Упал сервак ASE 12.5.0.3 и подыматься не хочет.
Всем добрый день. Беда НЕ СТАРТУЕТ Adaptive Server Enterprise/12.5.0.3/EBF 11449 ESD Сервер умер после сбоя по питанию - у UPS(а) кончались батарейки :( Sybase SQLServer стартует уже около часа.... :( без результатно. Поднять бэкапа не поможет т.к. нужен именно один вчерашний день, а умер он вечером. В логе после слова 'Initializing MSDTC Connection' тишина. Есть идеи? 2006/08/23 09:13:50.17 kernel Use license file c:\sybase\SYSAM-1_0\licenses\license.dat. 2006/08/23 09:13:50.21 kernel Checked out license ASE_SERVER 2006/08/23 09:13:50.21 kernel Adaptive Server Enterprise Edition 2006/08/23 09:13:50.25 kernel Using config area from primary master device. 2006/08/23 09:13:50.25 kernel Warning: Using default file 'c:\sybase\mandrake.cfg' since a configuration file was not specified. Specify a configuration file name in the RUNSERVER file to avoid this message. 2006/08/23 09:13:51.07 kernel Using 100000 file descriptors. 2006/08/23 09:13:51.17 kernel Adaptive Server Enterprise/12.5.0.3/EBF 11449 ESD#4/P/NT (IX86)/OS 4.0/rel12503/1939/32-bit/OPT/Sat Sep 20 22:28:57 2003 2006/08/23 09:13:51.17 kernel Confidential property of Sybase, Inc. 2006/08/23 09:13:51.17 kernel Copyright 1987, 2003 2006/08/23 09:13:51.17 kernel Sybase, Inc. All rights reserved. 2006/08/23 09:13:51.17 kernel Unpublished rights reserved under U.S. copyright laws. 2006/08/23 09:13:51.17 kernel 2006/08/23 09:13:51.17 kernel This software contains confidential and trade secret information of Sybase, 2006/08/23 09:13:51.17 kernel Inc. Use, duplication or disclosure of the software and documentation by 2006/08/23 09:13:51.17 kernel the U.S. Government is subject to restrictions set forth in a license 2006/08/23 09:13:51.17 kernel agreement between the Government and Sybase, Inc. or other written 2006/08/23 09:13:51.17 kernel agreement specifying the Government's rights to use the software and any 2006/08/23 09:13:51.17 kernel applicable FAR provisions, for example, FAR 52.227-19. 2006/08/23 09:13:51.17 kernel Sybase, Inc. One Sybase Drive, Dublin, CA 94568, USA 2006/08/23 09:13:51.17 kernel Using 'c:\sybase\mandrake.cfg' for configuration information. 2006/08/23 09:13:51.17 kernel Logging ASE messages in file 'c:\sybase\ASE-12_5\install\errorlog'. 2006/08/23 09:13:51.54 kernel Initializing MSDTC Connection ... |
| 23.08.2006, 10:05 |
Event Viewer Тип события: Уведомление Источник события: MSDTC Категория события: TM Код события: 4097 Дата: 08.22.2006 Время: 6:34:00 PM Пользователь: Н/Д Компьютер: MANDRAKE Описание: Выполнен запуск MS DTC со следующими настройками. Настройки безопасности (OFF = 0, ON = 1): Сетевое администрирование транзакций = 0, Сетевые клиенты = 0, Распределенные транзакции через внутренний протокол MSDTC = 0, Протокол TIP = 0, Транзакции XA = 1. Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp". Тип события: Ошибка Источник события: MSDTC Категория события: SVC Код события: 4437 Дата: 08.22.2006 Время: 6:33:59 PM Пользователь: Н/Д Компьютер: MANDRAKE Описание: Служба MS DTC выполняется под недопустимой учетной записью. Возможно, данные учетной записи службы были изменены с помощью оснастки служб в консоли управления Microsoft (MMC). Запуск службы MS DTC продолжится. С помощью проводника служб компонентов убедитесь, что данные учетной записи для службы MS DTC обновлены. Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp". ... |
| 23.08.2006, 10:16 |
а службы DTC запущена? попробуйте просто ее запустить net start msdtc ... |
| 23.08.2006, 10:33 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012647]: |
155ms |
| others: | 234ms |
| total: | 448ms |
