Интерпретатор на паскале. Делаю по книге "Creating Gear: An interpreter written in Free Pascal" с небольшими правками.
ссылка для скачивания https://cloud.mail.ru/public/1KND/xbMLrR7a4 Creating Gear: An interpreter written in Free Pascal using an external tree visitor pattern Jeroen de Haan гитхаб автора. там же эта книга в папке Doc https://github.com/jdehaan2014/GearLanguage/tree/master/interpreter This is a no-nonsense book about creating an interpreted programming language, named “Gear”, using an external visitor pattern. Why Gear? No particular reason, I just like the sound of it… In this book I won’t describe a lot of theory, as there are plenty of good books out there. As a matter of fact, I do recommend reading a few of them, such as: - Writing Compilers and Interpreters, A software emgineering approach (Ronald Mak) - Language Implementation Patterns (Terence Parr) Then, there are hands-on websites/blogs that describe and create an interpreter on-the-go: - Let’s build a simple interpreter (https://ruslanspivak.com/lsbasi-part1/) (Ruslan Spivak) - Crafting Interpreters (http://craftinginterpreters.com) (Bob Nystrom) These books/blogs use Java or Python as programming language. The code in this book is based on the programming language Object Pascal, a modern pascal version, and the free downloadable IDE ‘Lazarus’. Lazarus/Free Pascal is available for Windows, Linux, OSX, and many other Operatig Systems. It’s slogan is: ‘Write once, compile anywhere’! The website and download links are available at: http://www.lazarus-ide.org/index.php. For this book I use version 2.0.4 (or later) of Lazarus and version 3.04 (or later) of Free Pascal. ... |
| 09.10.2023, 09:24:58 |
#40138116
Буду считать это своим "Coding kata". Да и просто развлечение. Даже сделал проект на гитхабе, но это скорее для бэкапа. Кое-что меняю, но по мелочи. ... |
Изменено: 09.10.2023, 19:49:36 - Неуловимый Джо
| 09.10.2023, 09:31:11 |
Тема перенесена отсюда https://nosql.itwrks.org/forum/topic.php?fid=16&tid=11905 тут буду писать продолжение. ... |
| 09.10.2023, 11:14:45 |
Забыл сказать, делаю на Delphi 11.3 ... |
| 09.10.2023, 11:17:30 |
#40138120
| 09.10.2023, 11:24:31 |
#40138121
Для строк ограниченных апострофами добавлено экранирование апострофа (кавычки в таких строках считаются обычным символом). Для строк ограниченных кавычками, добавлено экранирование кавычки (апостроф в такой строке считается обычным символом). Это отсебятина, у автора строки ограничиваются только апострофами. ... |
| 09.10.2023, 11:35:08 |
#40138122
| 09.10.2023, 11:44:42 |
А что там за входной язык ? Где почитать про синтаксис ? уже нашёл https://github.com/jdehaan2014/GearLanguage/blob/master/interpreter/doc/The Gear language description.pdf ... |
| 09.10.2023, 19:21:48 |
А что там за входной язык ? Где почитать про синтаксис ? уже нашёл https://github.com/jdehaan2014/GearLanguage/blob/master/interpreter/doc/The Gear language description.pdf Я так понимаю это самиздат, книга не опубликована. ... |
Изменено: 09.10.2023, 19:28:54 - Неуловимый Джо
| 09.10.2023, 19:28:20 |
Следующее наверно буду делать интерполяцию строк (я делаю не по порядку, а что хочется в текущий момент). То есть что-то вроде 'строка${5+5}продолжение строки' ... |
| 10.10.2023, 23:25:10 |
#40138135
Изменено: 11.10.2023, 22:10:10 - Неуловимый Джо
| 11.10.2023, 21:35:57 |
#40138143
| 13.10.2023, 09:46:00 |
#40138145
| 14.10.2023, 00:43:13 |
#40138146
Изменено: 14.10.2023, 00:54:34 - Неуловимый Джо
| 14.10.2023, 00:52:57 |
#40138147
| 14.10.2023, 14:34:40 |
#40138150
| 14.10.2023, 22:50:45 |
#40138158
| 19.10.2023, 23:30:30 |
#40138191
Интерпретация Dictionary уже работает. С хэшами плюнул, в этом интерепретаторе всё хранится в Variant, не переделывать же сейчас всё на TObject. А с Variant 1 и '1' это одно и то же. Решил пойти по простому пути, ключом в словаре может быть только строка, все остальное будет приводиться к строке. Собственно, цель словаря в этом интерпретаторе будет только для упрощения получения данных с датасетов. Чтоб можно было обращаться примерно так Код: Delphi 1. 2. ... |
| 29.10.2023, 18:16:49 |
#40138216
| 05.11.2023, 16:47:05 |
#40138253
| 02.12.2023, 19:19:14 |
start [/forum/topic.php?desktop=1&fid=58&tid=2186854]: |
53ms |
87ms |
| others: | 296ms |
| total: | 510ms |
