Незнаю, какой файл подключить
Сделал Import Type Library для Dao, в результате получил файлы в папке import, названия которых DAO_OCX.xxx включая .h, DAO_TBL.xxx включая .h, какой из них надо подключать к проекту? ----------------------------------------------------------- С уважением,MySQLdb ... |
| 24.09.2004, 10:12 |
MSDN, как обычно, рулит http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vclang/html/_predir_The_.23.import_Directive.asp автор Header Files Created by Import #import creates two header files that reconstruct the type library contents in C++ source code. The primary header file is similar to that produced by the Microsoft Interface Definition Language (MIDL) compiler, but with additional compiler-generated code and data. The primary header file has the same base name as the type library, plus a .TLH extension. The secondary header file has the same base name as the type library, with a .TLI extension. It contains the implementations for compiler-generated member functions, and is included (#include) in the primary header file. If importing a dispinterface property that uses byref parameters, #import will not generate __declspec(property) statement for the function. Both header files are placed in the output directory specified by the /Fo (name object file) option. They are then read and compiled by the compiler as if the primary header file was named by a #include directive. The following compiler optimizations come with the #import directive: The header file, when created, is given the same timestamp as the type library. When #import is processed, the compiler first checks if the header exists and is up to date. If yes, then it does not need to be re-created. The #import directive also participates in minimal rebuild and can be placed in a precompiled header file. See Creating Precompiled Header Files for more information. ... |
| 24.09.2004, 10:58 |
Я веду речь про Builder C++, но не про VC++ ----------------------------------------------------------- С уважением,MySQLdb ... |
| 24.09.2004, 11:05 |
я пользовал TBL ... |
| 24.09.2004, 11:07 |
zalexakaя пользовал TBL патч TLB конешна :) ... |
| 24.09.2004, 11:08 |
start [/forum/topic.php?desktop=1&fid=57&tid=2034382]: |
51ms |
| others: | 240ms |
| total: | 339ms |
