WARNING - Fatal Error 423 occurred
Привет! При insert возникает вот такое сообщение. При этом insert проходит. В мануале по error messages ничего подобного не нашел. Может сталкивался кто? Msg 21, Level 20, State 1 Server 'CW_SYBASE', Line 1 WARNING - Fatal Error 423 occurred at Aug 10 2004 1:58PM. Please note the error and time, and contact a user with System Administrator (SA) authorization. ... |
| 10.08.2004, 14:02 |
Number Severity Text and Explanation 21 10 WARNING - Fatal Error %ld occurred at %S_DATE. Please note the error and time, and contact a user with System Administrator (SA) authorization. Explanation: This is an informational message. Unless otherwise specified, no action is required. Contact your System Administrator about any warning issued in the message. ... |
| 10.08.2004, 14:13 |
start [/forum/topic.php?desktop=1&fid=55&tid=2014298]: |
159ms |
39ms |
| others: | 212ms |
| total: | 457ms |
