деплой на WildFly
Всем привет! ребята подскажите пожалуйста что делать?! хочу деплоить приложения на Апп Сервер WildFly, но сервер возвращает ошибку: 2015-05-27 11:34:50,517 INFO [org.jboss.as.server.deployment] (MSC service thread 1-3) JBAS015876: Starting deployment of "app1.ear" (runtime-name: "app1.ear") 2015-05-27 11:34:51,305 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015973: Starting subdeployment (runtime-name: "view.war") 2015-05-27 11:34:51,305 INFO [org.jboss.as.server.deployment] (MSC service thread 1-8) JBAS015973: Starting subdeployment (runtime-name: "daejb.jar") 2015-05-27 11:34:53,179 INFO [org.jboss.as.jpa] (MSC service thread 1-10) JBAS011401: Read persistence.xml for Model 2015-05-27 11:34:53,315 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-15) MSC000001: Failed to start service jboss.deployment.subunit."app1.ear"."daejb.jar".FIRST_MODULE_USE: org.jboss.msc.service.StartException in service jboss.deployment.subunit."app1.ear"."daejb.jar".FIRST_MODULE_USE: JBAS018733: Failed to process phase FIRST_MODULE_USE of subdeployment "daejb.jar" of deployment "app1.ear" at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:166) [wildfly-server-8.2.0.Final.jar:8.2.0.Final] at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1948) [jboss-msc-1.2.2.Final.jar:1.2.2.Final] at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1881) [jboss-msc-1.2.2.Final.jar:1.2.2.Final] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [rt.jar:1.8.0] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [rt.jar:1.8.0] at java.lang.Thread.run(Thread.java:744) [rt.jar:1.8.0] Caused by: javax.persistence.PersistenceException: JBAS011466: PersistenceProvider ' org.eclipse.persistence.jpa.PersistenceProvider ' not found at org.jboss.as.jpa.processor.PersistenceUnitServiceHandler.lookupProvider(PersistenceUnitServiceHandler.java:990) at org.jboss.as.jpa.processor.PersistenceUnitServiceHandler.addPuService(PersistenceUnitServiceHandler.java:258) at org.jboss.as.jpa.processor.PersistenceUnitServiceHandler.handleJarDeployment(PersistenceUnitServiceHandler.java:153) at org.jboss.as.jpa.processor.PersistenceUnitServiceHandler.deploy(PersistenceUnitServiceHandler.java:128) at org.jboss.as.jpa.processor.PersistenceBeginInstallProcessor.deploy(PersistenceBeginInstallProcessor.java:52) at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:159) [wildfly-server-8.2.0.Final.jar:8.2.0.Final] ... 5 more 2015-05-27 11:34:53,389 ERROR [org.jboss.as.controller.management-operation] (DeploymentScanner-threads - 2) JBAS014613: Operation ("deploy") failed - address: ([("deployment" => "app1.ear")]) - failure description: {"JBAS014671: Failed services" => {"jboss.deployment.subunit.\"app1.ear\".\"daejb.jar\".FIRST_MODULE_USE" => "org.jboss.msc.service.StartException in service jboss.deployment.subunit.\"app1.ear\".\"daejb.jar\".FIRST_MODULE_USE: JBAS018733: Failed to process phase FIRST_MODULE_USE of subdeployment \"daejb.jar\" of deployment \"app1.ear\" Caused by: javax.persistence.PersistenceException: JBAS011466: PersistenceProvider ' org.eclipse.persistence.jpa.PersistenceProvider ' not found"}} 2015-05-27 11:34:54,258 INFO [org.jboss.as.server] (DeploymentScanner-threads - 2) JBAS018559: Deployed "app1.ear" (runtime-name : "app1.ear") 2015-05-27 11:34:54,266 INFO [org.jboss.as.controller] (DeploymentScanner-threads - 2) JBAS014774: Service status report JBAS014777: Services which failed to start: service jboss.deployment.subunit."app1.ear"."daejb.jar".FIRST_MODULE_USE: org.jboss.msc.service.StartException in service jboss.deployment.subunit."app1.ear"."daejb.jar".FIRST_MODULE_USE: JBAS018733: Failed to process phase FIRST_MODULE_USE of subdeployment "daejb.jar" of deployment "app1.ear" все это дело деплоиться на Weblogic на ура, а тут что-то ему не хватает... Заранее спасибо! ... |
| 27.05.2015, 12:47:18 |
деплой на WildFly
JBoss, насколько я знаю, использует в качестве JPA провайдера Hibernate. Вам нужно или поменять JPA-провайдер в persistence.xml, либо добавить EclipseLink в библиотеки вашего приложения. ... |
| 27.05.2015, 13:14:35 |
деплой на WildFly
Pavel SamolysovJBoss, насколько я знаю, использует в качестве JPA провайдера Hibernate. Вам нужно или поменять JPA-провайдер в persistence.xml, либо добавить EclipseLink в библиотеки вашего приложения. Хорошо попробую... ... |
| 27.05.2015, 13:20:58 |
деплой на WildFly
Pavel Samolysovдобавить EclipseLink в библиотеки вашего приложения. сделал как показана вот тут но все как прежде... ... |
| 27.05.2015, 14:07:46 |
деплой на WildFly
попробуйте лучше https://community.jboss.org/wiki/HowToUseEclipseLinkWithAS7?_sscc=t как никак это те же люди то и делают wildfly ... |
| 27.05.2015, 14:22:58 |
деплой на WildFly
Вообще в идеале всегда лучше всего сначала проверять официальную документацию. т.к. блоги зачастую это тупо перепост официальной документации к тому же часто сокращенный, за исключением если это блог самого разработчика да и то не факт. Вот еще официальные документация по этому поводу. https://docs.jboss.org/author/display/WFLY8/JPA Reference Guide#JPAReferenceGuide-UsingEclipseLink ... |
| 27.05.2015, 14:29:12 |
деплой на WildFly
llemingпопробуйте лучше https://community.jboss.org/wiki/HowToUseEclipseLinkWithAS7?_sscc=t как никак это те же люди то и делают wildflyЧто-то не видно этого товарища среди разработчиков EclipseLink .... ... |
| 27.05.2015, 14:54:54 |
деплой на WildFly
WGAllemingпопробуйте лучше https://community.jboss.org/wiki/HowToUseEclipseLinkWithAS7?_sscc=t как никак это те же люди то и делают wildflyЧто-то не видно этого товарища среди разработчиков EclipseLink .... Имеется ввиду те кто поддержку eclipelink в wildfly впихивал. ... |
| 27.05.2015, 16:36:48 |
деплой на WildFly
llemingВот еще официальные документация по этому поводу. https://docs.jboss.org/author/display/WFLY8/JPA Reference Guide#JPAReferenceGuide-UsingEclipseLink не получается... ... |
| 28.05.2015, 07:13:58 |
start [/forum/topic.php?desktop=1&fid=59&tid=2125361]: |
63ms |
69ms |
| others: | 375ms |
| total: | 591ms |
