JPA+JBoss7=BAS011440: Can't find a persistence unit
Имеется ear проект с тремя модулями: appname-ear, appname-ejb and appname-web. При попытке получить EntityManager Код: java 1. 2. получаю ошибку авторJBAS011440: Can't find a persistence unit named manager1 in subdeployment "factory-ejb-1.0-SNAPSHOT.jar" of deployment "factory.ear" persistence.xml автор<?xml version="1.0" encoding="UTF-8"?> <persistence version="2.0" xmlns=" http://java.sun.com/xml/ns/persistence" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd"> <persistence-unit name="manager1" transaction-type="JTA"> <provider>org.hibernate.ejb.HibernatePersistence</provider> <jta-data-source>java:jboss/datasources/PostgresDS</jta-data-source> <class>...</class> <class>...</class> <properties> <property name="hibernate.dialect" value="org.hibernate.dialect.PostgreSQLDialect" /> <property name="hibernate.show_sql" value="true" /> <property name="hibernate.hbm2ddl.auto" value="update"/> </properties> </persistence-unit> </persistence> persistence.xml находится appname/appname_ear/META-INF. ... |
| 06.10.2016, 14:59:26 |
start [/forum/topic.php?desktop=1&fid=59&tid=2123640]: |
23ms |
54ms |
62ms |
| others: | 372ms |
| total: | 567ms |
