Проблема с подключением к сетевому серверу
Sybase ASA 9.0 Следуя советам в http://www.sql.ru/forum/actualthread.aspx?tid=377612 Тестирую коннекшн стринг: dbping -z -d -c "eng=myServer;uid=DBA;pwd=SQL;links=tcpip(PORT=2638;HOST=myServerIp;DOBROADCAST=NONE;VERIFY=NO); ответ дебага (опция -z): Attempting to connect to a running server... Trying to start TCPIP link ... Loading wsock32.dll Loading ws2_32.dll TCP using Winsock version 2.0 My IP address is [myIP] My IP address is 127.0.0.1 TCPIP link started successfully Attempting TCPIP connection (address [myServerIP]:2638 found in asasrv.ini cache) DoBroadcast=NONE specified, ignoring cached address DoBroadcast=NONE specified, skipping LDAP check Looking for server with name [myServer] Trying to find server at address [myServerIP] Found server, not verifying server name Found database server at address [myServerIP]:2638 Found database server [myServer] on TCPIP link Connected to server over TCPIP at address myServerIP]:2638 Client disconnected Cannot connect to server Ping database failed -- Connection error: Found server but communication error occurred. Подскажите, плиз что поправить, чтобы полсоединиться к сетевому Sybase серверу ... |
| 19.08.2008, 15:19 |
start [/forum/topic.php?desktop=1&fid=55&tid=2011426]: |
439ms |
34ms |
| others: | 247ms |
| total: | 759ms |
