tuning your Network I/O sub-system.
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. Долго читал маны, так ничего не понял. Подскажите что крутить? ... |
| 18.05.2006, 13:30 |
ВигвамTask Management per sec per xact count % of total --------------------------- ------------ ------------ ---------- ---------- Connections Opened 0.0 0.0 25 n/a Task Context Switches by Engine Engine 0 34.6 3.7 31163 44.7 % Engine 1 13.5 1.4 12126 17.4 % Engine 2 19.9 2.1 17903 25.7 % Engine 3 9.4 1.0 8455 12.1 % ------------------------- ------------ ------------ ---------- Total Task Switches: 77.4 8.2 69647 Task Context Switches Due To: Voluntary Yields 14.0 1.5 12583 18.1 % Cache Search Misses 9.3 1.0 8361 12.0 % System Disk Writes 0.3 0.0 226 0.3 % I/O Pacing 3.4 0.4 3024 4.3 % Logical Lock Contention 0.0 0.0 44 0.1 % Address Lock Contention 0.0 0.0 0 0.0 % Latch Contention 0.0 0.0 2 0.0 % Log Semaphore Contention 0.0 0.0 27 0.0 % PLC Lock Contention 0.0 0.0 0 0.0 % Group Commit Sleeps 0.1 0.0 133 0.2 % Last Log Page Writes 9.6 1.0 8631 12.4 % Modify Conflicts 0.1 0.0 100 0.1 % I/O Device Contention 0.0 0.0 0 0.0 % Network Packet Received 10.3 1.1 9290 13.3 % Network Packet Sent 62.9 6.7 56623 81.3 % Other Causes -32.7 -3.5 -29397 -42.2 % Tuning Recommendations for Task Management ------------------------------------------ - Consider tuning your Network I/O sub-system. =============================================================================== Network I/O Management ---------------------- Total Network I/O Requests 20.0 2.1 17957 n/a Network I/Os Delayed 0.0 0.0 0 0.0 % Total TDS Packets Received per sec per xact count % of total ------------------------- ------------ ------------ ---------- ---------- Engine 0 6.5 0.7 5808 62.5 % Engine 1 1.5 0.2 1306 14.1 % Engine 2 1.4 0.2 1288 13.9 % Engine 3 1.0 0.1 888 9.6 % ------------------------- ------------ ------------ ---------- Total TDS Packets Rec'd 10.3 1.1 9290 Total Bytes Received per sec per xact count % of total ------------------------- ------------ ------------ ---------- ---------- Engine 0 1011.1 107.6 909997 70.5 % Engine 1 160.8 17.1 144726 11.2 % Engine 2 164.3 17.5 147825 11.5 % Engine 3 97.4 10.4 87658 6.8 % ------------------------- ------------ ------------ ---------- Total Bytes Rec'd 1433.6 152.5 1290206 Avg Bytes Rec'd per Packet n/a n/a 138 n/a ----------------------------------------------------------------------------- Total TDS Packets Sent per sec per xact count % of total ------------------------- ------------ ------------ ---------- ---------- Engine 0 57.2 6.1 51444 90.9 % Engine 1 1.5 0.2 1385 2.4 % Engine 2 1.4 0.2 1296 2.3 % Engine 3 2.8 0.3 2498 4.4 % ------------------------- ------------ ------------ ---------- Total TDS Packets Sent 62.9 6.7 56623 Total Bytes Sent per sec per xact count % of total ------------------------- ------------ ------------ ---------- ---------- Engine 0 26854.6 2856.9 24169154 95.2 % Engine 1 180.6 19.2 162524 0.6 % Engine 2 139.8 14.9 125784 0.5 % Engine 3 1030.0 109.6 926955 3.7 % ------------------------- ------------ ------------ ---------- Total Bytes Sent 28204.9 3000.5 25384417 Avg Bytes Sent per Packet n/a n/a 448 n/a Долго читал маны, так ничего не понял. Подскажите что крутить? Включите буферизацию сетевых пакетов sp_configure "tcp no delay", 0 ... |
| 18.05.2006, 13:40 |
Да стоит. Parameter Name Default Memory Used Config Value Run Value Unit Type -------------- ------- ----------- ------------ --------- ---- ---- tcp no delay 1 0 0 0 switch static ... |
| 18.05.2006, 13:49 |
exec sp_configure network go select network_pktsz, count(spid) from sysprocesses group by network_pktsz go Parameter Name Default Memory Used Config Value Run Value Unit Type -------------- ------- ----------- ------------ --------- ---- ---- additional network memory 0 0 0 0 bytes dynamic default network packet size 512 #621 1024 1024 bytes static max network packet size 512 0 1024 1024 bytes static max number network listeners 5 1085 5 5 number static Network Communication 0 0 0 0 not applicable NULL network_pktsz ------------- ----------- 512 30 1024 12 ... |
| 18.05.2006, 13:51 |
Выключите done_in_proc token при выполнении SP ... |
| 18.05.2006, 13:53 |
тут не понял.. :( ... |
| 18.05.2006, 14:14 |
Вигвамтут не понял.. :( Что бы самому долго не писать: почитайте тут http://www.petersap.nl/index.php?option=com_content&task=view&id=44&Itemid=54&word=sybase ... |
| 18.05.2006, 19:05 |
Господа, пользуйтесь разметкой. Выделяйте URL, исходный код, форматируйте листинги с FIXED. Для вашего и читателей удобства. ... |
| 18.05.2006, 19:24 |
Что-то крутить нужно чтобы чего-то добиться. Ты вот чего хочешь добиться ? Что тебе в этой конфигурации не нравится ? Мне вот так сходу все нравится, загрузка NIO маленькая . А что тебе там warning сунулся - ну понятно, это из-за Network Packet Sent 81.3 % Кстати это может быть и ошибка , видишь отрицательные числа в последней строчке ? Это может быть если очень большой период мониторинга . Ну а так - все, что тебе сказали уже , я еще могу добавить попробовать использовать другие размеры сетевых пакетов по умолчанию (sp_configure) - поставить в два раза больше, посмотреть, если 81.3 % уменьшится, еще в два раза, но в разумных пределах. Вообще там в мониторе есть где-то максимальный размер пакета за период мониторинья. Его можно взять за величину конфиг. параметра, округлив, естественно. Ниже 1024 я думаю размер пакета ставить бессмысленно, но тут зависит все от приложения, от его сетевого обмена. ... |
| 18.05.2006, 19:32 |
1) sp_configure "send doneinproc tokens",0 - сделать не могу. Так как Sybase 12.5.0.3 2) Ну период мониторинга 15мин. Ну если это мало, тогда будем ждать большего. P/S Всем спасибо. ... |
| 19.05.2006, 09:40 |
Вигвам1) sp_configure "send doneinproc tokens",0 - сделать не могу. Так как Sybase 12.5.0.3 Читать надо внимательней How to tune doneinproc for pre 12.5.1 releases For pre-12.5.1 releases of ASE the configuration option has not been implemented. But with the dbcc tune statement you can accomplish the same behaviour dbcc tune(doneinproc,0) switches the doneinproc tokens off for all statements, except for selects. With dbcc tune(doneinproc,1), the default behaviour, you can reset this switch. However, when you reboot Sybase ASE the setting will be reset to 1. This means that when you start ASE a small script should re-execute the dbcc tune statement. ... |
| 19.05.2006, 11:13 |
Вигвам1) 2) Ну период мониторинга 15мин. Ну если это мало, тогда будем ждать большего. У вас и за эти 15 минут произошло переполнение счетчиков. Если такая большая активность на сервере. Так на досуге, посчитайте положительные % в context switches. Получиться 142%. ... |
| 19.05.2006, 11:18 |
moris Вигвам1) 2) Ну период мониторинга 15мин. Ну если это мало, тогда будем ждать большего. У вас и за эти 15 минут произошло переполнение счетчиков. Если такая большая активность на сервере. Так на досуге, посчитайте положительные % в context switches. Получиться 142%. исходя из опыта, особо доверять "рекомендациям" sysmon-а не стоит - бывали случаи когда в одном из 10-минутных мониторингов один из параметров сервер рекомендовал увеличить на 50 мс, а уже в следующем - уменьшить ровно на это эе значение ;) ... |
| 19.05.2006, 19:04 |
1) sp_configure "send doneinproc tokens",0 - сделать не могу. Так как Sybase 12.5.0.3 До появления конфигурационнного параметра существовал аналогичный trace flag. Какой - надо искать в документации или справляться в Sybase. 2) Ну период мониторинга 15мин. Ну если это мало, тогда будем ждать большего. Много, а не мало. Но это не много, значит какая- то еще ошибка. Но отрицательных процентов быть не может. ... |
| 22.05.2006, 10:23 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012852]: |
198ms |
63ms |
| others: | 257ms |
| total: | 571ms |
