Sybase обрывает коннекты пользователей. Если кто знает подскажите из-за чего? ASE 11.9.3
В логах вот что творится!!!! 00:00000:00001:2005/12/23 09:57:36.26 server SQL Server's default sort order is: 00:00000:00001:2005/12/23 09:57:36.26 server 'rusdict_cp1251' (ID = 58) 00:00000:00001:2005/12/23 09:57:36.26 server on top of default character set: 00:00000:00001:2005/12/23 09:57:36.26 server 'cp1251' (ID = 53). 00:00000:00001:2005/12/23 09:57:36.30 server Loaded default Unilib conversion handle. 01:00000:00000:2005/12/23 09:57:36.32 kernel engine 1, os pid 318750 online 00:00000:00009:2005/12/23 10:00:51.69 kernel ubfree: block 0x00000000367fe000 already free 00:00000:00009:2005/12/23 10:00:51.72 server WARNING: memory usage in procedure headers (2) does not match memory usage count in Pss (-10) for server process id 9. 00:00000:00009:2005/12/23 10:11:09.82 kernel ubfree: block 0x0000000036999800 already free 00:00000:00009:2005/12/23 10:11:09.82 kernel ubfree: block 0x000000003699a000 already free 00:00000:00009:2005/12/23 10:11:09.84 server WARNING: memory usage in procedure headers (2) does not match memory usage count in Pss (-10) for server process id 9. 00:00000:00014:2005/12/23 10:13:48.00 kernel current process (0x230023) infected with 11 00:00000:00014:2005/12/23 10:13:48.00 kernel Error at address 0x0000000120373d74 (combuf_reserve) 00:00000:00014:2005/12/23 10:13:48.00 kernel ************************************ 00:00000:00014:2005/12/23 10:13:48.00 kernel SQL causing error : select dateformat from master.dbo.syslanguages where langid = 0 00:00000:00014:2005/12/23 10:13:48.00 kernel ************************************ 00:00000:00014:2005/12/23 10:13:48.00 server SQL Text: select dateformat from master.dbo.syslanguages where langid = 0 00:00000:00014:2005/12/23 10:13:48.00 kernel curdb = 1 pstat = 0x10000 lasterror = 0 00:00000:00014:2005/12/23 10:13:48.00 kernel preverror = 0 transtate = 1 00:00000:00014:2005/12/23 10:13:48.00 kernel curcmd = 0 program = main 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001205d7648 pcstkwalk+0x58() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001205d7498 ucstkgentrace+0x1c8() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001205b0280 ucbacktrace+0xb0() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001200a36cc terminate_process+0x9ac() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001205e5594 kisignal+0x124() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x000003ff800d9cf4 _call_remove_gp_range+0x3fe5fa5cb14() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x000000012035e940 s_compile+0x7f0() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x000000012035e940 s_compile+0x7f0() 00:00000:00014:2005/12/23 10:13:48.00 kernel [Handler pc: 0x0000000120328d70 s_handle installed by the following function:-] 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x0000000120325d38 sequencer+0x978() 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001200cffc8 tdsrecv_language+0x378() 00:00000:00014:2005/12/23 10:13:48.00 kernel [Handler pc: 0x00000001200ed430 hdl_backout installed by the following function:-] 00:00000:00014:2005/12/23 10:13:48.00 kernel [Handler pc: 0x00000001202aea20 ut_handle installed by the following function:-] 00:00000:00014:2005/12/23 10:13:48.00 kernel [Handler pc: 0x00000001202aea20 ut_handle installed by the following function:-] 00:00000:00014:2005/12/23 10:13:48.00 kernel pc: 0x00000001200a973c conn_hdlr+0x214c() 00:00000:00014:2005/12/23 10:13:48.01 kernel end of stack trace, spid 14, kpid 2293795, suid 1 00:00000:00007:2005/12/23 10:14:57.97 kernel current process (0x1a001a) infected with 11 00:00000:00007:2005/12/23 10:14:57.97 kernel Error at address 0x000003ff8020c778 (_call_remove_gp_range) 00:00000:00007:2005/12/23 10:14:57.97 kernel ************************************ 00:00000:00007:2005/12/23 10:14:57.97 kernel SQL causing error : select * from PaymentSystemMessageHeads where OperationReference='GCVP-00015177305' 00:00000:00007:2005/12/23 10:14:57.97 kernel ************************************ 00:00000:00007:2005/12/23 10:14:57.97 server SQL Text: select * from PaymentSystemMessageHeads where OperationReference='GCVP-00015177305' 00:00000:00007:2005/12/23 10:14:57.97 kernel curdb = 6 pstat = 0x10000 lasterror = 0 00:00000:00007:2005/12/23 10:14:57.97 kernel preverror = 0 transtate = 1 00:00000:00007:2005/12/23 10:14:57.97 kernel curcmd = 0 program = SQL_Advantage ... |
| 23.12.2005, 07:29 |
Повидимому, это stack-trace-ы, т.е. баги сервера. Лечение - найти workaround или ставить EBF, если он есть. 11.9 уже давно "умер", так что новых EBF не будет, если только старые какие-то, которых у вас нет. ... |
| 23.12.2005, 10:45 |
MasterZiv wrote: > Повидимому, это stack-trace-ы, т.е. баги сервера. А подпорченная БД не может давать такой эффект? Posted via ActualForum NNTP Server 1.3 ... |
| 23.12.2005, 10:57 |
Dim2000 MasterZiv wrote: > Повидимому, это stack-trace-ы, т.е. баги сервера. А подпорченная БД не может давать такой эффект? Posted via ActualForum NNTP Server 1.3 а чем она "подпорчена" ? может снять дамп и проверить её просто ? не, стектрейсы - это проблемы сервера ... select @@version что выдает? ... |
| 23.12.2005, 11:19 |
Dim2000 А подпорченная БД не может давать такой эффект? Конечно, может. Но это не означает однозначно, что в базе ошибка. ... |
| 23.12.2005, 20:36 |
С базой все в порядке. После анализа стало известно что сервер начинает обрывать коннекты после того как ставится процедура на сервер, причем не любая а определенная с кривым update-том. Спасибо за ответы. ... |
| 26.12.2005, 13:38 |
start [/forum/topic.php?desktop=1&fid=55&tid=2013161]: |
188ms |
45ms |
| others: | 244ms |
| total: | 528ms |
