Можно ли поставить BDE вручную?
Подскажите, пожалуйста, можно ли поставить BDE вручную? Или не вручную, но без использования Windows Installer'a. ... |
| 04.08.2003, 11:29 |
1. Переписать все файлы: CHARSET.BLL OTHER.BLL USA.BLL IDAPI32.CFG BLW32.DLL IDAPI32.DLL IDBAT32.DLL IDPDX32.DLL IDR20009.DLL IDSQL32.DLL BDEADMIN.EXE 2. Прописать в регистри след. значения: REGEDIT4 [HKEY_LOCAL_MACHINE\SOFTWARE\Borland] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine] "DLLPATH"="C:\\APartner\\BDE451\\SQLLinks.40;C:\\APartner\\BDE451" "RESOURCE"="0009" "CONFIGFILE01"="C:\\APartner\\BDE451\\IDAPI32.CFG" "UseCount"="1" "SaveConfig"="WIN32" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\DBASE] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\DBASE\INIT] "VERSION"="4.0" "TYPE"="FILE" "LANGDRIVER"="db866ru0" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\DBASE\TABLE CREATE] "LEVEL"="5" "MDX BLOCK SIZE"="1024" "MEMO FILE BLOCK SIZE"="1024" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\MSACCESS] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\MSACCESS\DB OPEN] "DATABASE NAME"="DRIVE:/PATH/DATABASE.MDB" "USER NAME"="" "OPEN MODE"="READ/WRITE" "LANGDRIVER"="" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\MSACCESS\INIT] "VERSION"="1.0" "TYPE"="SERVER" "DLL32"="IDDAO32.DLL" "DRIVER FLAGS"="" "TRACE MODE"="0" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\ORACLE] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\ORACLE\DB OPEN] "SERVER NAME"="ORA_SERVER" "USER NAME"="MYNAME" "NET PROTOCOL"="TNS" "OPEN MODE"="READ/WRITE" "SCHEMA CACHE SIZE"="8" "LANGDRIVER"="" "SQLQRYMODE"="" "SQLPASSTHRU MODE"="SHARED AUTOCOMMIT" "SCHEMA CACHE TIME"="-1" "MAX ROWS"="-1" "BATCH COUNT"="200" "ENABLE SCHEMA CACHE"="FALSE" "SCHEMA CACHE DIR"="" "ENABLE BCD"="FALSE" "ENABLE INTEGERS"="FALSE" "LIST SYNONYMS"="NONE" "ROWSET SIZE"="20" "BLOBS TO CACHE"="64" "BLOB SIZE"="32" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\ORACLE\INIT] "VERSION"="4.0" "TYPE"="SERVER" "DLL"="SQLD_ORA.DLL" "DLL32"="SQLORA32.DLL" "VENDOR INIT"="ORANT71.DLL" "DRIVER FLAGS"="" "TRACE MODE"="0" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\PARADOX] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\PARADOX\INIT] "VERSION"="4.0" "TYPE"="FILE" "LANGDRIVER"="ancyrr" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\DRIVERS\PARADOX\TABLE CREATE] "LEVEL"="4" "BLOCK SIZE"="2048" "FILL FACTOR"="95" "STRICTINTEGRTY"="TRUE" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\REPOSITORIES] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\REPOSITORIES\Borland Data Dictionary] "DATABASE NAME"="DefaultDD" "TABLE NAME"="BDESDD" "LANGUAGE DRIVER"="" "DESCRIPTION"="Borland Database Engine Sample Data Dictionary" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM\FORMATS] [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM\FORMATS\DATE] "SEPARATOR"="." "MODE"="1" "FOURDIGITYEAR"="FALSE" "YEARBIASED"="TRUE" "LEADINGZEROM"="FALSE" "LEADINGZEROD"="FALSE" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM\FORMATS\NUMBER] "DECIMALSEPARATOR"="." "THOUSANDSEPARATOR"=" " "DECIMALDIGITS"="2" "LEADINGZERON"="TRUE" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM\FORMATS\TIME] "TWELVEHOUR"="FALSE" "AMSTRING"="AM" "PMSTRING"="PM" "SECONDS"="TRUE" "MILSECONDS"="FALSE" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine\Settings\SYSTEM\INIT] "VERSION"="4.0" "LOCAL SHARE"="FALSE" "MINBUFSIZE"="128" "MAXBUFSIZE"="2048" "LANGDRIVER"="ancyrr" "MAXFILEHANDLES"="48" "SYSFLAGS"="0" "LOW MEMORY USAGE LIMIT"="32" "AUTO ODBC"="FALSE" "DEFAULT DRIVER"="PARADOX" "MEMSIZE"="16" "SHAREDMEMSIZE"="2048" "SHAREDMEMLOCATION"="" "DATA REPOSITORY"="Borland Data Dictionary" "SQLQRYMODE"="" [HKEY_LOCAL_MACHINE\SOFTWARE\Borland\BLW32] "BLAPIPATH"="C:\\APartner\\BDE451" "LOCALE_LIB1"="C:\\APartner\\BDE451\\USA.BLL" "LOCALE_LIB2"="C:\\APartner\\BDE451\\EUROPE.BLL" "LOCALE_LIB3"="C:\\APartner\\BDE451\\OTHER.BLL" "LOCALE_LIB4"="C:\\APartner\\BDE451\\CHARSET.BLL" "LOCALE_LIB5"="C:\\APartner\\BDE451\\CEEUROPE.BLL" "LOCALE_LIB6"="C:\\APartner\\BDE451\\FAREAST.BLL" "LOCALE_LIB7"="C:\\APartner\\BDE451\\JAPAN.BLL" ... |
| 04.08.2003, 13:26 |
start [/forum/topic.php?desktop=1&fid=58&tid=2117448]: |
72ms |
37ms |
| others: | 258ms |
| total: | 409ms |
