Pervasive v9 временная таблица
Добрый день, Не подскажите как в Pervasive v9 запросом создавать временные таблицы и заносить туда данные а потом уже от тудого еще один запрос на выборку данных из временной таблицы! ... |
| 20.12.2007, 07:19:24 |
RTFM CREATE (temporary) TABLE You can also use the CREATE TABLE statement to create a temporary table. The CREATE TABLE syntax for temporary tables is more restrictive than for permanent tables. For this reason, and because of other characteristics, temporary tables are discussed in their own section. Syntax CREATE TABLE <# | ##>table-name (table-element [ , table-element ]... ) table-name ::= user-defined-name table-element ::= column-definition | table-constraint-definition column-definition ::= column-name data-type [ DEFAULT default-value-expression ] [ column-constraint [ column-constraint ]... [CASE (string) | COLLATE collation-name ] column-name ::= user-defined-name data-type ::= data-type-name [ (precision [ , scale ] ) ] precision ::= integer scale ::= integer default-value-expression ::= default-value-expression + default-value-expression | default-value-expression - default-value-expression | default-value-expression * default-value-expression | default-value-expression / default-value-expression | default-value-expression & default-value-expression | default-value-expression | default-value-expression | default-value-expression ^ default-value-expression | ( default-value-expression ) | -default-value-expression | +default-value-expression | ~default-value-expression | ? | literal | scalar-function | { fn scalar-function } | USER | NULL literal ::= 'string' | number | { d 'date-literal' } | { t 'time-literal' } | { ts 'timestamp-literal' } scalar-function ::= see Scalar Functions column-constraint ::= [ CONSTRAINT constraint-name ] col-constraint constraint-name ::= user-defined-name col-constraint ::= NOT NULL | UNIQUE | PRIMARY KEY | REFERENCES table-name [ ( column-name ) ] [ referential-actions ] table-constraint-definition ::= [ CONSTRAINT constraint-name ] table-constraint table-constraint ::= UNIQUE ( column-name [ , column-name ]... ) | PRIMARY KEY ( column-name [ , column-name ]... ) REFERENCES table-name [ ( column-name [ , column-name ]... ) ] [ referential-actions ] referential-actions ::= referential-update-action [ referential-delete-action ] | referential-delete-action [ referential-update-action ] referential-update-action ::= ON UPDATE RESTRICT referential-delete-action ::= ON DELETE CASCADE | ON DELETE RESTRICT collation-name ::= 'string' | user-defined-name Remarks A temporary table is used for intermediate results or working storage. Unlike in permanent tables, data in a temporary table is destroyed at some point during the SQL session or at the end of the SQL session. The data is not saved in the database. Temporary tables are useful to narrow down intermediate results by continuing to operate on intermediate tables. Complex data operations are often easier if split into a sequence of simpler steps, which each step operating on the table result of a previous step. A temporary table is a base table. That is, the data it contains is its own. Contrast this with a view, which is an indirect representation of data in other tables. ... |
| 20.12.2007, 07:47:38 |
start [/forum/topic.php?desktop=1&fid=56&tid=2016035]: |
43ms |
34ms |
| others: | 299ms |
| total: | 442ms |
