Problema s peremennoy v cursor
SYBASE ASE 12.5 Y mena problema , pri opredelenii kyrsora , procedura otkazyvaetsa kompelirovatsa Smysl procedyry byl pokazyavat ascii znacheniya pola kak fynkzia DUMP v Oarcle ---Text procedyry--- create procedure chardump @colname varchar(30) ='oleg', @tblname varchar(30) ='oleg' as begin declare @cplace int,@clength integer,@str varchar (7999) declare @nn varchar(255),@test varchar(255) declare cur cursor for select @colname from =@tblname open cur fetch cur into @nn while @@sqlstatus=0 begin select @cplace=1 select @clength = char_length(@nn) select @str=convert(varchar(4),ascii(substring(@nn,1,1))) while @clength>=@cplace begin select @cplace=@cplace+1 select @str=@str+','+convert(varchar(4),ascii(substring(@nn,@cplace,1))) end print @str fetch cur into @nn end close cur deallocate cursor cur end Oshibka: Incorrect syntax near '@tblname' Ya sdelal probnyu prozedyry: --Tekst probnika-- create procedure a1 @tblname varchar(20)='oleg' as begin select name from @tblname select 1 end Oshibka: Incorrect syntax near '@tblname' Y kogo kakie idei est , bydy ochen blagodaren . Spasibo za pomosh ... |
| 17.04.2006, 13:18 |
нельзя во фром подставлять переменную. вот вариант (обычно все клиенты выводят binary в виде hex-ов): isql: Код: plaintext 1. 2. 3. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. ... |
| 17.04.2006, 14:09 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012908]: |
153ms |
26ms |
| others: | 259ms |
| total: | 470ms |
