Проблема с подключением к ASA9.0.2 по tcpip
Народ, помогите! Никак не могу подключиться к базе по tcpip, кидает ошибку: Connection error: Found server but communication error occurred. пробовал дебаггить - не нахожу ошибок. Вот лог с сервера: I. 06/29 11:35:56. 1: -x I. 06/29 11:35:56. 2: tcpip(MyIP=192.168.102.10;Broadcast=192.168.102.255;DoBroadcast=YES;LocalOnly=NO;TO=20) I. 06/29 11:35:56. 3: -z I. 06/29 11:35:56. 4: -n I. 06/29 11:35:56. 5: sybase I. 06/29 11:35:56. 6: -o I. 06/29 11:35:56. 7: /opt/sybase/SYBSsa9/dbsrv.log I. 06/29 11:35:56. 8: -ud I. 06/29 11:35:56. 9: asademo.db I. 06/29 11:35:56. I. 06/29 11:35:56. Adaptive Server Anywhere Database Engine Version 9.0.2.2452 I. 06/29 11:35:56. Running on Linux 2.6.21.5 #1 Fri Jun 29 10:25:20 EEST 2007 I. 06/29 11:35:56. 8192K of memory used for caching I. 06/29 11:35:56. Minimum cache size: 8192K, maximum cache size: 262016K I. 06/29 11:35:56. Using a maximum page size of 2048 bytes I. 06/29 11:35:56. Starting database "asademo" (/opt/sybase/SYBSsa9/bin32/asademo.db) at Fri Jun 29 2007 11:35 I. 06/29 11:35:56. Transaction log: asademo.log I. 06/29 11:35:56. Starting checkpoint of "asademo" (asademo.db) at Fri Jun 29 2007 11:35 I. 06/29 11:35:56. Finished checkpoint of "asademo" (asademo.db) at Fri Jun 29 2007 11:35 I. 06/29 11:35:56. Database "asademo" (asademo.db) started at Fri Jun 29 2007 11:35 I. 06/29 11:35:56. Database server started at Fri Jun 29 2007 11:35 I. 06/29 11:35:56. Trying to start SharedMemory link ... I. 06/29 11:35:56. SharedMemory link started successfully I. 06/29 11:35:56. Trying to start TDS (TCPIP) link ... I. 06/29 11:35:56. Starting TCP listener on IP address 192.168.102.10:2638 I. 06/29 11:35:56. Starting on port 2638 I. 06/29 11:35:56. Not performing a broadcast I. 06/29 11:35:56. Starting UDP listener on IP address 0.0.0.0:2638 I. 06/29 11:35:56. TDS (TCPIP) link started successfully I. 06/29 11:35:56. Now accepting requests I. 06/29 11:36:13. TCP/IP: Received connection request from 192.168.6.253:35239. I. 06/29 11:36:23. TCP/IP: Received connection request from 192.168.6.253:35240. А это выдает при попытке "пингать" с клиента: [root@localhost bin]# ./asa_ping.sh Adaptive Server Anywhere Server Ping Utility Version 9.0.2.2452 Application information: "IP=127.0.0.1;HOST=localhost;OS=Linux 2.6.12-3mdksmp #1 SMP Fri Jul 1 13:38:29 CEST 2005;PID=0x1d15;THREAD=0xb7c1a8e0;VERSION=9.0.2.2452;API=DBLIB;TIMEZONEADJUSTMENT=180" Attempting to connect using: UID=dba;PWD=********;ENG=sybase;LINKS=tcpip(host=192.168.102.10;DoBroadcast=NONE;VerifyServerName=NO) Attempting to connect to a running server... Trying to start TCPIP link ... My IP address is 127.0.0.1 My IP address is 127.0.0.1 TCPIP link started successfully Attempting TCPIP connection (address 192.168.102.10:2638 found in .asasrv.ini cache) DoBroadcast=NONE specified, ignoring cached address DoBroadcast=NONE specified, skipping LDAP check Looking for server with name sybase Trying to find server at address 192.168.102.10 Found server, not verifying server name Found database server at address 192.168.102.10:2638 Found database server sybase on TCPIP link Connected to server over TCPIP at address 192.168.102.10:2638 Client disconnected Cannot connect to server Ping database failed -- Connection error: Found server but communication error occurred. Где могут быть грабли? Я уже неделю долблюсь, выручайте... ... |
| 29.06.2007, 12:43 |
Как я понимаю ключевое слово здесь: Adaptive Server Anywhere Database Engine Version ... а должно быть: Adaptive Server Anywhere Network Server Version ... тонкий намек понятен? ... |
| 29.06.2007, 18:19 |
хммм, тонкий намек не понят. есть уже запущенный сервер установленный из этого же дистрибутива. Там все работает... :( ... |
| 01.07.2007, 18:27 |
P3ngu1nхммм, тонкий намек не понят. есть уже запущенный сервер установленный из этого же дистрибутива. Там все работает... :( RTFM dbsrv9, dbeng9 Проверь строку запуска сервера. -- Портал русскоязычной группы пользователей Sybase ... |
| 01.07.2007, 23:53 |
Александр Гoлдун RTFM dbsrv9, dbeng9 Проверь строку запуска сервера. Действительно RTFM... Спасибо!! :)) ... |
| 02.07.2007, 08:55 |
Здравствуйте! Насчет вышесказанного: Указываю в строке параметров executable file c:\program files\sybase\sql anywhere 7\win32\dbsrv7.exe или C:\PROGRAM FILES\SYBASE\SQL ANYWHERE 7\WIN32\DBENG7.EXE но проблема остается - при входе ругается: connection error: Found server but communication error occurred ... |
| 07.08.2007, 12:43 |
start [/forum/topic.php?desktop=1&fid=55&tid=2011976]: |
46ms |
47ms |
| others: | 243ms |
| total: | 386ms |
