ошибка при загрузке дампа
Вообщем, проблемка такая: есть база, есть дамп базы на 10гиг. пытаюсь загрузить дамп в базу - пишет следующее: May 22 16:46:25 2006: Backup Server: 6.28.1.1: Dumpfile name 'namebase ' section number 1 mounted on disk file '/u/backup/XXX.dump' May 22 16:46:39 2006: Backup Server: 4.58.1.1: Database ssirena: 109400 kilobytes LOADed. May 22 16:46:58 2006: Backup Server: 4.58.1.1: Database ssirena: 217896 kilobytes LOADed. May 22 16:47:18 2006: Backup Server: 4.58.1.1: Database ssirena: 325792 kilobytes LOADed. May 22 16:47:38 2006: Backup Server: 4.58.1.1: Database 'name': 431856 kilobytes LOADed. May 22 16:47:51 2006: D00: SYBMULTBUF ERROR: Wait for i/o completion failed: State=105, Msg=Attempted to transfer 12288 bytes, but 0 bytes were transferred by operating system call write. May 22 16:47:51 2006: D00: SYBMULTBUF ERROR: Internal error: In db_proc, the C_MBUF command is invalid when the context is DEST_RUN. May 22 16:47:51 2006: A00: SYBMULTBUF ERROR: Emulator interprocess communication failed with error state = 4, error code=32, system message=Broken pipe. May 22 16:47:51 2006: Backup Server: 4.145.2.22: [105] Error for device '/u/backup/ХХХ.dump'. Attempted to transfer 12288 bytes, but 0 bytes were transferred by operating system call write. May 22 16:47:51 2006: Backup Server: 4.141.2.66: [0] The 'write' call failed for device '/u/backup/ХХХ.dump' with error number 32 (Broken pipe). Refer to your operating system documentation for further details. May 22 16:47:51 2006: Backup Server Internal Error: 4.62.3.8: Multibuffering subprocesses died, archive /u/backup/ХХХ.dump. May 22 16:47:51 2006: Backup Server: 6.32.2.3: /u/backup/ХХХ.dump: volume not valid or not requested (server: , session id: 6.) May 22 16:47:51 2006: Backup Server: 1.14.2.4: Unrecoverable I/O or volume error. This DUMP or LOAD session must exit. при этом, если дамп базы состоит из нескольких файлов, то загрузка проходит успешно. как мне все таки загрузить дамп с одного файла?? Sybase, АSE 12.5.3, linux suse9.0. ... |
| 22.05.2006, 14:02 |
Попробуйте стартовать BackupServer c флагом -D32 и затем заново загрузить дамп. ... |
| 22.05.2006, 16:45 |
теперь не вылетает, загружает весь объем, но ошибка загрузки:.. Backup Server: 4.58.1.1: Database sirena: 9715578 kilobytes LOADed. Backup Server: 3.42.1.1: LOAD is complete (database sirena). Caution: You have set up this database to include space on disk 3 for both data and the transaction log. This can make recovery impossible if that disk fails. All dumped pages have been loaded. SQL Server is now clearing pages above page 4849664, which were not present in the database just loaded. SQL Server has finished clearing database pages. Started estimating recovery log boundaries for database 'sirena'. Completed estimating recovery log boundaries for database 'sirena'. Started ANALYSIS pass for database 'sirena'. Completed ANALYSIS pass for database 'sirena'. Started REDO pass for database 'sirena'. The total number of log records to process is 17621. The SQL Server is terminating this process. в логе сервера: SQL Text: load database sirena from '/u/backup/ХХХ.dump' with nounload curdb = 4 tempdb = 2 pstat = 0x1011000 lasterror = 0 preverror = 0 transtate = 1 curcmd = 316 program = SC_ASEJ_Mgmt pc 0x87e2019 ucbacktrace+0x89(0x0,0x1,0x930b1a4,0x100010,0x0) pc 0x81af795 terminate_process+0xc09(0x0,0xffffffff,0x930b1a4,0x413ba640,0x42121b18) pc 0x88014f0 kisignal+0xf0(0x8,0x405a2698,0x405a2718,0x8,0x0) pc 0xffffe440 init_dummy+0xf73a4720(0x412ed164,0x405a314c,0x405a314c,0x405a2f00,0x3) pc 0x8383ca3 redo_endxact+0x38b(0x405a3058,0x42121b18,0x405a3140,0x405a314c,0x405a2f00) pc 0x84214f2 rec_redo_log+0xb2a(0x3,0x40b49b40,0x40cadab0,0x415da800,0x0) pc 0x841ea96 recovery+0x822(0x3,0x0,0x40b49b40,0x930b1a4,0xc5) pc 0x864827b lddb_main+0x9fb(0x4153b5b4,0x930b1a4,0x40cad11c,0x1,0x2dc) pc 0x84dd9fc s_execute+0x38c4(0x930b1a4,0x0,0x405a49ac,0x0,0x756b6361) pc 0x84f4185 sequencer+0xf75(0x4150f800,0x930b1a4,0x0,0x405a49ac,0x81c27d6) pc 0x81de739 tdsrecv_language+0x2ed(0x0,0x0,0x0,0x0,0x0) pc 0x81ee001 conn_hdlr+0x2779(0x4,0x405a4a5c,0x895eed31,0x0,0x0) pc 0x823f387 ex_cleanup(0x0,0x0,0x0,0x40494900,0x11) pc 0x895eed31 init_dummy+0x80995011(0x0,0x40494900,0x11,0x1,0x5374616b) end of stack trace, spid 13, kpid 1048592, suid 1 кто-нибудь сталкивался с такой проблемой? может есть еще какие ключики по запуску бэкап-сервера? и где можно почитать про эти ключи? в имеющихся мануалах нет. ... |
| 23.05.2006, 07:55 |
У меня похожая проблема.... Кто-нибудь сможет подсказать, хоть в каком направлении копать? По форуму почти все на эту тему уже перерыл.... на попытку загрузки базы выдает следующее: 1> load database bill from "compress::/data/backup/bill_mvts2.dmp" 2> go Backup Server session id is: 5. Use this value when executing the 'sp_volchanged' system stored procedure after fulfilling any volume change request from the Backup Server. Backup Server: 4.132.1.1: Attempting to open byte stream device: 'compress::/data/backup/bill_mvts2.dmp::00' Backup Server: 6.28.1.1: Dumpfile name 'bill100421053C ' section number 1 mounted on byte stream 'compress::/data/backup/bill_mvts2.dmp::00' Backup Server: 4.145.2.73: [0] Error for device 'compress::/data/backup/bill_mvts2.dmp::00'. Pipe I/O returned 0 bytes Backup Server Internal Error: 4.62.3.4: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Backup Server Internal Error: 4.62.3.4: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Backup Server: 4.82.2.36: Operating system error, server device compress::/data/backup/bill_mvts2.dmp::00: code 17 message 77. Msg 8009, Level 16, State 1: Server 'MVTS2', Line 1: Error encountered by Backup Server. Please refer to Backup Server messages for details. В логах бакап сервера остается: Feb 12 17:30:34 2010: Backup Server: 4.132.1.1: Attempting to open byte stream device: 'compress::/data/backup/bill_mvts2.dmp::00' Feb 12 17:30:34 2010: Backup Server: 6.28.1.1: Dumpfile name 'bill100421053C ' section number 1 mounted on byte stream 'compress::/data/backup/bill_mvts2.d mp::00' Feb 12 17:30:34 2010: D00: SYBMULTBUF ERROR: Emulator interprocess communication failed with error state = 9, error code=0, system message=Pipe I/O returned 0 bytes. Feb 12 17:30:34 2010: Open Server Error: 16248.10.0: Error in srv_select() - file descriptor 17 is no longer active . Feb 12 17:30:34 2010: Backup Server: 4.145.2.73: [0] Error for device 'compress::/data/backup/bill_mvts2.dmp::00'. Pipe I/O returned 0 bytes Feb 12 17:30:34 2010: Backup Server Internal Error: 4.62.3.4: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Feb 12 17:30:34 2010: Backup Server Internal Error: 4.62.3.4: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Feb 12 17:30:34 2010: Backup Server: 4.82.2.36: Operating system error, server device compress::/data/backup/bill_mvts2.dmp::00: code 17 message .7'..7'... Feb 12 17:30:34 2010: Backup Server: 4.141.2.66: [0] The 'write' call failed for device 'compress::/data/backup/bill_mvts2.dmp::00' with error number 32 (Bro ken pipe). Refer to your operating system documentation for further details. Feb 12 17:30:34 2010: Backup Server Internal Error: 4.62.3.8: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Feb 12 17:30:34 2010: Backup Server: 6.32.2.3: compress::/data/backup/bill_mvts2.dmp::00: volume not valid or not requested (server: , session id: 5.) Feb 12 17:30:34 2010: Backup Server: 1.14.2.4: Unrecoverable I/O or volume error. This DUMP or LOAD session must exit. Feb 12 17:30:34 2010: Backup Server: 4.141.2.66: [0] The 'write' call failed for device 'compress::/data/backup/bill_mvts2.dmp::00' with error number 32 (Bro ken pipe). Refer to your operating system documentation for further details. Feb 12 17:30:34 2010: Backup Server Internal Error: 4.62.3.8: Multibuffering subprocesses died, archive compress::/data/backup/bill_mvts2.dmp::00. Система: 1> select @@version Adaptive Server Enterprise/12.5.2/EBF 12061 ESD#2/P/Linux Intel/Enterprise Linux/ase1252/1844/32-bit/OPT/Wed Aug 11 21:36:26 2004 Linux version 2.4.35 (Red Hat Linux 8.0 3.2-7) ... |
| 12.02.2010, 17:40 |
торможу. load database bill from "/data/backup/bill_mvts2.dmp" - в таком варианте пошел процесс. хотя в руководстве по другому написано... ... |
| 12.02.2010, 18:11 |
yastcherторможу. load database bill from "/data/backup/bill_mvts2.dmp" - в таком варианте пошел процесс. хотя в руководстве по другому написано... значит бэкап не пожатый ... |
| 12.02.2010, 19:18 |
создавался командой dump database bill to "/data/backup/bill_mvts2.dmp" with compression=7 ... |
| 12.02.2010, 21:34 |
yastcherсоздавался командой dump database bill to "/data/backup/bill_mvts2.dmp" with compression=7 Все правильно. with compression появился в доках начиная с 15-й версии, хотя был реализован уже в 12-ой. При этом есть некоторые особенности использования. Если Вы жмете дамп с помощью конструкции "compress::7::", то 1) load дампа должен быть обязательно с указанием компрессии "compress::" 2) Такой дамп невозможно "поднять" с помощью удаленного бэкап-сервера at remote_bs Если Вы жмете дамп с помощью with compression=7 1) При load не нужно указывать ни "compress::", ни with compression 2) Появляется возможность загружать дамп с удаленного сервера с помощью at remote_bs ... |
| 15.02.2010, 13:16 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010742]: |
156ms |
46ms |
| others: | 253ms |
| total: | 500ms |
