dump в DERBY
всем привет! Делаю java -cp .;derbytools.jar org.apache.derby.tools.dblook -d jdbc:derby:D:\derbyDB -t documents -o dump.sql В sql получаю дамп только структуры базы а самих данных нет. D:\dist\lib>java -cp .;derbyTOOLS.jar org.apache.derby.tools.dblook --help USAGE: java org.apache.derby.tools.dblook -d <sourceDBUrl> [OPTIONS] where the source URL is the full URL, including the connection protocol and any connection attributes that might apply. For example, use 'jdbc:derby:myDB', or 'jdbc:derby://localhost:1527/myDB;user=usr;'. options include: -z <schemaName> to specify a schema to which the DDL generation should be limited. Only database objects with that schema will have their DDL generated. -t <tableOne> <tableTwo> ... to specify a list of tables for which the DDL will be generated; any tables not in the list will be ignored. -td <value> to specify what should be appended to the end of each DDL statement. This defaults to ';'. -noview to prevent the generation of DDL for views. -append to keep from overwriting the output files. -verbose to have error messages printed to the console (in addition to the log file). If not specified, errors will only be printed to the log file. -o <filename> to specify the file name to which the generated DDL will be written. If not specified, default is the console. ... |
| 13.05.2008, 19:35:28 |
start [/forum/topic.php?desktop=1&fid=56&tid=2015946]: |
315ms |
| others: | 295ms |
| total: | 686ms |
