ASE 12.5 upyield: scheduler 5242960 trying to yield
Не давно в errorlog(е) начало появляться строка Код: plaintext В гугле так и не нашел что она означает(может плохо искал)! Что это означает может кто подскажет? ... |
| 11.08.2008, 10:46 |
This is CR 339482 (see tips for full description) To avoid the messages in the meantime there are two alterntatives: 1= configure the number of alarms to be up to twice the number of connections that would be logged in at midnight (the function being automatically run appears to grab another alarm before letting go of the one it had) If increasing the number of alarms, make sure you consider the amount of extra memory they will consume. 2=turn off "allow resource limits" using sp_configure. This issue is fixed in the ASE 12.5.2 code line. See http://www.sybase.com/detail?id=1023895 for tentative release schedule. ... |
| 11.08.2008, 11:16 |
start [/forum/topic.php?desktop=1&fid=55&tid=2011444]: |
61ms |
26ms |
| others: | 235ms |
| total: | 365ms |
