RAD Studio 11 PAServer January Patch
Product RAD Studio 11 PAServer January Patch Description This is the third patch for RAD Studio 11 and it includes only an update to PAServer for macOS and iOS development on macOS 12 Monterey Size 81656998 MD5 f37dc05674c8361f220bfa9866ccd372 https://my.embarcadero.com/#downloadDetail/1201 RAD Studio 11 PAServer January Patch Readme This is the third patch for RAD Studio 11. It is an update to PAServer for macOS and iOS development on macOS 12 Monterey (the new version of PAServer is 13.0.12.2). It does not include other files from the previous November Patch. You may install this and the November Patch in any sequence. Important note: this patch requires some manual installation even if installed via GetIt. Please read the readme carefully! Installing this patch is recommended for all RAD Studio 11 customers who build applications for macOS or iOS. The Quality Portal issue addressed is: - RSP-36648: iOS: Invalid Code Signing of frameworks If you do not build applications for macOS or iOS, you do not need to install this patch. Installation via GetIt: Manual Steps Are Required! The updated RAD Studio 11.0 PAServer version 13.0.12.2 for iOS and macOS is only installed in the Catalog Repository folder and not copied into the PAServer folder. You need to: - Copy the new PAServer over to a Mac and install it manually there; - In the SDK Manager of the RAD Studio IDE, delete and redefine the macOS 12.0 SDK and/or the iOS 15.0 SDK (we recommend deleting and importing again any Apple SDK you have already, if you are running PAServer on macOS Monterey). This is not needed if you have already refreshed the SDK Manager with the November patch. Manual Download and Installation This patch is also available in the download portal at my.embarcadero.com named ‘RAD Studio 11 PAServer January Patch’. Download this. You will need to copy and install PAServer to your Mac and reimport the SDKs using the same manual steps as explained above. Uninstallation steps (for GetIt installation) - Uninstall the package from GetIt - Restore the older version of PAServer on your Mac using the version in the RAD Studio installation folder ... |
| 20.01.2022, 15:53:54 |
| 20.01.2022, 16:56:11 |
start [/forum/topic.php?desktop=1&fid=58&tid=2036695]: |
52ms |
59ms |
| others: | 280ms |
| total: | 460ms |
