Добавляю @NamedQueries: ошибка Unable to build Hibernate SessionFactory
Всем привет! Intellij IDEA Ultimate 2017.3.3 Hibernate 5.2 + JPA Maven Создаю сущность User. Без аннотации @NamedQueries проект запускается без ошибок. При добавлении @NamedQueries выскакивает ошибка: авторException in thread "main" javax.persistence.PersistenceException: [PersistenceUnit: org.hibernate.tutorial.jpa] Unable to build Hibernate SessionFactory at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.persistenceException(EntityManagerFactoryBuilderImpl.java:967) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.build(EntityManagerFactoryBuilderImpl.java:892) at org.hibernate.jpa.HibernatePersistenceProvider.createEntityManagerFactory(HibernatePersistenceProvider.java:58) at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:55) at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:39) at Main.main(Main.java:9) Caused by: java.lang.NullPointerException at java.lang.String$CaseInsensitiveComparator.compare(String.java:1192) at java.lang.String$CaseInsensitiveComparator.compare(String.java:1186) at java.util.TreeMap.getEntryUsingComparator(TreeMap.java:376) at java.util.TreeMap.getEntry(TreeMap.java:345) at java.util.TreeMap.get(TreeMap.java:278) at org.hibernate.dialect.function.SQLFunctionRegistry.findSQLFunction(SQLFunctionRegistry.java:45) at org.hibernate.hql.internal.ast.util.SessionFactoryHelper.findSQLFunction(SessionFactoryHelper.java:369) at org.hibernate.hql.internal.ast.tree.IdentNode.getDataType(IdentNode.java:374) at org.hibernate.hql.internal.ast.HqlSqlWalker.lookupProperty(HqlSqlWalker.java:654) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.addrExpr(HqlSqlBaseWalker.java:5003) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.expr(HqlSqlBaseWalker.java:1286) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.exprOrSubquery(HqlSqlBaseWalker.java:4707) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.comparisonExpr(HqlSqlBaseWalker.java:4175) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.logicalExpr(HqlSqlBaseWalker.java:2138) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.whereClause(HqlSqlBaseWalker.java:815) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.query(HqlSqlBaseWalker.java:609) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.selectStatement(HqlSqlBaseWalker.java:313) at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.statement(HqlSqlBaseWalker.java:261) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.analyze(QueryTranslatorImpl.java:266) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.doCompile(QueryTranslatorImpl.java:189) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.compile(QueryTranslatorImpl.java:141) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:115) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:77) at org.hibernate.engine.query.spi.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:153) at org.hibernate.query.spi.NamedQueryRepository.checkNamedQueries(NamedQueryRepository.java:157) at org.hibernate.internal.SessionFactoryImpl.checkNamedQueries(SessionFactoryImpl.java:534) at org.hibernate.internal.SessionFactoryImpl.<init>(SessionFactoryImpl.java:324) at org.hibernate.boot.internal.SessionFactoryBuilderImpl.build(SessionFactoryBuilderImpl.java:452) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.build(EntityManagerFactoryBuilderImpl.java:889) ... 4 more Process finished with exit code 1 Класс Main.java Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. Класс User.java Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. Почему ошибка? ... |
| 04.02.2018, 18:28:30 |
Molasar, может вместо Код: java 1. надо было Код: java 1. и разве так можно писать? где селект? ... |
| 04.02.2018, 18:44:33 |
Музаффар, я поменял Код: java 1. на Код: java 1. теперь другая ошибка авторERROR: line 1:1: unexpected token: get_user_by_user_id line 1:1: unexpected token: get_user_by_user_id at org.hibernate.hql.internal.antlr.HqlBaseParser.statement(HqlBaseParser.java:210) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.parse(QueryTranslatorImpl.java:284) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.doCompile(QueryTranslatorImpl.java:186) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.compile(QueryTranslatorImpl.java:141) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:115) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:77) at org.hibernate.engine.query.spi.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:153) at org.hibernate.internal.AbstractSharedSessionContract.getQueryPlan(AbstractSharedSessionContract.java:553) at org.hibernate.internal.AbstractSharedSessionContract.createQuery(AbstractSharedSessionContract.java:662) at org.hibernate.internal.AbstractSessionImpl.createQuery(AbstractSessionImpl.java:23) at Main.main(Main.java:15) java.lang.IllegalArgumentException: org.hibernate.hql.internal.ast.QuerySyntaxException: unexpected token: get_user_by_user_id near line 1, column 1 [get_user_by_user_id] at org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:133) at org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:157) at org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:164) at org.hibernate.internal.AbstractSharedSessionContract.createQuery(AbstractSharedSessionContract.java:670) at org.hibernate.internal.AbstractSessionImpl.createQuery(AbstractSessionImpl.java:23) at Main.main(Main.java:15) Caused by: org.hibernate.hql.internal.ast.QuerySyntaxException: unexpected token: get_user_by_user_id near line 1, column 1 [get_user_by_user_id] at org.hibernate.hql.internal.ast.QuerySyntaxException.convert(QuerySyntaxException.java:74) at org.hibernate.hql.internal.ast.ErrorCounter.throwQueryException(ErrorCounter.java:91) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.parse(QueryTranslatorImpl.java:291) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.doCompile(QueryTranslatorImpl.java:186) at org.hibernate.hql.internal.ast.QueryTranslatorImpl.compile(QueryTranslatorImpl.java:141) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:115) at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:77) at org.hibernate.engine.query.spi.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:153) at org.hibernate.internal.AbstractSharedSessionContract.getQueryPlan(AbstractSharedSessionContract.java:553) at org.hibernate.internal.AbstractSharedSessionContract.createQuery(AbstractSharedSessionContract.java:662) ... 2 more фев 04, 2018 7:45:56 PM org.hibernate.engine.jdbc.connections.internal.DriverManagerConnectionProviderImpl stop INFO: HHH10001008: Cleaning up connection pool ... Process finished with exit code 0 ... |
| 04.02.2018, 19:50:54 |
нашёл ошибку Код: java 1. правильно Код: java 1. ... |
| 04.02.2018, 20:04:20 |
Molasar, все работает? ... |
| 04.02.2018, 20:25:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2122290]: |
51ms |
81ms |
| others: | 365ms |
| total: | 574ms |
