os_create_region: can't allocate 45582336 bytes
решил поставиь бесплатную версию на SESE 9.1, удалось запустить централ. там пытаюсь создать инстанс. он спрашивает master/sybsestemprocs device path - я так понял я должен создать для этого сам файл ? создал ручками файл в лог свалилось такое: 00:00000:00000:2004/09/11 23:29:02.79 kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). 00:00000:00000:2004/09/11 23:29:03.08 kernel Using config area from primary master device. 00:00000:00000:2004/09/11 23:29:03.08 server Configuration Error: Configuration file, '/opt/sybase/brisk.cfg', does not exist. 00:00000:00000:2004/09/11 23:29:03.10 kernel Warning: A configuration file was not specified and the default file '/opt/sybase/brisk.cfg' does not exist. SQL Server creates the default file with the default configuration. 00:00000:00000:2004/09/11 23:29:03.14 kernel Warning: Using default file '/opt/sybase/brisk.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 00:00000:00000:2004/09/11 23:29:03.19 kernel os_create_region: can't allocate 45582336 bytes 00:00000:00000:2004/09/11 23:29:03.19 kernel kbcreate: couldn't create kernel region. 00:00000:00000:2004/09/11 23:29:03.19 kernel kistartup: could not create shared memory 00:00000:00000:2004/09/11 23:29:03.31 kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). 00:00000:00000:2004/09/11 23:29:03.31 kernel The configuration area in device '/opt/sybase/data/brisk.dbf' appears to be corrupt. The server needs this data to boot, and so cannot continue. The server will shut down. ... |
| 12.09.2004, 00:56 |
start [/forum/topic.php?desktop=1&fid=55&tid=2014234]: |
163ms |
| others: | 213ms |
| total: | 431ms |
