DevExpress ExpressQuantumGrid русский язык?
Поделитесь пожалуйста русским языком для DevExpress ExpressQuantumGrid 18.2.5 русский язык Сейчас отображается, как в приложенном скрине ... |
| 02.05.2019, 23:17 |
тот ini файл нужно конвертировать в юникод, наверное ... |
| 03.05.2019, 08:37 |
X11, Спасибо, но не в этом дело. Ранее народ локализацию проводил утилиткой VCL Localizer Editor tool. Мне хотя бы английскую локализацию, т.к. моя версия похоже от персидских братьев. ... |
| 03.05.2019, 09:30 |
unlimuser, EQG Help - Base Concepts - Resource StringsDeveloper Express offers you a simple and complete mechanism of localizing the resource strings, which is common to all Developer Express VCL products. You can use the TcxLocalizer component designed to simplify localization tasks, or manually replace the default value of specific resource strings at runtime via the cxSetResourceString procedure calls. To learn more about the TcxLocalizer component, please refer to the How To Localize an Application Using the TcxLocalizer help topic. The cxSetResourceString procedure is used with the cxGetResourceString function used by Developer Express controls. When the controls need a specific string to display, they call the cxGetResourceString function, which returns either the custom string or the default string (if the resource string was not replaced). Resource strings are declared in separate files for individual Developer Express VCL products. Use the links below to obtain information on resource strings available for specific products. These sections provide resource string identifiers (required by cxSetResourceString) and default values: ExpressEditors ExpressQuantumGrid ExpressDataController Filter Controls and Dialogs Grid Popup Menus Example A date editor displays a Clear button in its dropdown. The button's string is addressed by the cxSDatePopupClear identifier. The following code substitutes the caption of the button with its German equivalent: [Delphi] cxSetResourceString(@cxSDatePopupClear, 'Löschen'); [C++ Builder] cxSetResourceString(&_cxSDatePopupClear, "Löschen"); This code changes the caption of the Clear button for all date editors in the current application. ... |
| 03.05.2019, 10:25 |
Нет, мне кажется, у тебя просто неюникодная версия. Или наоборот. Среда и программа юникодные, а файл локализации - нет. ... |
| 03.05.2019, 12:16 |
| 03.05.2019, 12:26 |
тут вот ещё что-то есть https://www.sql.ru/blogs/x11/1338 но блоги автор сайта забросил, поэтому ничего нельзя там сделать: ни отредактировать, ни коммент добавить, ни новую запись создать ... |
| 03.05.2019, 12:27 |
Все оказалось более просто и язящно - использование готовой встроенной компоненты cxLocalizer, которая дает возможность менять налету на любое кол-во языков, в т.ч. русский. Вопрос для меня закрыт. Спасибо всем откликнувшимся. ... |
| 03.05.2019, 14:13 |
start [/forum/topic.php?desktop=1&fid=58&tid=2039519]: |
63ms |
44ms |
| others: | 230ms |
| total: | 390ms |
