ASE 15.5 create database very long time
Всем доброго дня Почему то ОЧЕНЬ долго стала создаваться БД ... CPU - Xeon 2шт. 2000GHz RAM - 4Gb ОС:Windows 2008 R2 x64 Adaptive Server Enterprise/15.5/EBF 18158 SMP ESD#2/P/X64/Windows Server/asear155/2514/64-bit/OPT DeveloperEdition PageSize = 2K (так надо чтобы поднять дамп) disk init name = 'datadev1', physname = 'D:\Sybase\data\datadev1.dat', size = '65536M', directio = true, skip_alloc = true disk init name = 'datadev2',physname = 'E:\Sybase\data\datadev2.dat',size = '32768M', dsync = false, skip_alloc = true CREATE DATABASE pharmwork ON datadev1 = '65536M' -- 8388608 pages LOG ON datadev2 = '32768M' -- 4194304 pages где-то 30 мин. проц. был нагружен на 13% и вот уже час "тишина" .... проц. не жужжит, а процесс create database runnable Параметры конфигурации сервера ... то что DEFAULT поскипано [Named Cache:default data cache] cache size = 300M cache status = default data cache [Named Cache:tempdb_cache] cache size = 180m cache status = mixed cache [Meta-Data Caches] number of open databases = 20 number of open objects = 550 number of open indexes = 550 number of open partitions = 550 [Disk I/O] number of large i/o buffers = 12 [Network Communication] default network packet size = 4096 max network packet size = 4096 [Query Tuning] number of worker processes = 6 max parallel degree = 4 max scan parallel degree = 2 [Physical Memory] max memory = 1800000 additional network memory = 92160 allocate max shared memory = 1 heap memory per user = 6144 [Processors] statement cache size = 23040 [SQL Server Administration] procedure cache size = 92160 identity burning set factor = 1 event buffers per engine = 5000 number of aux scan descriptors = 10000 SQL Perfmon Integration = 0 [User Environment] stack guard size = 20480 [Lock Manager] number of locks = 40000 deadlock checking period = 800 [Component Integration Services] cis packet size = 4096 cis cursor rows = 200 cis bulk insert array size = 200 cis rpc handling = 1 [Java Services] size of process object heap = 4000 size of shared class heap = 8000 ... |
| 03.02.2011, 14:37 |
Вау ... закончило .... 2 часа!! ... |
| 03.02.2011, 15:11 |
_Drive_, в create database добавить опцию for load будет очень быстро ... |
| 03.02.2011, 15:30 |
_Drive_, эта опция только под поднятие дампа ... |
| 03.02.2011, 15:31 |
On 03.02.2011 15:31, komrad wrote: > эта опция только под поднятие дампа Да. А иначе сервер все страницы БД физически затирает грубо говоря нулями. Это естественно долго. Posted via ActualForum NNTP Server 1.4 ... |
| 04.02.2011, 09:20 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010413]: |
52ms |
26ms |
| others: | 256ms |
| total: | 364ms |
