Open Directory using OpenDialogBox
Hello, Does anyone know of a way to use the OpenDialogBox in Borland 6 to select a folder instead of just a file. I need to allow the user to select a directory so that I can open multiple files out of subdirectories. -Brian ... |
| 23.06.2006, 16:56:36 |
1. TDirectoryListBox 2. OpenDialog->Options->AllowMultiSelect ... |
| 23.06.2006, 17:26:06 |
I tried that and it does not let you select a directory. Once a folder has been selected and the open button is clicked the dialog will just open that folder (rather than selecting it and closing the dialog). Any other advice? ... |
| 23.06.2006, 22:02:29 |
Brian, You should deside what you really want. If you want to select multiple file inside the directory then solution from Dmitrii K. should work. If you want to select a directory anthen process files in it then look at these links: codeguru ; codeproject May be it is what you want. ... |
| 24.06.2006, 01:25:37 |
start [/forum/topic.php?desktop=1&fid=57&tid=2030946]: |
46ms |
40ms |
| others: | 238ms |
| total: | 355ms |
