Nujna informacia o sisteme
esli kto znaet podskajite pojalusta kak mojno iz delphi uznat imia kompa na kotorom zapushena proga I nazvanie jestkogo diska??? ... |
| 28.08.2003, 17:40 |
The GetComputerName function retrieves the computer name of the current system. This name is established at system startup, when it is initialized from the registry. Что значит "название жесткого диска"? ... |
| 28.08.2003, 17:49 |
Spasiba za sovet!!! Ved 'C' ne vsegda 'C' ego je dlia seti mojno kak to nazvat...tak vot eto imia mne i nujno ..kotorie vidno v seti.... ... |
| 28.08.2003, 17:54 |
Если узнать диск, с которого прога запущена, то потраши ParamStr( 0 ) , а если системный диск, то GetWindowsDirectory , GetSystemDirectory . ... |
| 28.08.2003, 19:10 |
Tommy Smith >>I nazvanie jestkogo diska??? Это для C++Builder. Для Delphi думаю сами сможете переделать, кому это необходимо. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. ... |
| 29.08.2003, 09:06 |
Returns the drive portion of a file name. Unit SysUtils Category file name utilities extern PACKAGE AnsiString __fastcall ExtractFileDrive(const AnsiString FileName); Description On Windows, ExtractFileDrive returns an AnsiString containing the drive portion of a fully qualified path name for the file passed in the FileName. For file names with drive letters, the result is in the form “'<drive>'”. For file names with a UNC path the result is in the form “'\\<servername>\<sharename>'”. If the given path contains neither style of path prefix, the result is an empty string.On Linux, ExtractFileDrive always returns a zero-length string. ... |
| 29.08.2003, 09:08 |
start [/forum/topic.php?desktop=1&fid=58&tid=2117108]: |
159ms |
51ms |
| others: | 259ms |
| total: | 519ms |
