Проблема при установке ASE 12.5.4 на openSUSE 11.1 (x86_64)
1) Устанавливал с этого CD: CD_ASE_12_5_4_Linux_x86-64 2) Вот инфа о Linix: # uname -a Linux osuse111b64 2.6.27.7-9-default #1 SMP 2008-12-04 18:10:04 +0100 x86_64 x86_64 x86_64 GNU/Linux # cat /etc/issue Welcome to openSUSE 11.1 - Kernel \r (\l). 3) Вот протокол инсталляции: Building Adaptive Server 'OSUSE111B64': Writing entry into directory services... Directory services entry complete. Building master device... Master device complete. Writing RUN_OSUSE111B64 file... RUN_OSUSE111B64 file complete. Starting server... Server started. Building sysprocs device and sybsystemprocs database... sybprocs device and sybsystemprocs database created. Running installmaster script to install system stored procedures... installmaster: 10% complete. installmaster: 20% complete. installmaster: 30% complete. installmaster: 40% complete. installmaster: 50% complete. installmaster: 60% complete. installmaster: 70% complete. installmaster: 80% complete. installmaster: 90% complete. installmaster: 100% complete. installmaster script complete. Creating two-phase commit database... Two phase commit database complete. Installing common character sets (Code Page 437, Code Page 850, ISO Latin-1, Macintosh and HP Roman-8)... Character sets installed. Setting server name in Adaptive Server... Server name added. Server 'OSUSE111B64' was successfully created. Building Backup Server 'OSUSE111B64_BS': Writing entry into directory services... Directory services entry complete. Writing RUN_OSUSE111B64_BS file... RUN_OSUSE111B64_BS file complete. Starting server... sh: line 1: 3975 Segmentation fault /opt/sybase/ASE-12_5/bin/backupserver -e/opt/sybase/ASE-12_5/install/OSUSE111B64_BS.log -N25 -C20 -M/opt/sybase/ASE-12_5/bin/sybmultbuf -SOSUSE111B64_BS > /dev/null 2>&1 <hung> Кто может подсказать, что надо подправить? У кого есть опыт успешной установки именно этой конфигурации? ... |
| 18.06.2009, 09:36 |
попробуй перед запуском ASE сделать export LD_POINTER_GUARD=1 или export LD_POINTER_GUARD=0 если поможет - соотв. значение переменной пропиши в профиль или скрипт старта ASE ... |
| 18.06.2009, 10:01 |
оказывается не ASE, а backup-сервер. зы, это зависит не от ядра, а от glibc версии 2.5 ... |
| 18.06.2009, 10:04 |
blzz, спасибо, но что конкретно надо сделать? ... |
| 18.06.2009, 18:57 |
gsverdlblzz, спасибо, но что конкретно надо сделать? FAQ для SUSE выставить значение переменной окружения LD_POINTER_GUARD в 1. для redhat-based, федоры наоборот нужен LD_POINTER_GUARD=0. сделать можно разными способами: 1. в ~/.bashrc или ~/.bash_profile или $SYBASE/SYBASE.sh или ~/.profile дописать строчку (в любое место) [SRC bash]export LD_POINTER_GUARD=1[/SRC] переменная будет взведена в пределах работы оболочки, из которой запускают всё остальное. 2. в скрипте запуска backup сервера Код: plaintext Код: plaintext 1. переменная будет взведена только для запуска backup-сервера. 3. если прав хвататит - можно в /etc/profile или /etc/enviroment это глобально, для всех пользователей. не знаете - лучше не лезть. ... |
| 19.06.2009, 11:43 |
blzz, спасибо ещё раз, но я спрашивал, что можно сделать с glibc, так как обе установки LD_POINTER_GUARD (0 или 1) не помогают. Есть информация (from the BackupServer engineering group), что это сочетание версий openSUSE и ACE - openSUSE 11.1 & ASE 12.5.4 ещё не сертифицировано: OpenSUSE 11 has not been certified yet (probably can not be until they pick up Open Server 15.0 ESD#16). Я кстати пробовал эту установку ACE на 64-битной версии openSUSE 10.3 и получил ту же ошибку. Было бы интересно послушать, у кого есть опыт успешной установки именно этих конфигураций ... |
| 19.06.2009, 18:54 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010999]: |
191ms |
43ms |
| others: | 240ms |
| total: | 525ms |
