MSXML 4.0 BCB5
Win98 Borland C++ Builder 5 Ispoljzuju MSXML 4.0 Sp2, ustanovlinneij v direktoriju Project |import type lib msxml4.dll viden C:\Program Files\MSXML 4.0 V boralnd proekte Project|Options |Directories /Conditionals Include path ..\..\..\MSXML 4.0\inc //estj MSXML4.0 headeri Library path ..\..\..\MSXML 4.0\lib //estj MSXML4.0 libraries No sledujashaja programma primer iz MSXML SDK ne kompiliruetsja. Vidaet kuchu oshibok . #include "C:\Program Files\MSXML 4.0\inc\msxml2.h" #include <msxml2.h> #include <vcl.h> #include <stdio.h> #include <iostream.h> int main(int argc, char* argv[]) { //new added ////#import "C:\WINDOWS\SYSTEM\msxml4.dll" raw_interfaces_only HINSTANCE DLL = LoadLibrary("msxml4.dll"); if (DLL){ cout << "LOADED "; } else { cout << " NOT LOADED ";} HRESULT hr; IXMLDOMDocument2 *pXMLDoc = NULL; IXMLDOMParseError * pObjError = NULL; BSTR bstr = NULL; VARIANT_BOOL status; VARIANT vSrc; CoInitialize(NULL); hr = CoCreateInstance(CLSID_DOMDocument40, NULL, CLSCTX_INPROC_SERVER, IID_IXMLDOMDocument2, (void**)&pXMLDoc); if (FAILED(hr)) { // printf("Failed to CoCreate an instance of an XML DOM\n"); // cout<<"Failed to CoCreate an instance of an XML DOM\n"; //printf("Error code: %x\n", hr); // cout <<"Error code: "<< hr<<endl; goto clean; } hr = pXMLDoc->put_async(VARIANT_FALSE); if (FAILED(hr)) { //printf("Failed to set async property\n"); goto clean; } hr = pXMLDoc->put_validateOnParse(VARIANT_FALSE); if (FAILED(hr)) { // printf("Failed to set validateOnParse\n"); goto clean; } hr = pXMLDoc->put_resolveExternals(VARIANT_FALSE); if (FAILED(hr)) { //printf("Failed to disable resolving externals.\n"); goto clean; } VariantInit(&vSrc); V_BSTR(&vSrc) = SysAllocString(L"stocks.xml"); V_VT(&vSrc) = VT_BSTR; hr = pXMLDoc->load(vSrc, &status); if(status!=VARIANT_TRUE) { hr = pXMLDoc->get_parseError(&pObjError); hr = pObjError->get_reason(&bstr); //printf("Failed to load DOM from books.xml. %S\n",bstr); goto clean; } hr = pXMLDoc->get_xml(&bstr); //printf("stocks.xml:\n%S\n", bstr); clean: if (bstr) SysFreeString(bstr); if (&vSrc) VariantClear(&vSrc); if (pObjError) pObjError->Release(); if (pXMLDoc) pXMLDoc->Release(); CoUninitialize(); return 0; } //*/ V chem mozhet bitj delo ? ... |
| 12.04.2005, 12:05:25 |
start [/forum/topic.php?desktop=1&fid=57&tid=2033484]: |
41ms |
| others: | 195ms |
| total: | 281ms |
