аудит sybase ase 12.0 виндовс
читаю как инсталлить The $SYBASE/scripts directory contains installsecurity, a script for installing auditing. To use installsecurity to install auditing: 1. Create the auditing devices and auditing database with the Transact-SQL disk init and create database commands. For example: disk init name = "auditdev", physname = "/dev/dsk/c2d0s4", vdevno = 3, size = 5120 disk init name = "auditlogdev", physname = “/dev/dsk/c2d0s5”, vdevno = 4, size = 1024 create database sybsecurity on auditdev log on auditlogdev 2. Use isql to execute the installsecurity script: cd $SYBASE/scripts setenv DSQUERY server_name isql -Usa - Ppassword - Sserver_name < installsecurity 3. Shut down and restart Adaptive Server. нет у меня такого скрипта installsecurity, откуда его можно взять? ... |
| 19.01.2005, 17:37 |
instsecu он называется ... |
| 20.01.2005, 11:28 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013956]: |
160ms |
30ms |
| others: | 235ms |
| total: | 464ms |
