FC3+ASE:Маленькие открытия каждый день
Tue Aug 16 18:07:40 2005: srvbuild/12.5.2/P/Linux Intel/Linux 2.4.18-18.7.xsmp i686/EBF 11799/OPT/Fri Mar 26 15:52:13 PST 2004 Tue Aug 16 18:07:40 2005: Getting attribute values from sybinit resource file `/opt/sybase/ASE-12_5/sqlsrv.res'. Tue Aug 16 18:07:40 2005: type = 1 server_page_size = 2k master_device_physical_name = /opt/sybase/data/master.dat master_device_size = 30 master_database_size = 6 sybsystemprocs_device_physical_name = /opt/sybase/data/sysprocs.dat sybsystemprocs_device_size = 120 sybsystemprocs_database_size = 120 errorlog = /opt/sybase/ASE-12_5/install/PARMA.log configfile = /opt/sybase/ASE-12_5/PARMA.cfg sybsystemdb_device_physical_name = sybsystemdb_device_size = 5 sybsystemdb_database_size = 5 shmem = /opt/sybase/ASE-12_5 default_backup_server = PARMA_BS server_name = PARMA force_buildmaster = yes Tue Aug 16 18:07:40 2005: (Shell command) /opt/sybase/ASE-12_5/bin/dataserver -d/opt/sybase/data/master.dat -b30M -z2k -sPARMA -e/opt/sybase/ASE-12_5/install/PARMA.log -T1623 -f > /tmp/sb0hEmJb 2>&1 dataserver: master device size for this server: 30.0 Mb dataserver: master database size for this server: 6.0 Mb dataserver: model database size for this server: 2.0 Mb 00:00000:00000:2005/08/16 18:07:41.02 kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). 00:00000:00000:2005/08/16 18:07:41.21 kernel Using config area from primary master device. 00:00000:00000:2005/08/16 18:07:41.21 server Configuration Error: Configuration file, '/opt/sybase/PARMA.cfg', does not exist. 00:00000:00000:2005/08/16 18:07:41.22 kernel Warning: A configuration file was not specified and the default file '/opt/sybase/PARMA.cfg' does not exist. SQL Server creates the default file with the default configuration. 00:00000:00000:2005/08/16 18:07:41.24 kernel Warning: Using default file '/opt/sybase/PARMA.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 00:00000:00000:2005/08/16 18:07:41.27 kernel os_create_region: can't allocate 42510336 bytes 00:00000:00000:2005/08/16 18:07:41.27 kernel kbcreate: couldn't create kernel region. 00:00000:00000:2005/08/16 18:07:41.27 kernel kistartup: could not create shared memory Tue Aug 16 18:07:41 2005: Buildmaster return code: 0. Tue Aug 16 18:07:41 2005: (Shell command) /opt/sybase/ASE-12_5/bin/dataserver -z2k -d/opt/sybase/data/master.dat -e/opt/sybase/ASE-12_5/install/PARMA.log -c/opt/sybase/ASE-12_5/PARMA.cfg -M/opt/sybase/ASE-12_5 -sPARMA -T1623 > /dev/null 2>&1 Tue Aug 16 18:10:51 2005: Unable to boot server 'PARMA'. ... |
| 16.08.2005, 23:14 |
TRFM до установки а не после ;) Installation Guide Adaptive Server® Enterprise12.5 Linux Pre-installation tasks стр.15 To adjust the shared memory size: # /sbin/sysctl -w kernel.shmmax=nnn where nnn is the new size in bytes (at least 64MB which is 67108864 bytes). и добавь это - "kernel.shmmax=nnn" в файл /etc/sysctl.conf чтобы после перезагрузки действовало ... |
| 17.08.2005, 15:18 |
0rcTRFM до установки а не после ;) Installation Guide Adaptive Server® Enterprise12.5 Linux Pre-installation tasks стр.15 To adjust the shared memory size: # /sbin/sysctl -w kernel.shmmax=nnn where nnn is the new size in bytes (at least 64MB which is 67108864 bytes). и добавь это - "kernel.shmmax=nnn" в файл /etc/sysctl.conf чтобы после перезагрузки действовало Я думал никто не отзовётся, спасибо, завтра посмотрю ... |
| 17.08.2005, 20:11 |
Михаил Михайлович 0rcTRFM до установки а не после ;) Installation Guide Adaptive Server® Enterprise12.5 Linux Pre-installation tasks стр.15 To adjust the shared memory size: # /sbin/sysctl -w kernel.shmmax=nnn where nnn is the new size in bytes (at least 64MB which is 67108864 bytes). и добавь это - "kernel.shmmax=nnn" в файл /etc/sysctl.conf чтобы после перезагрузки действовало Я думал никто не отзовётся, спасибо, завтра посмотрю Дайте ссылку на этот рулез плиз!!! ... |
| 18.08.2005, 11:11 |
Михаил, старайся яснее выражать свои вопросы и просьбы в этом форуме, пожалуйста. ... |
| 18.08.2005, 11:42 |
MasterZivМихаил, старайся яснее выражать свои вопросы и просьбы в этом форуме, пожалуйста. Думаю что если моя фраза не является самодостаточной с точки зрения обрывка произвольно вырванного из общего контекста диалога, то ничего страншнгог в этом нет. Или я не прав? Теперь по поводу ясности мыслей. Сегодня я ломился на www.sybase.ru и www.sybase.com ничего не открывалось - наверно у нас на фирме что то с инетом Мне нужнО руководство (упоминавшееся ранее в беседе) по установке последней версии ASE на Linux. Возможно я плохо искал, возможно я я вобще его самостоятельно не искал (заранее извиняюсь). ... |
| 18.08.2005, 13:10 |
Прикольно, пытаюсь скачать и браузеры как бы зависают ... http://sybooks.sybase.com/aseep1252e.html http://sybooks.sybase.com/asp1250e.html ... |
| 19.08.2005, 02:59 |
Спасибо за советы - заработало! ... |
| 19.08.2005, 12:03 |
Вопрос: гденибудь описаны такие простые вещи как запуск/останов служб ASE for Linux. Я Express Edition этот поставил и смотрю как баран на новые ворота. http://sybooks.sybase.com/ облазил, основные доки взял. Но там такими вопросами вроде и не замарачиваются. А я даже не знаю запущен у меня сервер или нет. ... |
| 20.08.2005, 10:13 |
запуск любого из сервисов Sybase : ./RUN_<servername>& у меня были проблемы с бЫкап-сервером при старте из-под телнета (при закрытии телнета вываливался и сам бЫкап-сервер), потому пользуюсь : nohup ./RUN_<servername>_back& в одной умной книге нашел скрипт для стопа сервера kill `ps -efa | grep dataserver | grep -v grep | awk '{print $2}'` но не думаю что это есть корректный и правильный способ ;) по-моему isql надежнее ;) ... |
| 20.08.2005, 11:11 |
и кстати - для посмотреть запущен или нет наверно вернее чем стандартный ps не найти... но есть шкрипт showserver - показывает только сайбесовые сервисы или вот - то пан сам клЕпал : ps -efa | grep dataserver | grep -v grep | awk '{print $2, $4, $5, $8}' ... |
| 20.08.2005, 11:19 |
....мое ХО в том, что для запуска сервисов таки лучше воспользоваться штатными средствами той операционной системы где он работает, FC если правильно ошибусь System V скрипты... Потому у меня в /etc/rc.d лежит нижеприведенный скрипт... Хотя, останавливаю таки да, через isql.... :) ... |
| 20.08.2005, 19:05 |
g613....мое ХО в том, что для запуска сервисов таки лучше воспользоваться штатными средствами той операционной системы где он работает, FC если правильно ошибусь System V скрипты... Потому у меня в /etc/rc.d лежит нижеприведенный скрипт... Хотя, останавливаю таки да, через isql.... :) ВесЧь ... |
| 20.08.2005, 19:17 |
g613....мое ХО в том, что для запуска сервисов таки лучше воспользоваться штатными средствами той операционной системы где он работает, FC если правильно ошибусь System V скрипты... Потому у меня в /etc/rc.d лежит нижеприведенный скрипт... Хотя, останавливаю таки да, через isql.... :) [root@Gorlach tmp]# sh ./sybase start Starting Sybase ASE Lmgd... Starting Sybase ASE ... RUN_GORLACH RUN_GORLACH_BS RUN_GORLACH_MS [root@Gorlach tmp]# У меня всё нормально ? :)) ... |
| 21.08.2005, 12:48 |
Ставил из под рута, работаю из не же: huting down Sybase ASE configured servers: [FAILED] [root@Gorlach tmp]# sh ./sybase stop Shuting down Sybase ASE configured servers: [FAILED] [root@Gorlach tmp]# sh ./sybase stop Shuting down Sybase ASE configured servers: [FAILED] [root@Gorlach tmp]# sh ./sybase stop Shuting down Sybase ASE configured servers: [FAILED] [root@Gorlach tmp]# sh ./sybase restart ./sybase: line 88: ./sybase: Permission denied ./sybase: line 89: ./sybase: Permission denied [root@Gorlach tmp]# ... |
| 21.08.2005, 12:50 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013453]: |
139ms |
26ms |
| others: | 232ms |
| total: | 424ms |
