Как узнать, существует ли каталог?
Как узнать, существует ли каталог на чистом C/C++? ... |
| 12.08.2006, 13:19:47 |
А какая ОС? ... |
| 12.08.2006, 15:32:04 |
F1 Header File dir.h Category Directory Control Routines Prototype int chdir(const char *path); int _wchdir(const wchar_t *path); Description Changes current directory. chdir causes the directory specified by path to become the current working directory; path must specify an existing directory. A drive can also be specified in the path argument, such as chdir("a:\\BC") but this method changes only the current directory on that drive; it does not change the active drive. Under Windows, only the current process is affected. Return Value Upon successful completion, chdir returns a value of 0. Otherwise, it returns a value of -1, and the global variable errno is set to ENOENT Path or file name not found + перед этим setdisk ... |
| 12.08.2006, 15:32:57 |
можно проще (из VCL содрал): bool dirExists(const char* dirName){ DWORD code = GetFileAttributes(dirName); return (code != 0xFFFFFFFF)&&((code & FILE_ATTRIBUTE_DIRECTORY)!=0); } ... |
| 17.08.2006, 01:33:05 |
ИЗвините. В тему не вчитался... :( ... |
| 17.08.2006, 01:38:04 |
man stat ну или _stat ... |
| 17.08.2006, 07:37:59 |
start [/forum/topic.php?desktop=1&fid=57&tid=2030672]: |
27ms |
30ms |
| others: | 188ms |
| total: | 274ms |
