Installation system
Hi gurus, Does somebody could point me to the direction where I could find some installation system like InstallShield (or at least set of good shell/perl scripts) intended for installing/copying db through DDL scripts (like wrapper for SQL scripts already prepared manually/by ddlgen/3rd party tools with couple of parameters like clientname, servername, dbname, clientname, user, pwd, etc) + bcpying data (everything under Unix). The source and target servers should not be connected at all. It is like fresh installation on the client site. I am currently using my own, but would like to take a look on maybe something better. Regards, Eugene ... |
| 13.09.2006, 20:39 |
Installation system
Официальный язык сообщений на форумах SQL.RU - Русский. Убедительная просьба не нарушать правила, тем паче, что даже если нет русской клавиатуры, внизу на форме ввода сообщения находится ссылочка на виртуальную клавиатуру. ... |
| 14.09.2006, 07:52 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012591]: |
151ms |
42ms |
| others: | 213ms |
| total: | 446ms |
