Проблемы при установке ASE 1253 ЕЕ под FC3
В конце установки при запуске сервака вот что происходит 00:00000:00000:2005/09/08 16:21:10.50 kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). 00:00000:00000:2005/09/08 16:21:10.53 kernel Using config area from primary master device. 00:00000:00000:2005/09/08 16:21:10.53 kernel Warning: Using default file '/opt/sybase/PLUS.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 00:00000:00000:2005/09/08 16:21:10.60 kernel os_create_region: can't allocate 50907136 bytes 00:00000:00000:2005/09/08 16:21:10.60 kernel kbcreate: couldn't create kernel region. 00:00000:00000:2005/09/08 16:21:10.60 kernel kistartup: could not create shared memory 00:00000:00000:2005/09/08 16:21:11.62 kernel Adaptive Server Enterprise Express Edition (Limits: 1 Engine, 2GB Memory, 5GB Disk space). 00:00000:00000:2005/09/08 16:21:11.62 kernel The configuration area in device '/opt/sybase/data/master.dat' appears to be corrupt. 00:00000:00000:2005/09/08 16:21:11.62 kernel The configuration area in device '/opt/sybase/data/master.dat' appears to be corrupt. The server cannot continue and will shut down. Как побороть? ... |
| 08.09.2005, 16:08 |
/sbin/sysctl -w kernel.shmmax="1342177280" 1342177280 - по вкусу ? ... |
| 09.09.2005, 11:44 |
thnx. Уже сам нашел ошибку. 2-ой совсем ламерский вопрос - где Central искать и как его запустить? ... |
| 09.09.2005, 13:34 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013399]: |
150ms |
28ms |
| others: | 197ms |
| total: | 410ms |
