Replication Server
Господа, подскажите, где можно "достать" Replication Server. Очень Хочется попробовать что это такое. ... |
| 04.04.2005, 13:02 |
Replication Server
Sybase CIS обращайся... ... |
| 04.04.2005, 14:49 |
Replication Server
MasterZivSybase CIS обращайся... Как-то дороговато... ... |
| 05.04.2005, 08:43 |
Replication Server
Скоро можно будет поиграться: Replication Server & Replication Manager Plug-in Version 15.0 Beta Release We are looking to add a few more existing Replication Server customers to the 15.0 Beta Program. The Beta release will include both the Replication Server and a new version of the Replication Manager Plug-in (RMP) for Sybase Central. The Beta program will run for eight weeks starting with a kick off conference call and software download on May 5, 2005. The Beta will be engineering supported. Each Beta customer will be assigned a Sybase engineer for direct communications, as well as given direct access to the RS 15.0 feature developers for questions and comments about the new features. Weekly conference calls have been scheduled running from May 5, 2005 - June 28, 2005. If you are interested in joining this Beta Program, please send an email to Chris Huston before May 1, 2005. You will be contacted with further details about the Beta in the coming weeks. New Replication Server features included in the 15.0 Beta release are: Embedded RSSD Routing - Adds full support of routes to any 15.0 Replication Server with an Embedded RSSD(ERSSD). 12.6 Replication Servers with an ERSSD were unable to be the source of any route, this limitation has been removed in 15.0. The 15.0 Replication Server controls the ASA dbltm, including configuration and process control. This added functionality enriches the ERSSD feature by removing all limitations and differences between a traditional RSSD(on ASE) and an eRSSD. New 15.0 ASE datatyes - UniText, 64-Bit Integer SQL Data Type( signed & unsigned) - These new datatypes in ASE 15.0 are supported in Replication Server 15.0 as well. UniText expands ASE's Unicode capabilities by providing UNITEXT datatype support along with the existing UNICHAR and UNIVARCHAR datatypes. The 64-Bit Integer SQL Datatype provides efficient handling of values up to 9.22 x 10e18. Large Identifiers - Provides increased naming flexibility in single and multi-byte character set environments by expanding most identifier names from 30 bytes to 255 bytes, including replication definitions, subscriptions, articles, publications, etc. ASE 15.0 supports large identifiers for tables, columns, indexes, views, stored procedures, variables, and datatypes. Computed columns - Supports ASE 15.0 new functionality used to define columns in respect to a regular expression using data in the table. RS 15.0 will replicated "materialized" computed columns. Larger Replication Server partition support - The maximum size of an Replication Server 15.0 partition has been expanded to 1 Terabyte. This feature will assist customers who have high data volume and periods of non-connected replicate databases. FIPS 140-2 Security Algorithm - 15.0 Replication Server used a FIPS 140-2 approved security algorithm for encryption of passwords on the network and in the RS configuration file. FIPS 140-2 Compliant SSL Support - updated SSL libraries are now compliant with the FIPS 140-2 standard. The Replication Manager Plug-in (RMP) for Sybase Central Java Edition enhances the original Java plug-in delivered with Replication Server 12.6. The new features available in the 15.0 Beta are: Replication environment monitoring - The RMP monitors the status of the servers, connections, routes, and queues in a replication environment. The RMP graphically displays status on the Sybase Central desktop and reports any change of status in the new event log panel. Manage Replication Objects - The RMP now manages many additional objects in a replication environment including logical connections, routes, queues, table replication definitions, and table subscriptions. The RMP can aid users when implementing complex replication configuration such as adding a database replication definition to a logical connection. Troubleshooting tools - The RMP provides the ability to view the Replication Server's exception log, edit skipped transactions, and re-submit them to the replicate data server. The RMP also provides the ability to view Replication Server internal thread data and view the data in the Replication Server's queues. I'd like to thank you for you interest in Sybase Replication Server 15.0 and look forward to working with you over the next few months. Chris Huston Replication Server Eng Manager Sybase, Inc. ... |
| 15.04.2005, 09:03 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013702]: |
146ms |
54ms |
| others: | 256ms |
| total: | 504ms |
