BCP запроса ASE 12.5.x
Господа подскажите пожалуйста, можно ли в ASE 12.5.x выгрузить результат запроса. Именно запроса и не вьюхи. Т.е. что-то bcp "select x from t" out и.т.д. У меня не получается и в доках ничего не могу найти. Такое подозрение что запрос выгрузить нельзя. Заранее большое спасибо ... |
| 15.01.2008, 21:07 |
низя тебе может помочь SQSH Redirection & Pipes How many times have you watched a result set disappear from your screen because you didn't hit ^S fast enough? Well, no more. Now, any command available in sqsh may be redirected to/from a file or pipelined to another process. For example, it is now legal to type: 1> SELECT * FROM sysobjects 2> go | grep test | more You may also redirect output to files and (if you are careful) can redirect input from files: 1> select * from sysobjects 2> go 2>/dev/null >/tmp/objects.txt Interserver BCP Using the \bcp command, sqsh supports the ability to transfer the result set from any command batch to another server (or even the same server) via the Sybase bcp protocol. This feature is particulary nice because current the standard Sybase bcp program does not support being able to transfer directly between server, or the ability to specify which rows from the source server are to be copied. 1> SELECT customer_id, item, SUM(qty) 2> FROM orders 3> GROUP BY customer_id, item 4> \bcp -S SYB_DSS shipping.dbo.order_summary Starting... Batch successfully bulk-copied to SQL Server Batch successfully bulk-copied to SQL Server Batch successfully bulk-copied to SQL Server ... ... |
| 15.01.2008, 21:19 |
rcryoнизя тебе может помочь SQSH Redirection & Pipes How many times have you watched a result set disappear from your screen because you didn't hit ^S fast enough? Well, no more. Now, any command available in sqsh may be redirected to/from a file or pipelined to another process. For example, it is now legal to type: 1> SELECT * FROM sysobjects 2> go | grep test | more You may also redirect output to files and (if you are careful) can redirect input from files: 1> select * from sysobjects 2> go 2>/dev/null >/tmp/objects.txt Interserver BCP Using the \bcp command, sqsh supports the ability to transfer the result set from any command batch to another server (or even the same server) via the Sybase bcp protocol. This feature is particulary nice because current the standard Sybase bcp program does not support being able to transfer directly between server, or the ability to specify which rows from the source server are to be copied. 1> SELECT customer_id, item, SUM(qty) 2> FROM orders 3> GROUP BY customer_id, item 4> \bcp -S SYB_DSS shipping.dbo.order_summary Starting... Batch successfully bulk-copied to SQL Server Batch successfully bulk-copied to SQL Server Batch successfully bulk-copied to SQL Server ... Большое спасибо за ответ. Я не ожидал, что в ASE BCP нельзя запрос выгрузить. В MSSQL ещё в 7й версии можно было. Отдельное спасибо за альтернативное решение. ... |
| 15.01.2008, 21:35 |
Почему нельзя ... мона!!! Create view V_MY_SELECT as select ..... from ...where ... bcp mydatabase..V_MY_SELECT out V_MY_SELECT.txt -S%SERVER% -U%UID% -P%PWD% -c ... |
| 16.01.2008, 12:29 |
_Drive_, внимательней: Kruможно ли в ASE 12.5.x выгрузить результат запроса. Именно запроса и не вьюхи . ... |
| 16.01.2008, 15:02 |
Kru wrote: > Господа подскажите пожалуйста, > можно ли в ASE 12.5.x выгрузить результат запроса. > Именно запроса и не вьюхи. Нет. Именно создаешь из запроса VIEW и из него фетчишь. Или - SQSH, как уже сказали. Posted via ActualForum NNTP Server 1.4 ... |
| 16.01.2008, 22:05 |
А еще можно поставить клиентскую часть от 15-ой и воспользоваться всей мощью dbisql. Он на уровне запросов как раз и делает выгрузку. Да еще и не только в tsv формат а и еще в полдюжины разных включая dbf и xls. ... |
| 17.01.2008, 00:21 |
Выгрузку результатов запроса \ скрипта в текстовый файл можно сделать стандартной утилитой ISQL: Код: plaintext ... |
| 17.01.2008, 07:09 |
golsaВыгрузку результатов запроса \ скрипта в текстовый файл можно сделать стандартной утилитой ISQL: Код: plaintext В этот раз я Артизаном всё выгрузил. Но хотелось бы знать как средствами Sybase обходиться. Артизана и SQSH может и не быть. Вариант с isql больше всего подходит. Всем большое Спасибо ... |
| 18.01.2008, 00:17 |
Kru, Добрый день, господа. Выполнил командную строку: isql -b -S DBSERVER -U sa -P mypw -i d:\s.sql -o d:\l.txt В результате получил файл d:\l.txt - пустой!! Может быть где-то промах? ... |
| 28.01.2011, 16:45 |
Забыл, содержимое файла d:\s.sql - select * from my_table ... |
| 28.01.2011, 16:47 |
golol_olЗабыл, содержимое файла d:\s.sql - select * from my_table наверное забыл терминатор. добавь go в конце. Код: plaintext 1. ... |
| 28.01.2011, 16:58 |
Большое спасибо!!! Действительно, как же без go? ... |
| 28.01.2011, 17:06 |
И ещё... Операционная система: Windows 2000 sp4. База данных: Sybase 12.5. ОДБС.Drivers: Sybase ASE ODBC Driver 3.70.00.20 Sybase,Inc. SYODASE.DLL 19.10.2005 Выполняется командная строка: isql -b -S DBSERVER -U sa -P mypw -i d:\ol\s.sql -o d:\ol\l.txt Результат запроса в файл d:\ol\l.txt 1437799 1153724 980 240010001 0.00 20010306 0 20110131 2941759 1153724 840 240010001 0.00 20020701 0 20110131 (2 rows affected) (return status = 0) На самом деле в результате должно быть две записи, но при выводе информации после суммы 0.00 следуют три символа 0D 0A 09 0D 0A - это конец строки 09 - это табуляция Как избавиться от этого? Хотелось бы видеть результат, таким: 1437799 1153724 980 240010001 0.00 20010306 0 20110131 2941759 1153724 840 240010001 0.00 20020701 0 20110131 (2 rows affected) (return status = 0) ... |
| 02.02.2011, 18:36 |
golol_olИ ещё... Операционная система: Windows 2000 sp4. База данных: Sybase 12.5. ОДБС.Drivers: Sybase ASE ODBC Driver 3.70.00.20 Sybase,Inc. SYODASE.DLL 19.10.2005 Выполняется командная строка: isql -b -S DBSERVER -U sa -P mypw -i d:\ol\s.sql -o d:\ol\l.txt Результат запроса в файл d:\ol\l.txt 1437799 1153724 980 240010001 0.00 20010306 0 20110131 2941759 1153724 840 240010001 0.00 20020701 0 20110131 (2 rows affected) (return status = 0) На самом деле в результате должно быть две записи, но при выводе информации после суммы 0.00 следуют три символа 0D 0A 09 0D 0A - это конец строки 09 - это табуляция Как избавиться от этого? Хотелось бы видеть результат, таким: 1437799 1153724 980 240010001 0.00 20010306 0 20110131 2941759 1153724 840 240010001 0.00 20020701 0 20110131 (2 rows affected) (return status = 0) ключ isql -w, например isql -b -S DBSERVER -U sa -P mypw -w 8000 -i d:\ol\s.sql -o d:\ol\l.txt а чтобы избавиться от (2 rows affected) - set nocount on (return status = 0) - можно отрегулировать кажется с помощью -m ... |
| 02.02.2011, 21:20 |
golol_olИ ещё... ОДБС.Drivers: Sybase ASE ODBC Driver 3.70.00.20 Sybase,Inc. SYODASE.DLL 19.10.2005 И ещё, ОДБС к isql никакого отношения не имеет. ... |
| 03.02.2011, 09:36 |
сур0k (return status = 0) - можно отрегулировать кажется с помощью -m Господа, всем большое спасибо. Получилось всё. Только не могу убрать (return status = 0). Но это уже и не так важно. ... |
| 03.02.2011, 13:07 |
golol_olТолько не могу убрать (return status = 0). варианты : Код: plaintext 1. Код: plaintext 1. ... |
| 03.02.2011, 14:07 |
On 03.02.2011 13:07, golol_ol wrote: > Господа, всем большое спасибо. > Получилось всё. > Только не могу убрать (return status = 0). Используй SQSh вместо ISQL. Там всё можно отключить. Posted via ActualForum NNTP Server 1.4 ... |
| 03.02.2011, 14:11 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010415]: |
437ms |
72ms |
| others: | 226ms |
| total: | 777ms |
