Господа, как победить ошибку??? ASE 12.0
03:00000:00103:2006/07/03 13:38:33.78 server Error: 12308, Severity: 21, State: 6 03:00000:00103:2006/07/03 13:38:33.78 server Internal error : Invalid row id (Row 155, Page 544515) encountered in the table 'table1' in the database 'base'. 02:00000:00103:2006/07/03 13:42:31.60 server Error: 12308, Severity: 21, State: 6 02:00000:00103:2006/07/03 13:42:31.60 server Internal error : Invalid row id (Row 130, Page 144014) encountered in the table 'table2' in the database 'base'. что можно предпринять? ошибка обнаружена при DBCC CHECKDB('base') очень слабо представляю sybase... поможите пожалуйста... ... |
| 03.07.2006, 13:46 |
Затем пишет следующее 02:00000:00103:2006/07/03 13:42:54.67 server Starting diagnostics for read failure: 02:00000:00103:2006/07/03 13:42:54.67 server Device Information: Device number = 112 Phyname = D:\Devices\vils_dat_03.dat 02:00000:00103:2006/07/03 13:42:54.67 server Buffer Information: Buf addr = 0x4F89C8E8, Mass addr = 0x4F89C8E8 Buf pageno = 257390, Mass pageno = 257390, dbid = 19 02:00000:00103:2006/07/03 13:42:54.67 server Buf virtpg = 1879100782, Mass virtpg = 1879100782 Buf stat = 0x1, Mass stat = 0x44001008 Mass keep = 1, Mass awaited = 0 02:00000:00103:2006/07/03 13:42:54.67 server Page Information from first read attempt: Page read from cache ppageno = 257390, pobjid = 1319675749, pindid = 13 pnextpg = 238918, pprevpg = 238870 plevel = 0, pstat = 0x802 pts_hi = 1, pts_lo = 118843414 02:00000:00103:2006/07/03 13:42:54.67 server Page Information from second read attempt: Page read from disk ppageno = 257390, pobjid = 1319675749, pindid = 13 pnextpg = 238918, pprevpg = 238870 plevel = 0, pstat = 0x802 pts_hi = 1, pts_lo = 118843414 02:00000:00103:2006/07/03 13:42:54.67 server SDES Information: dbid = 19, objid = 1650104919, scur.pageid = 257390 sstat = 0x0, sstat2 = 0x800 suid = 1, cacheid = 0 02:00000:00103:2006/07/03 13:42:54.67 server PSS Information: pstat = 0x10000, pcurdb = 19, pspid = 103 p2stat = 0x1000, p3stat = 0x81a plasterror = 9999, preverror = 0, pattention = 0 02:00000:00103:2006/07/03 13:42:54.68 server End diagnostics for read failure: 02:00000:00103:2006/07/03 13:42:54.68 server Run the DBCC command 'dbcc tablealloc' for both the objects 1650104919, 1319675749 ... |
| 03.07.2006, 13:51 |
http://search.sybase.com/search/simple.do?keyword=12308&Submit.x=13&Submit.y=9 если кто-то имеет доступ - расскажите о чем пишут... пожалуйста ... |
| 03.07.2006, 14:48 |
как решаю проблему! при чекании базы артизан пишет какие индексы нужно удалить и создать заново, так и сделал ... |
| 03.07.2006, 15:35 |
но, при повторноых проверках опять появляются ошибки но уже на других индексах... что может быть, почему сыпание такое происходит, я в растерянности... ... |
| 03.07.2006, 15:36 |
start [/forum/search_topic.php?author=hsadik&author_mode=last_posts&do_search=1]: |
148ms |
30ms |
| others: | 693ms |
| total: | 925ms |
