А репликация меж 5.05 и 8.02 работает ?
Может я ошибаюсь но пятерка говорит коруптед мессайдж..... ... |
| 31.08.2005, 15:11 |
teplia wrote: > Может я ошибаюсь но пятерка говорит коруптед мессайдж..... А ты делал на ночь RTFM :)? --------------------------------------------------------------------- Compression option Set the level of compression for messages. Values can be from -1 to 9, and have the following meanings: -1 Send messages in Version 5 format. Message Agents (both dbremote and ssremote) from previous versions of SQL Remote cannot read messages sent in Version 6 format. You should ensure that COMPRESSION is set to -1 until all Message Agents in your system are upgraded to Version 6. --------------------------------------------------------------------- Posted via ActualForum NNTP Server 1.3 ... |
| 31.08.2005, 15:17 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013425]: |
321ms |
34ms |
| others: | 202ms |
| total: | 600ms |
