Какой код для "page up" и "page down"?
Нужно для sendmessage ... |
| 28.03.2006, 17:47:29 |
Из DOS времён помню, что один из них 43, другой рядом. Но в winuser.h написано: #define VK_PRINT 0x2A #define VK_EXECUTE 0x2B #define VK_SNAPSHOT 0x2C ... |
| 28.03.2006, 18:19:59 |
Что-то не найду (или ослеп?) ? #define VK_LBUTTON 1 #define VK_RBUTTON 2 #define VK_CANCEL 3 #define VK_MBUTTON 4 #define VK_BACK 8 #define VK_TAB 9 #define VK_CLEAR 12 #define VK_RETURN 13 #define VK_KANA 15 #define VK_SHIFT 16 #define VK_CONTROL 17 #define VK_MENU 18 #define VK_PAUSE 19 #define VK_CAPITAL 20 #define VK_ESCAPE 0x1B #define VK_SPACE 32 #define VK_PRIOR 33 #define VK_NEXT 34 #define VK_END 35 #define VK_HOME 36 #define VK_LEFT 37 #define VK_UP 38 #define VK_RIGHT 39 #define VK_DOWN 40 #define VK_SELECT 41 #define VK_PRINT 42 #define VK_EXECUTE 43 #define VK_SNAPSHOT 44 #define VK_INSERT 45 #define VK_DELETE 46 #define VK_HELP 47 #define VK_LWIN 0x5B #define VK_RWIN 0x5C #define VK_APPS 0x5D #define VK_NUMPAD0 0x60 #define VK_NUMPAD1 0x61 #define VK_NUMPAD2 0x62 #define VK_NUMPAD3 0x63 #define VK_NUMPAD4 0x64 #define VK_NUMPAD5 0x65 #define VK_NUMPAD6 0x66 #define VK_NUMPAD7 0x67 #define VK_NUMPAD8 0x68 #define VK_NUMPAD9 0x69 #define VK_MULTIPLY 0x6A #define VK_ADD 0x6B #define VK_SEPARATOR 0x6C #define VK_SUBTRACT 0x6D #define VK_DECIMAL 0x6E #define VK_DIVIDE 0x6F #define VK_F1 0x70 #define VK_F2 0x71 #define VK_F3 0x72 #define VK_F4 0x73 #define VK_F5 0x74 #define VK_F6 0x75 #define VK_F7 0x76 #define VK_F8 0x77 #define VK_F9 0x78 #define VK_F10 0x79 #define VK_F11 0x7A #define VK_F12 0x7B #define VK_F13 0x7C #define VK_F14 0x7D #define VK_F15 0x7E #define VK_F16 0x7F #define VK_F17 0x80 #define VK_F18 0x81 #define VK_F19 0x82 #define VK_F20 0x83 #define VK_F21 0x84 #define VK_F22 0x85 #define VK_F23 0x86 #define VK_F24 0x87 #define VK_NUMLOCK 0x90 #define VK_SCROLL 0x91 #define VK_LSHIFT 0xA0 #define VK_RSHIFT 0xA1 #define VK_LCONTROL 0xA2 #define VK_RCONTROL 0xA3 #define VK_LMENU 0xA4 #define VK_RMENU 0xA5 #define VK_PROCESSKEY 0xE5 #define VK_ATTN 0xF6 #define VK_CRSEL 0xF7 #define VK_EXSEL 0xF8 #define VK_EREOF 0xF9 #define VK_PLAY 0xFA #define VK_ZOOM 0xFB #define VK_NONAME 0xFC #define VK_PA1 0xFD #define VK_OEM_CLEAR 0xFE ... |
| 28.03.2006, 19:39:21 |
VK_NEXT VK_PRIOR ... |
| 28.03.2006, 19:56:27 |
start [/forum/topic.php?desktop=1&fid=57&tid=2031660]: |
42ms |
| others: | 189ms |
| total: | 278ms |
