Работа над ошибкой
Добрый день всем. Ребята подскажите не могу справиться с ошибкой. вот мой класс Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. при вызове метода ParsingAdressCountry(String firm) выскакивает ошибка { Exception in thread "JavaFX Application Thread" java.lang.NullPointerException at price1.Parsing_Adress_Firm.ParsingAdressCountry(Parsing_Adress_Firm.java:53) at price1.FXMLDocumentController$3.handle(FXMLDocumentController.java:178) at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54) at javafx.event.Event.fireEvent(Event.java:198) at javafx.scene.Scene$MouseHandler.process(Scene.java:3758) at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3486) at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762) at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2495) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:350) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275) at java.security.AccessController.doPrivileged(Native Method) at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$350(GlassViewEventHandler.java:385) at com.sun.javafx.tk.quantum.GlassViewEventHandler$$Lambda$203/202522089.get(Unknown Source) at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:404) at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:384) at com.sun.glass.ui.View.handleMouseEvent(View.java:555) at com.sun.glass.ui.View.notifyMouse(View.java:927) at com.sun.glass.ui.win.WinApplication._runLoop(Native Method) at com.sun.glass.ui.win.WinApplication.lambda$null$145(WinApplication.java:101) at com.sun.glass.ui.win.WinApplication$$Lambda$36/1963387170.run(Unknown Source) at java.lang.Thread.run(Thread.java:745) } подскажите в чем проблема. ... |
| 24.07.2015, 17:30:00 |
Работа над ошибкой
Ошибка и код не совпадают. В 53й строке ничего нет. ... |
| 24.07.2015, 17:39:29 |
Работа над ошибкой
getRow и getCell могут вернуть null. Читайте документацию. Старайтесь не использовать цепочку вызовов вроде sheet.getRow(i).getCell(index).toString() Заведите переменные для Row и Cell. Такие цепочки имеет смысл использовать только в случае Builder паттерна. ... |
| 24.07.2015, 17:42:49 |
Работа над ошибкой
BlazkowiczОшибка и код не совпадают. В 53й строке ничего нет. в 53 строке добавление в arraylist Код: java 1. походу я неправильно наполняю arraylist Подскажите пожалуйста как правильно добавить елементы в arraylist. ... |
| 24.07.2015, 17:46:06 |
Работа над ошибкой
mixon21, Код: java 1. 2. 3. 4. 5. 6. 7. ... |
| 24.07.2015, 17:48:28 |
start [/forum/topic.php?desktop=1&fid=59&tid=2125141]: |
41ms |
54ms |
| others: | 369ms |
| total: | 534ms |
