IntelliJ Idea 13 and Gwt project problem
Всем, привет, ребята! мигрировал проект на свой ноут Все вроде по скринам настроил, но вот при запуске выскакивает вот такая ошибка: [SRC JAVA]Loading module: myApp Top URL: http://127.0.0.1:8888/MyApp.html?gwt.codesvr=127.0.0.1:9997 User agent: IE Remote host: 127.0.0.1:17761 Tab key: 4352 Session key: YV!MRZJ*KM6=&'F_ DEBUG: Rebinding com.google.gwt.useragent.client.UserAgent ERROR: Deferred binding failed for 'com.google.gwt.useragent.client.UserAgent'; expect subsequent failures DEBUG: Invoking generator com.google.gwt.useragent.rebind.UserAgentGenerator ERROR: Unable to find value for 'user.agent' com.google.gwt.core.ext.BadPropertyValueException: Property 'user.agent' cannot be set to unexpected value 'ie8' at com.google.gwt.dev.shell.ModuleSpacePropertyOracle.computePropertyValue(ModuleSpacePropertyOracle.java:170) at com.google.gwt.dev.shell.ModuleSpacePropertyOracle.getSelectionProperty(ModuleSpacePropertyOracle.java:89) at com.google.gwt.useragent.rebind.UserAgentGenerator.generate(UserAgentGenerator.java:66) at com.google.gwt.core.ext.IncrementalGenerator.generateNonIncrementally(IncrementalGenerator.java:40) at com.google.gwt.dev.javac.StandardGeneratorContext.runGeneratorIncrementally(StandardGeneratorContext.java:676) at com.google.gwt.dev.cfg.RuleGenerateWith.realize(RuleGenerateWith.java:41) at com.google.gwt.dev.shell.StandardRebindOracle$Rebinder.rebind(StandardRebindOracle.java:79) at com.google.gwt.dev.shell.StandardRebindOracle.rebind(StandardRebindOracle.java:276) at com.google.gwt.dev.shell.ShellModuleSpaceHost.rebind(ShellModuleSpaceHost.java:147) at com.google.gwt.dev.shell.ModuleSpace.rebind(ModuleSpace.java:600) at com.google.gwt.dev.shell.ModuleSpace.rebindAndCreate(ModuleSpace.java:470) at com.google.gwt.dev.shell.GWTBridgeImpl.create(GWTBridgeImpl.java:49) at com.google.gwt.core.shared.GWT.create(GWT.java:72) at com.google.gwt.core.client.GWT.create(GWT.java:86) at com.google.gwt.useragent.client.UserAgentAsserter.onModuleLoad(UserAgentAsserter.java:41) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at com.google.gwt.dev.shell.ModuleSpace.onLoad(ModuleSpace.java:411) at com.google.gwt.dev.shell.OophmSessionHandler.loadModule(OophmSessionHandler.java:200) at com.google.gwt.dev.shell.BrowserChannelServer.processConnection(BrowserChannelServer.java:526) at com.google.gwt.dev.shell.BrowserChannelServer.run(BrowserChannelServer.java:364) at java.lang.Thread.run(Thread.java:722) ERROR: Unable to load module entry point class com.google.gwt.useragent.client.UserAgentAsserter (see associated exception for details) java.lang.RuntimeException: Deferred binding failed for 'com.google.gwt.useragent.client.UserAgent' (did you forget to inherit a required module?) at com.google.gwt.dev.shell.GWTBridgeImpl.create(GWTBridgeImpl.java:53) at com.google.gwt.core.shared.GWT.create(GWT.java:72) at com.google.gwt.core.client.GWT.create(GWT.java:86) at com.google.gwt.useragent.client.UserAgentAsserter.onModuleLoad(UserAgentAsserter.java:41) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at com.google.gwt.dev.shell.ModuleSpace.onLoad(ModuleSpace.java:411) at com.google.gwt.dev.shell.OophmSessionHandler.loadModule(OophmSessionHandler.java:200) at com.google.gwt.dev.shell.BrowserChannelServer.processConnection(BrowserChannelServer.java:526) at com.google.gwt.dev.shell.BrowserChannelServer.run(BrowserChannelServer.java:364) at java.lang.Thread.run(Thread.java:722) Caused by: com.google.gwt.core.ext.UnableToCompleteException: (see previous log entries) at com.google.gwt.dev.shell.ModuleSpace.rebind(ModuleSpace.java:610) at com.google.gwt.dev.shell.ModuleSpace.rebindAndCreate(ModuleSpace.java:470) at com.google.gwt.dev.shell.GWTBridgeImpl.create(GWTBridgeImpl.java:49) at com.google.gwt.core.shared.GWT.create(GWT.java:72) at com.google.gwt.core.client.GWT.create(GWT.java:86) at com.google.gwt.useragent.client.UserAgentAsserter.onModuleLoad(UserAgentAsserter.java:41) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at com.google.gwt.dev.shell.ModuleSpace.onLoad(ModuleSpace.java:411) at com.google.gwt.dev.shell.OophmSessionHandler.loadModule(OophmSessionHandler.java:200) at com.google.gwt.dev.shell.BrowserChannelServer.processConnection(BrowserChannelServer.java:526) at com.google.gwt.dev.shell.BrowserChannelServer.run(BrowserChannelServer.java:364) at java.lang.Thread.run(Thread.java:722) ERROR: Failed to load module 'myApp' from user agent 'Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E)' at 127.0.0.1:17761 ... |
| 31.12.2014, 14:53:00 |
Ребят, очень надо, подскажите, пожалуйста! на сайтах и форумах смотрел, почистил кеш, не помогло ... |
| 31.12.2014, 14:54:03 |
start [/forum/topic.php?desktop=1&fid=59&tid=2125990]: |
26ms |
55ms |
55ms |
| others: | 329ms |
| total: | 508ms |
