jboss 8 spring. Выдает ошибку Cannot resolve the name 'repository:repository'
Всем привет Подскажите как можно побороть данную проблему. Под win7 x64 в jboss 8 приложение стартует и работает. Попытка запустить приложение под linux x64 c тем же jboss 8 заканчивается ошибкой: лог деплоя "{\"JBAS014671: Failed services\" => {\"jboss.undertow.deployment.default-server.default-host./app\" => \"org.jboss.msc.service.StartException in service jboss.undertow.deployment.default-server.default-host./app: Failed to start service Caused by: java.lang.RuntimeException: org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 18 in XML document from ServletContext resource [/WEB-INF/applicationContext.xml] is invalid; nested exception is org.xml.sax.SAXParseException; systemId: http://www.springframework.org/schema/data/jpa/spring-jpa.xsd; lineNumber: 18; columnNumber: 48; src-resolve: Cannot resolve the name 'repository:repository' to a(n) 'type definition' component. Caused by: org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 18 in XML document from ServletContext resource [/WEB-INF/applicationContext.xml] is invalid; nested exception is org.xml.sax.SAXParseException; systemId: http://www.springframework.org/schema/data/jpa/spring-jpa.xsd; lineNumber: 18; columnNumber: 48; src-resolve: Cannot resolve the name 'repository:repository' to a(n) 'type definition' component. Caused by: org.xml.sax.SAXParseException; systemId: http://www.springframework.org/schema/data/jpa/spring-jpa.xsd; lineNumber: 18; columnNumber: 48; src-resolve: Cannot resolve the name 'repository:repository' to a(n) 'type definition' component.\"}}" лог ошибки 2015-02-05 16:43:45,238 ERROR [org.springframework.web.context.ContextLoader] (MSC service thread 1-3) Context initialization failed: org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 18 in XML document from ServletContext resource [/WEB-INF/applicationContext.xml] is invalid; nested exception is org.xml.sax.SAXParseException; systemId: http://www.springframework.org/schema/data/jpa/spring-jpa.xsd; lineNumber: 18; columnNumber: 48; src-resolve: Cannot resolve the name 'repository:repository' to a(n) 'type definition' component. at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:396) [spring-beans-3.2.2.RELEASE.jar:3.2.2.RELEASE] at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334) [spring-beans-3.2.2.RELEASE.jar:3.2.2.RELEASE] ... Caused by: org.xml.sax.SAXParseException; systemId: http://www.springframework.org/schema/data/jpa/spring-jpa.xsd; lineNumber: 18; columnNumber: 48; src-resolve: Cannot resolve the name 'repository:repository' to a(n) 'type definition' component. at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source) at org.apache.xerces.util.ErrorHandlerWrapper.error(Unknown Source) at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source) at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source) at org.apache.xerces.impl.xs.traversers.XSDHandler.reportSchemaError(Unknown Source) at org.apache.xerces.impl.xs.traversers.XSDHandler.getGlobalDecl(Unknown Source) ... |
| 06.02.2015, 12:17:53 |
Выложите содержимое файла applicationContext.xml , из лога же видно что он на него ругается ... |
| 06.02.2015, 20:16:54 |
start [/forum/topic.php?desktop=1&fid=59&tid=2125840]: |
48ms |
58ms |
| others: | 330ms |
| total: | 511ms |
