Ошибка при установке компоненты в BCBuilder6
При попытке установить компонет линковщик матерится: автор[Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::~TCustomOutline()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::TCustomOutline(Classes::TComponent *)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetOutlineStyle(Outline::TOutlineStyle)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetOutlineOptions(System::Set<Outline::TOutlineOption, 0, 2>)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::GetPicture(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetPicture(int, Graphics::TBitmap *)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::GetFullPath()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::HasChildren()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::getFirstChild()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::GetNextChild(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Insert(int, const System::AnsiString)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::GetLastChild()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Add(int, const System::AnsiString)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::AddChild(int, const System::AnsiString)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Get(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Clear()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TOutlineNode::SetExpandedState(bool)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetSelectedItem(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Click()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::GetSelectedItem()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Expand(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::Loaded()' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external 'Outline::TCustomOutline::' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::DefineProperties(Classes::TFiler *)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::DrawCell(int, int, const Types::TRect&, System::Set<Grids::Grids__3, 0, 2>)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__tpdsc__ Outline::TCustomOutline' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetItemHeight(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::StoreBitmap(int)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp [Linker Error] Unresolved external '__fastcall Outline::TCustomOutline::SetStyle(Outline::TOutlineType)' referenced from C:\PROGRAM FILES\BORLAND\CBUILDER6\LIB\BCBSMP.LIB|.\cdiroutl.cpp Что может быть? ... |
| 10.06.2005, 11:15:42 |
start [/forum/topic.php?desktop=1&fid=57&tid=2033171]: |
67ms |
| others: | 207ms |
| total: | 333ms |
