44 (full 5): def new generation total 20032K, used 1535K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 0% used [0x04120000, 0x04120000, 0x05290000) from space 2176K, 70% used [0x054b0000, 0x0562fd60, 0x056d0000) to space 2176K, 0% used [0x05290000, 0x05290000, 0x054b0000) tenured generation total 44324K, used 41665K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 94% used [0x0ebc0000, 0x114705d8, 0x11470600, 0x11709000) Metaspace total 11865K, used 11527K, reserved 13696K data space 10197K, used 10056K, reserved 11648K class space 1668K, used 1471K, reserved 2048K } Event: 11.332 GC heap before {Heap before GC invocations=44 (full 5): def new generation total 20032K, used 19391K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 100% used [0x04120000, 0x05290000, 0x05290000) from space 2176K, 70% used [0x054b0000, 0x0562fd60, 0x056d0000) to space 2176K, 0% used [0x05290000, 0x05290000, 0x054b0000) tenured generation total 44324K, used 41665K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 94% used [0x0ebc0000, 0x114705d8, 0x11470600, 0x11709000) Metaspace total 12105K, used 11771K, reserved 13696K data space 10389K, used 10255K, reserved 11648K class space 1716K, used 1516K, reserved 2048K Event: 11.343 GC heap after Heap after GC invocations=45 (full 5): def new generation total 20032K, used 2173K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 0% used [0x04120000, 0x04120000, 0x05290000) from space 2176K, 99% used [0x05290000, 0x054af480, 0x054b0000) to space 2176K, 0% used [0x054b0000, 0x054b0000, 0x056d0000) tenured generation total 44324K, used 42437K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 95% used [0x0ebc0000, 0x11531698, 0x11531800, 0x11709000) Metaspace total 12105K, used 11771K, reserved 13696K data space 10389K, used 10255K, reserved 11648K class space 1716K, used 1516K, reserved 2048K } Event: 11.532 GC heap before {Heap before GC invocations=45 (full 5): def new generation total 20032K, used 20029K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 100% used [0x04120000, 0x05290000, 0x05290000) from space 2176K, 99% used [0x05290000, 0x054af480, 0x054b0000) to space 2176K, 0% used [0x054b0000, 0x054b0000, 0x056d0000) tenured generation total 44324K, used 42437K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 95% used [0x0ebc0000, 0x11531698, 0x11531800, 0x11709000) Metaspace total 12353K, used 11999K, reserved 13696K data space 10581K, used 10437K, reserved 11648K class space 1772K, used 1561K, reserved 2048K Event: 11.546 GC heap after Heap after GC invocations=46 (full 5): def new generation total 20032K, used 1547K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 0% used [0x04120000, 0x04120000, 0x05290000) from space 2176K, 71% used [0x054b0000, 0x05632c60, 0x056d0000) to space 2176K, 0% used [0x05290000, 0x05290000, 0x054b0000) tenured generation total 44324K, used 44203K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 99% used [0x0ebc0000, 0x116eafb8, 0x116eb000, 0x11709000) Metaspace total 12353K, used 11999K, reserved 13696K data space 10581K, used 10437K, reserved 11648K class space 1772K, used 1561K, reserved 2048K } Event: 11.666 GC heap before {Heap before GC invocations=46 (full 5): def new generation total 20032K, used 19403K [0x04120000, 0x056d0000, 0x0ebc0000) eden space 17856K, 100% used [0x04120000, 0x05290000, 0x05290000) from space 2176K, 71% used [0x054b0000, 0x05632c60, 0x056d0000) to space 2176K, 0% used [0x05290000, 0x05290000, 0x054b0000) tenured generation total 44324K, used 44203K [0x0ebc0000, 0x11709000, 0x24120000) the space 44324K, 99% used [0x0ebc0000, 0x116eafb8, 0x116eb000, 0x11709000) Metaspace total 12545K, used 12191K, reserved 13696K data space 10741K, used 10602K, reserved 11648K class space 1804K, used 1589K, reserved 2048K Event: 11.806 GC heap after Heap after GC invocations=47 (full 6): def new generation total 33472K, used 0K [0x04120000, 0x06570000, 0x0ebc0000) eden space 29760K, 0% used [0x04120000, 0x04120000, 0x05e30000) from space 3712K, 0% used [0x05e30000, 0x05e30000, 0x061d0000) to space 3712K, 0% used [0x061d0000, 0x061d0000, 0x06570000) tenured generation total 74292K, used 44574K [0x0ebc0000, 0x1344d000, 0x24120000) the space 74292K, 59% used [0x0ebc0000, 0x11747bd0, 0x11747c00, 0x1344d000) Metaspace total 12545K, used 12191K, reserved 13696K data space 10741K, used 10602K, reserved 11648K class space 1804K, used 1589K, reserved 2048K } Deoptimization events (0 events): No events Internal exceptions (10 events): Event: 11.923 Thread 0x003dd800 Threw 0x04972ff0 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.923 Thread 0x003dd800 Threw 0x04975098 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.923 Thread 0x003dd800 Threw 0x049781b0 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.923 Thread 0x003dd800 Threw 0x0497a2a8 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.924 Thread 0x003dd800 Threw 0x0497cdf8 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jni.cpp:717 Event: 11.974 Thread 0x003dd800 Threw 0x04e5f730 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.975 Thread 0x003dd800 Threw 0x04e632c0 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.977 Thread 0x003dd800 Threw 0x04e66fe8 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.979 Thread 0x003dd800 Threw 0x04e71468 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Event: 11.980 Thread 0x003dd800 Threw 0x04e76390 at C:\re\jdk8\4590\hotspot\src\share\vm\prims\jvm.cpp:1203 Events (10 events): Event: 11.974 loading class 0x2580a508 Event: 11.974 loading class 0x2580a508 done Event: 11.975 loading class 0x2580a538 Event: 11.975 loading class 0x2580a538 done Event: 11.977 loading class 0x24c49cd0 Event: 11.977 loading class 0x24c49cd0 done Event: 11.979 loading class 0x25821fb0 Event: 11.979 loading class 0x25821fb0 done Event: 11.980 loading class 0x2580a658 Event: 11.980 loading class 0x2580a658 done Dynamic libraries: 0x011f0000 - 0x01220000 C:\Program Files\Java\jre8\bin\javaw.exe 0x76e70000 - 0x76fac000 C:\Windows\SYSTEM32\ntdll.dll 0x76cc0000 - 0x76d94000 C:\Windows\system32\kernel32.dll 0x75140000 - 0x7518b000 C:\Windows\system32\KERNELBASE.dll 0x76af0000 - 0x76b90000 C:\Windows\system32\ADVAPI32.dll 0x75c60000 - 0x75d0c000 C:\Windows\system32\msvcrt.dll 0x75340000 - 0x75359000 C:\Windows\SYSTEM32\sechost.dll 0x75d60000 - 0x75e02000 C:\Windows\system32\RPCRT4.dll 0x75730000 - 0x757f9000 C:\Windows\system32\USER32.dll 0x77050000 - 0x7709e000 C:\Windows\system32\GDI32.dll 0x76fc0000 - 0x76fca000 C:\Windows\system32\LPK.dll 0x75280000 - 0x7531d000 C:\Windows\system32\USP10.dll 0x73750000 - 0x738ee000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll 0x75800000 - 0x75857000 C:\Windows\system32\SHLWAPI.dll 0x75320000 - 0x7533f000 C:\Windows\system32\IMM32.DLL 0x76da0000 - 0x76e6c000 C:\Windows\system32\MSCTF.dll 0x69160000 - 0x6921d000 C:\Program Files\Java\jre8\bin\msvcr100.dll 0x65150000 - 0x654a6000 C:\Program Files\Java\jre8\bin\client\jvm.dll 0x71ec0000 - 0x71ec7000 C:\Windows\system32\WSOCK32.dll 0x77010000 - 0x77045000 C:\Windows\system32\WS2_32.dll 0x751e0000 - 0x751e6000 C:\Windows\system32\NSI.dll 0x73030000 - 0x73062000 C:\Windows\system32\WINMM.dll 0x76fb0000 - 0x76fb5000 C:\Windows\system32\PSAPI.DLL 0x73330000 - 0x7333c000 C:\Program Files\Java\jre8\bin\verify.dll 0x6c6f0000 - 0x6c711000 C:\Program Files\Java\jre8\bin\java.dll 0x70af0000 - 0x70b03000 C:\Program Files\Java\jre8\bin\zip.dll 0x75ea0000 - 0x76aea000 C:\Windows\system32\SHELL32.dll 0x75860000 - 0x759bc000 C:\Windows\system32\ole32.dll 0x74e80000 - 0x74e8b000 C:\Windows\system32\profapi.dll 0x72a00000 - 0x72a0a000 C:\Program Files\Java\jre8\bin\management.dll 0x6c6d0000 - 0x6c6e4000 C:\Program Files\Java\jre8\bin\net.dll 0x748e0000 - 0x7491c000 C:\Windows\system32\mswsock.dll 0x748d0000 - 0x748d6000 C:\Windows\System32\wship6.dll 0x73320000 - 0x7332f000 C:\Program Files\Java\jre8\bin\nio.dll 0x73ac0000 - 0x73ad0000 C:\Windows\system32\NLAapi.dll 0x6e1f0000 - 0x6e200000 C:\Windows\system32\napinsp.dll 0x6e1d0000 - 0x6e1e2000 C:\Windows\system32\pnrpnsp.dll 0x6eb00000 - 0x6eb27000 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL 0x747a0000 - 0x747e4000 C:\Windows\system32\DNSAPI.dll 0x6e180000 - 0x6e188000 C:\Windows\System32\winrnr.dll 0x6e8b0000 - 0x6e8d1000 C:\Program Files\Bonjour\mdnsNSP.dll 0x73710000 - 0x7372c000 C:\Windows\system32\Iphlpapi.DLL 0x736f0000 - 0x736f7000 C:\Windows\system32\WINNSI.DLL 0x743c0000 - 0x743c5000 C:\Windows\System32\wshtcpip.dll 0x6e8a0000 - 0x6e8a6000 C:\Windows\system32\rasadhlp.dll 0x735f0000 - 0x73628000 C:\Windows\System32\fwpuclnt.dll 0x697b0000 - 0x697c2000 C:\Program Files\Java\jre8\bin\unpack.dll 0x24420000 - 0x2446c000 C:\Users\Кирилл\AppData\Roaming\.minecraft\versions\1.7.2-Forge10.12.0.997\1.7.2-Forge10.12.0.997-natives-10768700421229\lwjgl.dll 0x69910000 - 0x699d8000 C:\Windows\system32\OPENGL32.dll 0x698e0000 - 0x69902000 C:\Windows\system32\GLU32.dll 0x68650000 - 0x68737000 C:\Windows\system32\DDRAW.dll 0x6c960000 - 0x6c966000 C:\Windows\system32\DCIMAN32.dll 0x75590000 - 0x7572d000 C:\Windows\system32\SETUPAPI.dll 0x75110000 - 0x75137000 C:\Windows\system32\CFGMGR32.dll 0x751f0000 - 0x7527f000 C:\Windows\system32\OLEAUT32.dll 0x75040000 - 0x75052000 C:\Windows\system32\DEVOBJ.dll 0x72f50000 - 0x72f63000 C:\Windows\system32\dwmapi.dll 0x74030000 - 0x74039000 C:\Windows\system32\VERSION.dll 0x74920000 - 0x74936000 C:\Windows\system32\CRYPTSP.dll 0x746c0000 - 0x746fb000 C:\Windows\system32\rsaenh.dll 0x74490000 - 0x744a7000 C:\Windows\system32\USERENV.dll 0x74e00000 - 0x74e0c000 C:\Windows\system32\CRYPTBASE.dll 0x68d10000 - 0x68e54000 C:\Program Files\Java\jre8\bin\awt.dll 0x732c0000 - 0x73300000 C:\Windows\system32\uxtheme.dll 0x242e0000 - 0x24317000 C:\Program Files\ATI Technologies\HydraVision\HydraDMH.dll 0x71e50000 - 0x71e61000 C:\Program Files\Mail.Ru\Guard\GuardMailRu.dll 0x01770000 - 0x01776000 C:\Program Files\ESET\ESET NOD32 Antivirus\eplgHooks.dll 0x68c10000 - 0x68c25000 C:\Windows\system32\atiglpxx.dll 0x26630000 - 0x275e8000 C:\Windows\system32\.DLL 0x68920000 - 0x68945000 C:\Windows\system32\atigktxx.dll 0x72770000 - 0x72849000 C:\Windows\system32\atiadlxx.dll 0x73c30000 - 0x73d25000 C:\Windows\system32\PROPSYS.dll 0x740f0000 - 0x740fd000 C:\Windows\system32\WTSAPI32.dll 0x751a0000 - 0x751ce000 C:\Windows\system32\WINTRUST.dll 0x74f10000 - 0x75030000 C:\Windows\system32\CRYPT32.dll 0x74ef0000 - 0x74efc000 C:\Windows\system32\MSASN1.dll 0x5ba50000 - 0x5bb3b000 C:\Windows\system32\dbghelp.dll VM Arguments: jvm_args: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -Djava.library.path=C:\Users\Кирилл\AppData\Roaming\.minecraft\versions\1.7.2-Forge10.12.0.997\1.7.2-Forge10.12.0.997-natives-10768700421229 java_command: net.minecraft.launchwrapper.Launch --username VladyanxD --version 1.7.2-Forge10.12.0.997 --gameDir C:\Users\Кирилл\AppData\Roaming\.minecraft --assetsDir C:\Users\Кирилл\AppData\Roaming\.minecraft\assets\virtual\legacy --uuid 243ac6934fb1402a86cdf9bff6467996 --accessToken 3fa005ccbcc1455e85fbef184d7af025 --tweakClass cpw.mods.fml.common.launcher.FMLTweaker --width 1280 --height 720 java_class_path (initial): C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\net\minecraftforge\forge\1.7.2-10.12.0.997\forge-1.7.2-10.12.0.997.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\net\minecraft\launchwrapper\1.9\launchwrapper-1.9.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\org\ow2\asm\asm-all\4.1\asm-all-4.1.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-library\2.10.2\scala-library-2.10.2.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-compiler\2.10.2\scala-compiler-2.10.2.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\java3d\vecmath\1.3.1\vecmath-1.3.1.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\net\sf\trove4j\trove4j\3.0.3\trove4j-3.0.3.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\ibm\icu\icu4j-core-mojang\51.2\icu4j-core-mojang-51.2.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\lzma\lzma\0.0.1\lzma-0.0.1.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\io\netty\netty-all\4.0.10.Final\netty-all-4.0.10.Final.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\15.0\guava-15.0.jar;C:\Users\Кирилл\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\Кирилл Launcher Type: SUN_STANDARD Environment Variables: CLASSPATH=.; PATH=C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\Program Files\ATI Stream\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Windows Live\Shared;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files\Autodesk\backburner\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Java\jre8\bin USERNAME=Кирилл OS=Windows_NT PROCESSOR_IDENTIFIER=x86 Family 6 Model 30 Stepping 5, GenuineIntel --------------- S Y S T E M --------------- OS: Windows 7 Build 7601 Service Pack 1 CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 30 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht, tsc, tscinvbit Memory: 4k page, physical 3665400k(1312336k free), swap 7329048k(4212484k free) vm_info: Java HotSpot(TM) Client VM (25.0-b34) for windows-x86 JRE (1.8.0-ea-b92), built on May 30 2013 04:34:41 by "java_re" with MS VC++ 10.0 (VS2010) time: Wed Mar 12 23:50:22 2014 elapsed time: 12 seconds Майнкрафт перезапускал и переустанавливал много раз, переустанавливал все, что только можно: java, драйвера и прочее.. Ничего не помогает! Прошу вас мне помочь!!! ... |
| 12.03.2014, 21:53:27 |
Рецепты читайте тут https://www.google.com/search?q=org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat Ошибка в нативной либе LWJGL для реализации OpenGL в Java. Что-то с драйверами или локальными настройками. В общем первые N ссылок из гугла имеют вполне конкретные рецепты. ... |
| 13.03.2014, 11:22:10 |
Blazkowicz, Испробовал все.. Ничего не работает!!! ... |
| 13.03.2014, 13:47:14 |
SunRise123Испробовал все.. Ничего не работает!!! А зачем вы на Java 8 запускаете? JRE version: Java(TM) SE Runtime Environment (8.0-b92) (build 1.8.0-ea-b92) ... |
| 13.03.2014, 13:50:51 |
Blazkowicz, Я пробовал запускать на java 7, но там мне вообще какую-то левую ошибку выдавало... В прочем, какие бы я версии java не использовал, этого краша не избежать, так сказать ... |
| 13.03.2014, 15:12:01 |
Вот это че за хрень? C:\Windows\system32\.DLL В ней падает ... |
| 13.03.2014, 15:19:35 |
Антивирусы есть? Попробуйте удалить этот DLL. ... |
| 13.03.2014, 15:20:56 |
Blazkowicz, Есть конечно! Удалять что-либо в папке system32 опасаюсь, да и не нашел файл .DLL.. Там есть файлы такие, их много, но у всех есть свое название ... |
| 13.03.2014, 15:28:21 |
Бочина где-то в ATI драйверах. Установили последнюю стабильную версию? У всех нормальных людей в дампе видно нормальное имя DLL либы драйвера. У вас почему-то ".DLL". Хотя он затесался между других dll от ATI, то скорее всего тоже создан этим драйвером. Проблема к Java никакого отношения не имеет вообще. Ошибка в какой-то несовместимости LWJGL и видео драйвера ATI. Гуглите в этом направлении. ... |
| 13.03.2014, 15:34:49 |
Blazkowicz, Я же говорю, устанавливал драйвера до самой последней версии.. Может направите в нужное направление или конкретный ответ найдете, ибо я в этом не шарю, а в гугле лазать ничего не зная толком смысла нет ... |
| 13.03.2014, 15:38:43 |
SunRise123Я же говорю, устанавливал драйвера до самой последней версии.. Самая последняя версия не всегда самая стабильная. SunRise123Может направите в нужное направление или конкретный ответ найдете, ибо я в этом не шарю, а в гугле лазать ничего не зная толком смысла нет Проблема к Java никакого отношения не имеет вообще Справшиваейте на профильных форумах. ... |
| 13.03.2014, 15:41:35 |
Blazkowicz, Устанавливал все версии, какие можно ... |
| 13.03.2014, 15:45:38 |
-Dorg.lwjgl.opengl.Display.allowSoftwareOpenGL=true пробовали? Куда прописывали? ... |
| 13.03.2014, 15:46:14 |
Blazkowicz, Впервые такое вижу.. Никуда не прописывал Оо ... |
| 13.03.2014, 15:49:48 |
SunRise123Испробовал все.. Ничего не работает!!! SunRise123Впервые такое вижу.. Никуда не прописывал Оо ... |
| 13.03.2014, 16:00:42 |
| 13.03.2014, 16:00:59 |
Blazkowicz, Я должен сделать bat файл и через него запускать? ... |
| 13.03.2014, 16:04:22 |
SunRise123Я должен сделать bat файл и через него запускать? Нет. Вы должны позвать кого-нибудь кто "разбирается в компьютерах" и пусть настроит вам Minecraft. ... |
| 13.03.2014, 16:05:58 |
SunRise123, Попробуй этот сайт http://mcskill.ru/mcforum/index.php?/topic/10575-a-fatal-error-has-been-detected-by-the-java-runtime-environment/ Прочитай , вроде должно получиться ... |
| 15.12.2014, 15:56:46 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126078]: |
58ms |
78ms |
| others: | 364ms |
| total: | 572ms |
