Проблемы при запуске Сервера Репликаций
Проблема возникает при загрузке сервера I. 2007/01/05 14:44:22. Logging messages in file '/usr/sybase/repserver/REP-12_6/install/REPSERVER.log'. I. 2007/01/05 14:44:22. Using interfaces file '/usr/sybase/repserver/interfaces'. I. 2007/01/05 14:44:22. Server name is 'REPSERVER'. W. 2007/01/05 14:44:22. WARNING #18065 GLOBAL RS(GLOBAL RS) - /servapp.c(132) Unable to get message '18065'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) W. 2007/01/05 14:44:22. WARNING #18066 GLOBAL RS(GLOBAL RS) - /servapp.c(138) Unable to get message '18066'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:22. Reading '/usr/sybase/repserver/REP-12_6/install/REPSERVER.cfg' for configuration information. I. 2007/01/05 14:44:22. Using the 'cp1251' character set. I. 2007/01/05 14:44:22. Using the 'us_english' language. I. 2007/01/05 14:44:22. Using the 'binary' sort order. I. 2007/01/05 14:44:22. Unable to get message '18068'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:22. Using server 'REPSERVER' for an ID Server. I. 2007/01/05 14:44:22. Using config file password for the ID user. I. 2007/01/05 14:44:22. Using user 'REPSERVER_id_user' for the ID Server. I. 2007/01/05 14:44:22. Using config file maintenance password for the RSSD maint user. I. 2007/01/05 14:44:23. RSSD maintenace user is 'rssd_maint'. I. 2007/01/05 14:44:23. Using config file password for the RSSD primary user. I. 2007/01/05 14:44:23. RSSD primary user is 'rssd_prim'. I. 2007/01/05 14:44:23. RSSD database is 'rssd'. I. 2007/01/05 14:44:23. RSSD server is 'SQLGNPF02'. I. 2007/01/05 14:44:23. Reading 'SQLGNPF02.rssd..rs_config' for system configuration parameters. I. 2007/01/05 14:44:23. Value of the 'memory_limit' config parameter is: 20 megabytes. I. 2007/01/05 14:44:23. Maximum outbound connections allowed: 64. I. 2007/01/05 14:44:24. System outbound connection fadeout time: '30'. I. 2007/01/05 14:44:24. System table cache size: 100 rows. I. 2007/01/05 14:44:24. Maximum number of Open Server threads allowed: 50. I. 2007/01/05 14:44:24. Maximum number of Open Server mutexes allowed: 1024. I. 2007/01/05 14:44:24. Maximum number of incoming client connections allowed: 30. I. 2007/01/05 14:44:24. Maximum number of Open Server message queues allowed: 178. I. 2007/01/05 14:44:24. Maximum number of Open Server messages allowed: 45568. I. 2007/01/05 14:44:24. Maximum number of stable queues allowed: 32. I. 2007/01/05 14:44:25. Password encryption option: 0. I. 2007/01/05 14:44:25. Unable to get message '31301'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:25. Unable to get message '31273'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:25. Unable to get message '31300'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:25. System configuration complete. I. 2007/01/05 14:44:25. Unable to get message '60044'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(491)) I. 2007/01/05 14:44:26. Server using Open Server version Sybase Server-Library/12.5.1/P/DRV.12.5.1.0/HP Tru64 UNIX/5.0.A Native Threads/BUILD1251-004/OPT/Mon Nov 10 13:28:35 2003 I. 2007/01/05 14:44:26. Server using Open Client version Sybase Client-Library/12.5.1/P/DRV.12.5.1.0/HP Tru64 UNIX/5.0.A Native Threads/BUILD1251-004/OPT/Mon Nov 10 13:25:44 2003 W. 2007/01/05 14:44:26. WARNING #13061 GLOBAL RS(GLOBAL RS) - seful/cm.c(5695) Server SQLGNPF02 is using 'rusdict_cp1251' sort order, which is different from this Replication Server's sort order. I. 2007/01/05 14:44:32. Server site id is '16777317'. I. 2007/01/05 14:44:32. Embedded database id is '101'. I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) I. 2007/01/05 14:44:34. Unable to get message '6198'. (Message not found. Localization File: 251/rs.loc Location: r/errloc.c(683)) после чего сервер падает, может кто встречал такое? ... |
| 05.01.2007, 12:07 |
нет файла rs.loc в кталоге %SYBASE%/locales/us_english/сp1251. Надо скопировать rs.loc из %SYBASE%/locales/us_english/iso_1 Если вообще каталога %SYBASE%/locales/us_english/сp1251 нет, то создайте его и скопируйте все содержимое %SYBASE%/locales/us_english/iso_1 ... |
| 05.01.2007, 13:12 |
Файл в каталоге cp1251 существует. Заменил его на аналогичный из iso_1. Результат тот же. ... |
| 05.01.2007, 13:28 |
start [/forum/topic.php?desktop=1&fid=55&tid=2012320]: |
162ms |
| others: | 241ms |
| total: | 456ms |
