Неприятные ошибки
Здравствуйте. ВОзникают ошибки при дампе и не могу разобраться в чем проблема, а т.е: Backup Server: 4.58.1.1: Database data: 47803028 kilobytes DUMPed. Backup Server: 4.58.1.1: Database data: 48358204 kilobytes DUMPed. Backup Server: 4.58.1.1: Database data: 48924822 kilobytes DUMPed. Backup Server: 4.58.1.1: Database data: 49492308 kilobytes DUMPed. Backup Server: 4.58.1.1: Database data: 50059794 kilobytes DUMPed. Backup Server: 4.58.1.1: Database data: 50605898 kilobytes DUMPed. Backup Server: 4.145.2.73: [0] Error for device 'compress::4::/backup/sybase/finist5.dmp::04'. Pipe I/O returned 0 bytes Backup Server Internal Error: 4.62.3.4: Multibuffering subprocesses died, archive compress::4::/backup/sybase/finist5.dmp::04. Backup Server Internal Error: 4.62.3.3: Multibuffering subprocesses died, archive compress::4::/backup/sybase/finist5.dmp::04. Msg 8009, Level 16, State 1: Server 'pnsybase', Line 1: Error encountered by Backup Server. Please refer to Backup Server messages for details. Sep 24 10:41:28 2008 Backup Server: 4.141.2.66: [0] The 'write' call failed for device 'compress::4::/backup/sybase/finist5.dmp::04' with error number 32 (Broken pipe). Refer to your operating system documentation for further details. Sep 24 10:41:28 2008 Backup Server Internal Error: 4.62.3.8: Multibuffering subprocesses died, archive compress::4::/backup/sybase/finist5.dmp::04. Sep 24 10:41:28 2008 Backup Server: 4.82.2.53: Operating system error, server device compress::4::/backup/sybase/finist5.dmp::04: code 0 message ((шЁ3p(H(‡Ё4Ё3. Sep 24 10:41:28 2008 Backup Server: 4.141.2.66: [0] The 'write' call failed for device 'compress::4::/backup/sybase/finist5.dmp::04' with error number 32 (Broken pipe). Refer to your operating system documentation for further details. Sep 24 10:41:28 2008 Backup Server Internal Error: 4.62.3.8: Multibuffering subprocesses died, archive compress::4::/backup/sybase/finist5.dmp::04. …………. В чем может быть загвоздка? ... |
| 25.09.2008, 13:22 |
Неприятные ошибки
Bundesrus В чем может быть загвоздка? например в свободном месте на файловой системе укажите версию ASE ! ... |
| 25.09.2008, 13:30 |
Неприятные ошибки
Свободного места на диске чуть больше 45 гигов. Версия 12-5. ... |
| 25.09.2008, 13:44 |
Неприятные ошибки
BundesrusСвободного места на диске чуть больше 45 гигов. Версия 12-5. а размер БД какой? ... |
| 25.09.2008, 14:14 |
Неприятные ошибки
порядка 14 гигов. В чем проблема - не знаю.... может проблема в файловой системе? Просто ФС слетала уже... ... |
| 25.09.2008, 14:22 |
Неприятные ошибки
Bundesrusпорядка 14 гигов. В чем проблема - не знаю.... может проблема в файловой системе? Просто ФС слетала уже... кажется мне, что не 14 ... Код: plaintext ... |
| 25.09.2008, 15:17 |
Неприятные ошибки
komrad > 50Гб а если быть точным, то 48 Гб покажите вывод : Код: plaintext 1. 2. 3. 4. ... |
| 25.09.2008, 15:19 |
Неприятные ошибки
покажите вывод Код: plaintext когда появилась ошибка? версию ASE не поднимали недавно? ... |
| 25.09.2008, 15:30 |
Неприятные ошибки
автор'compress::4::/backup/sybase/finist5.dmp::04'. stripe on используете? а часом дампитесь не на smbfs? там есть проблема 32битная проблема с 2гб . ... |
| 26.09.2008, 17:37 |
start [/forum/topic.php?desktop=1&fid=55&tid=2011270]: |
30ms |
42ms |
| others: | 233ms |
| total: | 354ms |
