ASE 12.5 Жрет всю память .. в чем дело ? HELP
| 01.12.2006, 13:47 |
голодный видимо... ... |
| 01.12.2006, 13:59 |
maxilink Код: plaintext 1. 2. 3. 4. 5. 6. 7. в студию ... |
| 01.12.2006, 16:51 |
1> select @@version 2> go --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Adaptive Server Enterprise/12.5.2/EBF 12061 ESD#2/P/Linux Intel/Enterprise Linu x/ase1252/1844/32-bit/OPT/Wed Aug 11 21:36:26 2004 (1 row affected) maximum failed logins 0 0 0 0 number dynamic maximum job output 32768 0 32768 32768 bytes dynamic memory alignment boundary 2048 0 2048 2048 bytes static memory per worker process 1024 4 1024 1024 bytes dynamic Memory Use 0 0 0 0 not applicable NULL messaging memory 400 0 400 400 memory pages(2k) dynamic Meta-Data Caches 0 0 0 0 not applicable NULL minimum password length 6 0 6 6 bytes dynamic Monitoring 0 0 0 0 not applicable NULL msg confidentiality reqd 0 0 0 0 switch dynamic msg integrity reqd 0 0 0 0 switch dynamic Network Communication 0 0 0 0 not applicable NULL number of alarms 40 4 40 40 number dynamic number of aux scan descriptors 200 #232 200 200 number dynamic number of ccbs 0 0 0 0 number static number of checkpoint tasks 1 0 1 1 number dynamic number of devices 10 #10 10 10 number dynamic number of dtx participants 500 146 500 500 number dynamic number of dump threads 1 0 1 1 number dynamic number of engines at startup 1 0 2 2 number static number of histogram steps 20 0 20 20 number dynamic number of index trips 0 0 0 0 number dynamic number of java sockets 0 0 0 0 number dynamic number of large i/o buffers 6 3112 6 6 number dynamic number of locks 5000 7080 50000 50000 number dynamic number of mailboxes 30 6 30 30 number dynamic number of messages 64 6 64 64 number dynamic number of oam trips 0 0 0 0 number dynamic number of open databases 12 1416 12 12 number dynamic number of open indexes 500 592 500 500 number dynamic number of open objects 500 7105 5000 5000 number dynamic number of pre-allocated extent 2 0 2 2 number dynamic number of remote connections 20 33 20 20 number static number of remote logins 20 22 20 20 number static number of remote sites 10 1564 10 10 number static number of sort buffers 500 0 500 500 number dynamic number of user connections 25 3905 25 25 number dynamic number of worker processes 0 0 0 0 number dynamic o/s file descriptors 0 0 0 1024 number read-only O/S Resources 0 0 0 0 not applicable NULL object lockwait timing 0 0 0 0 switch dynamic open index hash spinlock ratio 100 0 100 100 ratio dynamic open index spinlock ratio 100 0 100 100 ratio dynamic open object spinlock ratio 100 0 100 100 ratio dynamic page lock promotion HWM 200 0 200 200 number dynamic page lock promotion LWM 200 0 200 200 number dynamic page lock promotion PCT 100 0 100 100 percent dynamic page utilization percent 95 0 95 95 percent dynamic Parallel Query 0 0 0 0 not applicable NULL partition groups 1024 860 1024 1024 number dynamic partition spinlock ratio 10 0 10 10 ratio dynamic per object statistics active 0 0 0 0 switch dynamic percent database for history 20 0 20 20 percent dynamic percent database for output 30 0 30 30 percent dynamic percent history free 30 0 30 30 percent dynamic percent output free 50 0 50 50 percent dynamic performance monitoring option 0 0 0 0 switch dynamic permission cache entries 15 #178 15 15 number dynamic Physical Memory 0 0 0 0 not applicable NULL Physical Resources 0 0 0 0 not applicable NULL plan text pipe active 0 0 0 0 switch dynamic plan text pipe max messages 0 0 0 0 number dynamic print deadlock information 0 0 0 0 switch dynamic print recovery information 0 0 0 0 switch dynamic procedure cache size 3271 69246 32710 32710 memory pages(2k) dynamic process wait events 0 0 0 0 switch dynamic Processors 0 0 0 0 not applicable NULL read committed with lock 0 0 0 0 switch dynamic recovery interval in minutes 5 0 5 5 minutes dynamic remote server pre-read packets 3 #32 3 3 number static Rep Agent Thread Administratio 0 0 0 0 not applicable NULL row lock promotion HWM 200 0 200 200 number dynamic row lock promotion LWM 200 0 200 200 number dynamic row lock promotion PCT 100 0 100 100 percent dynamic runnable process search count 2000 0 2000 2000 number dynamic sampling percent 0 0 10 10 percent dynamic secure default login guest 0 guest guest not applicable dynamic Security Related 0 0 0 0 not applicable NULL select on syscomments.text 1 0 1 1 switch dynamic send doneinproc tokens 1 0 1 1 switch dynamic shared memory starting address 0 0 0 0 not applicable static size of auto identity column 10 0 10 10 bytes dynamic size of global fixed heap 150 0 150 150 memory pages(2k) dynamic size of process object heap 1500 0 1500 1500 memory pages(2k) dynamic size of shared class heap 1536 0 1536 1536 memory pages(2k) dynamic size of unilib cache 0 120 0 0 bytes dynamic SQL batch capture 0 0 0 0 switch dynamic SQL Perfmon Integration 1 0 1 1 switch static SQL Server Administration 0 0 0 0 not applicable NULL sql server clock tick length 100000 0 100000 100000 microseconds static sql text pipe active 0 0 0 0 switch dynamic sql text pipe max messages 0 0 0 0 number dynamic stack guard size 4096 #280 4096 4096 bytes static stack size 61440 #4200 61440 61440 bytes static start mail session 0 0 0 0 switch dynamic statement cache size 0 0 0 0 memory pages(2k) dynamic statement pipe active 0 0 0 0 switch dynamic statement pipe max messages 0 0 0 0 number dynamic statement statistics active 0 0 0 0 switch dynamic strict dtm enforcement 0 0 0 0 switch static suspend audit when device full 1 0 1 1 switch dynamic syb_sendmsg port number 0 0 0 0 id static systemwide password expiration 0 0 0 0 days dynamic tape retention in days 0 0 0 0 days dynamic tcp no delay 1 0 1 1 switch static text prefetch size 16 0 16 16 logical pages dynamic time slice 100 0 100 100 milliseconds dynamic total data cache size 0 8742 0 8742 kilobytes read-only total logical memory 32768 116712 58356 58356 memory pages(2k) read-only total physical memory 0 116712 0 58356 memory pages(2k) read-only txn to pss ratio 16 764 16 16 number dynamic Unicode 0 0 0 0 not applicable NULL unified login required 0 0 0 0 switch dynamic upgrade version 12500 0 12500 12500 id dynamic use security services 0 0 0 0 switch static User Environment 0 0 0 0 not applicable NULL user log cache size 2048 0 2048 2048 bytes static user log cache spinlock ratio 20 0 20 20 ratio dynamic wait event timing 0 0 0 0 switch dynamic xact coordination interval 60 0 60 60 seconds dynamic xp_cmdshell context 1 0 1 1 switch dynamic (1 row affected) (return status = 0) 1> sp_helpcache 2> go Cache Name Config Size Run Size Overhead ------------------------ ------------- ---------- ---------- default data cache 0.00 Mb 8.00 Mb 0.54 Mb Memory Available For Memory Configured Named Caches To Named Caches -------------------- ---------------- 8.01 Mb 0.00 Mb ------------------ Cache Binding Information: ------------------ Cache Name Entity Name Type Index Name Status ---------- ----------- ---- ---------- ------ (return status = 0) 1> sp_cacheconfig 2> go Cache Name Status Type Config Value Run Value ------------------------------ --------- -------- ------------ ------------ default data cache Active Default 0.00 Mb 8.00 Mb ------------ ------------ Total 0.00 Mb 8.00 Mb ========================================================================== Cache: default data cache, Status: Active, Type: Default Config Size: 0.00 Mb, Run Size: 8.00 Mb Config Replacement: strict LRU, Run Replacement: strict LRU Config Partition: 1, Run Partition: 1 IO Size Wash Size Config Size Run Size APF Percent -------- --------- ------------ ------------ ----------- 2 Kb 1638 Kb 0.00 Mb 8.00 Mb 10 (return status = 0) ... |
| 01.12.2006, 22:41 |
Непонимаю - что за постановка вопроса - "ASE 12.5 Жрет всю память .. в чем дело ? " На такой вопрос только один ответ - см. пост номер 2 от гостя Лень Можете объяснить свою проблему более детальней ? Что значит "жрет" ??? На уровне ОS ??? т.е. процесс ASE забирает всю доступную память? Или же на уровне самого ASE используется вся доступная память (вплоть до max memory)?? По поводу уровня ASE - вас попросили прислать конфигурацию, а вы прислали только половину конфигурационных параметров??? Что первая половина вы считаете не важна?? Ну даже и из половины параметров видно что - используется только дефолтный кеш размером, с дефолтным же размером - аж 8 Мб !!! - ASE сумарно использует только 116 Mb ... |
| 03.12.2006, 00:57 |
Дело в том . .что я сам совсем новичок в этом деле.. АСЕ поставил по руководству моего софта , который будет использоват его. просто у меня этот софт пишет что с 1000МБ рам памяти фрии 100мб но это не постоянно, обычно фрии рам у меня 700 750 мб ... |
| 03.12.2006, 02:47 |
maxilink просто у меня этот софт пишет что с 1000МБ рам памяти фрии 100мб Прямо как в "Гараже": - Товарищи, предложение Аникеевой хорошее. Значит так, двое блатных, дочка профессора, и кто там четвертый? этот, как его... Гуськов! Точно, Гуськов, он для этого годится! - Как Гуськов? Опять Гуськов?! Почему Гуськов??! - Должен же быть кто-то четвертым! В вашем случае Гуськов - это ASE, - " он для этого годится!" :-) тем более - "Должен же быть кто-то крайним" Во первых - надо доверять показанием команд OS , а не тому что пишет ваш софт, касательно FREE RAM А во - вторых для UNIX OS, в том числе и для Linux, есть такое понятие как фаловый кеш (А если у вас например еще и Suse, то прочитайте например, что такое Aggressive caching) ... |
| 03.12.2006, 16:27 |
да, хотелось бы посмотреть на Код: plaintext если сервер использует файловые девайсы, и не хочется лазить в sysctl или /proc/sys/vm, колдовать с кешем файловой системы - может стоит перетащить на raw-device ))) ... |
| 04.12.2006, 03:26 |
а точно, не 48 а 116, Код: plaintext 1. 2. ... и куда оно столько его сожрало O_o, точно голодный. ... |
| 04.12.2006, 03:35 |
blzzа точно, не 48 а 116, не заметил =(, у меня свежесозданный сервер обычно вдвое меньше берет. ... и куда оно столько его сожрало O_o, точно голодный. 48Mb по всем дефотлтным установкам + измененный procedure cache size (69246) = 116 Mb ... |
| 04.12.2006, 11:29 |
Дело в том что , он постипенно снижается,, после ребута фрии рам 800 Мб гдето, а потом постепенно снижается,,, как это исправить? 1> sp_configure memory 2> go Msg 17411, Level 16, State 1: Server 'ipsoft', Procedure 'sp_configure', Line 209: Configuration option is not unique. Parameter Name Default Memory Used Config Value Run Value Unit Type ------------------------------ ----------- ----------- ------------ ----------- -------------------- ---------- additional network memory 0 0 0 0 bytes dynamic allocate max shared memory 0 0 0 0 switch dynamic heap memory per user 4096 0 4096 4096 bytes dynamic lock shared memory 0 0 0 0 switch static max memory 32768 1048576 524288 524288 memory pages(2k) dynamic memory alignment boundary 2048 0 2048 2048 bytes static memory per worker process 1024 4 1024 1024 bytes dynamic Memory Use 0 0 0 0 not applicable NULL messaging memory 400 0 400 400 memory pages(2k) dynamic Physical Memory 0 0 0 0 not applicable NULL shared memory starting address 0 0 0 0 not applicable static total logical memory 32768 116712 58356 58356 memory pages(2k) read-only total physical memory 0 116712 0 58356 memory pages(2k) read-only (1 row affected) An additional 931864 K bytes of memory is available for reconfiguration. This is the difference between 'max memory' and 'total logical memory'. (return status = 1) 1> ... |
| 04.12.2006, 22:31 |
строка (1 row affected) An additional 931864 K bytes of memory is available for reconfiguration. This is the difference between 'max memory' and 'total logical memory'. (return status = 1)говорит что серверу отдана память которая не распределена. если в операционке ничего не крутится жрущщего память - задействуй в SQL сервере её. например отдай в кеш данных, 1> sp_cacheconfig 2> go Cache Name Status Type Config Value Run Value ------------------------------ --------- -------- ------------ ------------ default data cache Active Default 0.00 Mb 8.00 Mb ------------ ------------ Total 0.00 Mb 8.00 Mb ========================================================================== Cache: default data cache, Status: Active, Type: Default Config Size: 0.00 Mb, Run Size: 8.00 Mb Config Replacement: strict LRU, Run Replacement: strict LRU Config Partition: 1, Run Partition: 1 IO Size Wash Size Config Size Run Size APF Percent -------- --------- ------------ ------------ ----------- 2 Kb 1638 Kb 0.00 Mb 8.00 Mb 10 (return status = 0) мало! например это увелилчит default data cache до 800мб Код: plaintext 1. за распределение этой памяти в ос при старте сервера отвечает Код: plaintext а также почитать что точно делает Код: plaintext если столкнешься с тем что при старте будет валиться с "cannot create kernel region..." поищи тут как использвался sysctl. или понижай в конфиге кеш и max memory. ... |
| 09.12.2006, 20:39 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012367]: |
167ms |
55ms |
| others: | 240ms |
| total: | 514ms |
