undefined reference to `mysql_close@4'
Привет., написал клас для работы с mysql в Visual C++ Тепер когда импортирую проект в wxDev-C++ то получаю ошыбки.... Default Profile/Quemy.o:Quemy.cpp:(.text+0x906): undefined reference to `mysql_close@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x92e): undefined reference to `mysql_init@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x9b7): undefined reference to `mysql_real_connect@32' Default Profile/Quemy.o:Quemy.cpp:(.text+0x9de): undefined reference to `mysql_select_db@8' Default Profile/Quemy.o:Quemy.cpp:(.text+0xa13): undefined reference to `mysql_close@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0xa4d): undefined reference to `mysql_close@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0xa74): undefined reference to `mysql_get_client_info@0' Default Profile/Quemy.o:Quemy.cpp:(.text+0xef3): undefined reference to `mysql_query@8' Default Profile/Quemy.o:Quemy.cpp:(.text+0x107c): undefined reference to `mysql_insert_id@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x1141): undefined reference to `mysql_real_query@12' Default Profile/Quemy.o:Quemy.cpp:(.text+0x1160): undefined reference to `mysql_store_result@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x117d): undefined reference to `mysql_num_rows@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x119a): undefined reference to `mysql_num_fields@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x11b7): undefined reference to `mysql_fetch_fields@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x11de): undefined reference to `mysql_data_seek@12' Default Profile/Quemy.o:Quemy.cpp:(.text+0x1394): undefined reference to `mysql_free_result@4' Default Profile/Quemy.o:Quemy.cpp:(.text+0x1757): undefined reference to `mysql_data_seek@12' Default Profile/Quemy.o:Quemy.cpp:(.text+0x1768): undefined reference to `mysql_fetch_row@4' Кто-то может помочь.. ? ... |
| 20.12.2006, 12:18 |
Должна подключаться библиотека. ... |
| 20.12.2006, 12:30 |
Как.., я ее прописал в параметрах проекта.., вот лог компиляции.., я ее переназвал с разширенеем "а" и тепер при компиляции выдает Building Makefile: "D:\C++Projects\DEV_C++_Projects\QuemyImp\Makefile.win" Âèêîíàííÿ make... mingw32-make.exe -f "D:\C++Projects\DEV_C++_Projects\QuemyImp\Makefile.win" all g++.exe "Default Profile/main.o" "Default Profile/Quemy.o" -o "Default Profile\main.exe" -L"m:/Dev-Cpp/Lib" -mwindows -lwxmsw27 -lwxmsw27_gl -lwxtiff -lwxjpeg -lwxpng -lwxzlib -lwxregex -lwxexpat -lkernel32 -luser32 -lgdi32 -lcomdlg32 -lwinspool -lwinmm -lshell32 -lcomctl32 -lole32 -loleaut32 -luuid -lrpcrt4 -ladvapi32 -lwsock32 -lodbc32 -lopengl32 -libmySQL m:\Dev-Cpp\Bin\..\lib\gcc\mingw32\3.4.2\..\..\..\..\mingw32\bin\ld.exe: cannot find -libmySQL collect2: ld returned 1 exit status mingw32-make.exe: *** [Default Profile/main.exe] Error 1 ... |
| 20.12.2006, 12:32 |
Попробуй -llibmySQL или -lmySQL. Первый символ "l" к названию библиотеки не относится ... |
| 20.12.2006, 12:45 |
А еще вопросик., lib-файлы от Visual C++ можна подключать к wxDEV-C++ ? ... |
| 20.12.2006, 13:10 |
start [/forum/topic.php?desktop=1&fid=57&tid=2029787]: |
50ms |
37ms |
| others: | 221ms |
| total: | 349ms |
