JDBC в Jboss Developer Studio
Всем привет. Уже пару дней не могу настроить банальной подключение к базе данных MS SQL в Jboss Developer Studio. Работаю в перспективе Fuse Integration. Итак, что есть: xml файл, который должен быть разобран и отправлен в базу, и, собственно, сама база. Код blueprint<blueprint xmlns=" http://www.osgi.org/xmlns/blueprint/v1.0.0" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://www.osgi.org/xmlns/blueprint/v1.0.0 https://www.osgi.org/xmlns/blueprint/v1.0.0/blueprint.xsd http://camel.apache.org/schema/blueprint http://camel.apache.org/schema/blueprint/camel-blueprint.xsd"> <!-- The namespace for the camelContext element in Blueprint is 'https://camel.apache.org/schema/blueprint'. Additionally, we can also define namespace prefixes we want to use them in the XPath expressions in our CBR. While it is not required to assign id's to the <camelContext/> and <route/> elements, it is a good idea to set those for runtime management purposes (logging, JMX MBeans, ...) --> <bean class="org.apache.commons.dbcp.BasicDataSource" id="dataSource"> <property name="url" value="jdbc:sqlserver://10.0.1.****:1433;databaseName=Test;"/> <property name="username" value="******"/> <property name="password" value="******"/> </bean> <camelContext id="_context1" xmlns=" http://camel.apache.org/schema/blueprint"> <route id="_route1"> <from id="_from_xml" uri="file:src/xml?noop=true"/> <log id="_log4" message="File read"/> <setHeader headerName="code" id="_setHeader1"> <xpath>goods/good/code/text()</xpath> </setHeader> <setHeader headerName="name" id="_setHeader2"> <xpath>goods/good/name/text()</xpath> </setHeader> <setHeader headerName="Act" id="_setHeader3"> <constant>0</constant> </setHeader> <setBody id="_setBody1"> <sql>INSERT INTO SA_GOOD Values(${header.code}, ${header.name}, ${header.act})</sql> </setBody> <to id="_to1" uri="jdbc:dataSource"/> <log id="_log1" message="Done!"/> </route> </camelContext> </blueprint> Лог ошибки[INFO] Starting Camel ... [mel.test.blueprint.Main.main()] Activator INFO Camel activator starting [mel.test.blueprint.Main.main()] Activator INFO Camel activator started [ Blueprint Extender: 1] BlueprintContainerImpl INFO Bundle xml-to-database/1.0.0.SNAPSHOT is waiting for namespace handlers [ http://camel.apache.org/schema/blueprint%5D]http://camel.apache.org/schema/blueprint] [ Blueprint Extender: 3] BlueprintCamelContext INFO Apache Camel 2.17.0.redhat-630254 (CamelContext: _context1) is starting [ Blueprint Extender: 3] ManagedManagementStrategy INFO JMX is enabled [ Blueprint Extender: 3] DefaultManagementAgent INFO ManagementAgent detected JVM system properties: {org.apache.camel.jmx.createRmiConnector=true} [mi://pc00021:1099/jmxrmi/camel] DefaultManagementAgent INFO JMX Connector thread started and listening at: service:jmx:rmi:///jndi/rmi://pc00021:1099/jmxrmi/camel [ Blueprint Extender: 3] DefaultRuntimeEndpointRegistry INFO Runtime endpoint registry is in extended mode gathering usage statistics of all incoming and outgoing endpoints (cache limit: 1000) [ Blueprint Extender: 3] BlueprintCamelContext INFO Apache Camel 2.17.0.redhat-630254 (CamelContext: _context1) is shutting down [ Blueprint Extender: 3] BlueprintCamelContext INFO Apache Camel 2.17.0.redhat-630254 (CamelContext: _context1) uptime 0.532 seconds [ Blueprint Extender: 3] BlueprintCamelContext INFO Apache Camel 2.17.0.redhat-630254 (CamelContext: _context1) is shutdown in 0.000 seconds [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN Test bundle headers: Bundle-ManifestVersion=2, Bundle-Name=System Bundle, Bundle-SymbolicName=org.apache.felix.connect, Bundle-Vendor=Apache Software Foundation, Bundle-Version=0.0.0 [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.cm [30], symbolicName: org.apache.aries.blueprint.cm [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.framework.hooks.bundle.EventHook], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.cm [30], symbolicName: org.apache.aries.blueprint.cm [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.startlevel.StartLevel], bundle: org.apache.felix.connect [0], symbolicName: org.apache.felix.connect [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.ComponentResolver], bundle: org.apache.camel.camel-jdbc [17], symbolicName: org.apache.camel.camel-jdbc [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.blueprint.container.BlueprintListener], bundle: xml-to-database [2], symbolicName: xml-to-database [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.LanguageResolver], bundle: org.apache.camel.camel-josql [14], symbolicName: org.apache.camel.camel-josql [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.ComponentResolver], bundle: org.apache.camel.camel-core [3], symbolicName: org.apache.camel.camel-core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.proxy.ProxyManager], bundle: org.apache.aries.proxy.impl [25], symbolicName: org.apache.aries.proxy.impl [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.DataFormatResolver], bundle: org.apache.camel.camel-core [3], symbolicName: org.apache.camel.camel-core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.services.ParserService], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.url.URLStreamHandlerService], bundle: org.apache.felix.fileinstall [39], symbolicName: org.apache.felix.fileinstall [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.cm.ConfigurationAdmin], bundle: org.apache.felix.configadmin [27], symbolicName: org.apache.felix.configadmin [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.cm.ConfigurationListener, org.apache.felix.fileinstall.ArtifactListener, org.apache.felix.fileinstall.ArtifactInstaller], bundle: org.apache.felix.fileinstall [39], symbolicName: org.apache.felix.fileinstall [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.quiesce.participant.QuiesceParticipant], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.LanguageResolver], bundle: org.apache.camel.camel-core [3], symbolicName: org.apache.camel.camel-core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.blueprint.container.BlueprintContainer], bundle: org.apache.camel.camel-blueprint [8], symbolicName: org.apache.camel.camel-blueprint [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.cm [30], symbolicName: org.apache.aries.blueprint.cm [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.blueprint.container.BlueprintContainer], bundle: xml-to-database [2], symbolicName: xml-to-database [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.camel.spi.TypeConverterLoader], bundle: org.apache.camel.camel-core [3], symbolicName: org.apache.camel.camel-core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.felix.cm.PersistenceManager], bundle: org.apache.felix.configadmin [27], symbolicName: org.apache.felix.configadmin [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.services.BlueprintExtenderService], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.cm [30], symbolicName: org.apache.aries.blueprint.cm [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.cm.ManagedServiceFactory], bundle: org.apache.felix.fileinstall [39], symbolicName: org.apache.felix.fileinstall [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.blueprint.container.BlueprintContainer], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.blueprint.container.BlueprintContainer], bundle: org.apache.aries.blueprint.cm [30], symbolicName: org.apache.aries.blueprint.cm [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.osgi.service.packageadmin.PackageAdmin], bundle: org.apache.felix.connect [0], symbolicName: org.apache.felix.connect [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.camel.camel-blueprint [8], symbolicName: org.apache.camel.camel-blueprint [mel.test.blueprint.Main.main()] CamelBlueprintHelper WARN ServiceReference: [org.apache.aries.blueprint.NamespaceHandler], bundle: org.apache.aries.blueprint.core [28], symbolicName: org.apache.aries.blueprint.core [mel.test.blueprint.Main.main()] BlueprintExtender INFO Destroying BlueprintContainer for bundle org.apache.aries.blueprint.cm/1.0.6 [mel.test.blueprint.Main.main()] BlueprintExtender INFO Destroying BlueprintContainer for bundle xml-to-database/1.0.0.SNAPSHOT [mel.test.blueprint.Main.main()] BlueprintExtender INFO Destroying BlueprintContainer for bundle org.apache.aries.blueprint.core/1.4.4 [mel.test.blueprint.Main.main()] BlueprintExtender INFO Destroying BlueprintContainer for bundle org.apache.camel.camel-blueprint/2.17.0.redhat-630254 [mel.test.blueprint.Main.main()] Activator INFO Camel activator stopping [mel.test.blueprint.Main.main()] Activator INFO Camel activator stopped [mel.test.blueprint.Main.main()] CamelBlueprintHelper INFO Deleting work directory target/bundles/1502708357225 [ERROR] ************************************* [ERROR] Error occurred while running main from: org.apache.camel.test.blueprint.Main [ERROR] java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.camel.maven.RunMojo$1.run(RunMojo.java:458) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.RuntimeException: Gave up waiting for service (objectClass=org.apache.camel.CamelContext) at org.apache.camel.test.blueprint.CamelBlueprintHelper.getOsgiService(CamelBlueprintHelper.java:295) at org.apache.camel.test.blueprint.CamelBlueprintHelper.getOsgiService(CamelBlueprintHelper.java:256) at org.apache.camel.test.blueprint.Main.doStart(Main.java:110) at org.apache.camel.support.ServiceSupport.start(ServiceSupport.java:61) at org.apache.camel.main.MainSupport.run(MainSupport.java:138) at org.apache.camel.main.MainSupport.run(MainSupport.java:390) at org.apache.camel.test.blueprint.Main.main(Main.java:79) ... 6 more [ERROR] ************************************* [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 01:05 min [INFO] Finished at: 2017-08-14T14:00:17+03:00 [INFO] Final Memory: 39M/498M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.apache.camel:camel-maven-plugin:2.17.0.redhat-630254:run (default-cli) on project camel-blueprint: null: MojoExecutionException: InvocationTargetException: Gave up waiting for service (objectClass=org.apache.camel.CamelContext) -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException При том что в перспективе Database Development я спокойно могу подключиться к бд ... |
| 14.08.2017, 14:08:16 |
https://stackoverflow.com/a/23998619 Ошибка к подключению к БД отношения не имеет. По-моему выбор инструментов какой-то предельно не удачный. ... |
| 14.08.2017, 14:11:27 |
Если что, проблема была в этой строчке Код: sql 1. Необходимо использовать язык simple Код: sql 1. ... |
| 13.09.2017, 11:46:15 |
start [/forum/topic.php?desktop=1&fid=59&tid=2122597]: |
29ms |
48ms |
71ms |
| others: | 312ms |
| total: | 513ms |
