Firebird в netBeans ошибки при выводе информации из таблицы
Здравствуйте подскажите что делать? Выскакивают такие ошибки при открытии формы содержащую таблицу из бд. компиляторrun: [EL Info]: 2015-09-16 09:47:28.55--ServerSession(1599737207)--EclipseLink, version: Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd [EL Severe]: ejb: 2015-09-16 09:47:28.691--ServerSession(1599737207)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException Internal Exception: org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544344. I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" Error while trying to open file null Error Code: 335544344 Exception in thread "AWT-EventQueue-0" javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException Internal Exception: org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544344. I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" Error while trying to open file null Error Code: 335544344 at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:766) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:304) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:336) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:302) at cubd.kursovii.test.initComponents(test.java:31) at cubd.kursovii.test.<init>(test.java:18) at cubd.kursovii.mainform.jMenuItem10ActionPerformed(mainform.java:222) at cubd.kursovii.mainform.access$900(mainform.java:14) at cubd.kursovii.mainform$10.actionPerformed(mainform.java:138) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2346) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6525) at javax.swing.JComponent.processMouseEvent(JComponent.java:3322) at java.awt.Component.processEvent(Component.java:6290) at java.awt.Container.processEvent(Container.java:2234) at java.awt.Component.dispatchEventImpl(Component.java:4881) at java.awt.Container.dispatchEventImpl(Container.java:2292) at java.awt.Component.dispatchEvent(Component.java:4703) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4898) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4533) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4462) at java.awt.Container.dispatchEventImpl(Container.java:2278) at java.awt.Window.dispatchEventImpl(Window.java:2739) at java.awt.Component.dispatchEvent(Component.java:4703) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:751) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:702) at java.awt.EventQueue$3.run(EventQueue.java:696) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:724) at java.awt.EventQueue$4.run(EventQueue.java:722) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75) at java.awt.EventQueue.dispatchEvent(EventQueue.java:721) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException Internal Exception: org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544344. I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" Error while trying to open file null Error Code: 335544344 at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:331) at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:326) at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.setOrDetectDatasource(DatabaseSessionImpl.java:204) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:741) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:239) at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:685) ... 47 more Caused by: org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544344. I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" Error while trying to open file null at org.firebirdsql.jdbc.FBDataSource.getConnection(FBDataSource.java:120) at org.firebirdsql.jdbc.AbstractDriver.connect(AbstractDriver.java:138) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ... 52 more Caused by: org.firebirdsql.gds.GDSException: I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" Error while trying to open file null at org.firebirdsql.gds.impl.wire.AbstractJavaGDSImpl.readStatusVector(AbstractJavaGDSImpl.java:2092) at org.firebirdsql.gds.impl.wire.AbstractJavaGDSImpl.receiveResponse(AbstractJavaGDSImpl.java:2042) at org.firebirdsql.gds.impl.wire.AbstractJavaGDSImpl.internalAttachDatabase(AbstractJavaGDSImpl.java:457) at org.firebirdsql.gds.impl.wire.AbstractJavaGDSImpl.iscAttachDatabase(AbstractJavaGDSImpl.java:411) at org.firebirdsql.jca.FBManagedConnection.<init>(FBManagedConnection.java:105) at org.firebirdsql.jca.FBManagedConnectionFactory.createManagedConnection(FBManagedConnectionFactory.java:499) at org.firebirdsql.jca.FBStandAloneConnectionManager.allocateConnection(FBStandAloneConnectionManager.java:69) at org.firebirdsql.jdbc.FBDataSource.getConnection(FBDataSource.java:118) ... 56 more СБОРКА УСПЕШНО ЗАВЕРШЕНА (общее время: 5 секунды) ... |
| 16.09.2015, 09:54:31 |
Firebird не может открыть файл PUSH.FDB. Например ему может не хватить прав, так как файл находиться внутри профиля пользователя, а FB сервер запущен под другим аккаунтом. Вопрос к Java отношения не имеет. Учитесь читать Exception-ы. Ключевая ошибка Caused by: org.firebirdsql.gds.GDSException: I/O error during "CreateFile (open)" operation for file "C:/Users/рр/Desktop/СУБД/кр/bd/PUSH.FDB" ... |
| 16.09.2015, 10:02:09 |
start [/forum/topic.php?desktop=1&fid=59&tid=2124904]: |
50ms |
75ms |
| others: | 368ms |
| total: | 575ms |
