Разделение сегмента данных и лога по разным девайсам Sybase ASE 15.0.2
День добрый. В результате махинаций с перемещением девайсов по сегментам в базе sp_helplog выдает "No valid log device can be found to contain the starting logpage of '33328484', on database 'data'. Perhaps the segment mapping of database has changed recently. Please inspect the sysusages catalog and contact your system administrator." Кто-нить сталкивался?. Нужен совет гуру ... |
| 22.03.2012, 17:27 |
scroodj, в базе выполнить Код: sql 1. 2. ... |
| 22.03.2012, 20:40 |
komrad, sp_helplog data No valid log device can be found to contain the starting logpage of '33328484', on database 'data'. Perhaps the segment mapping of database has changed recently. Please inspect the sysusages catalog and contact your system administrator. sp_helpsegment logsegment segment name status ------- ---------- ------ 2 logsegment 0 device size ------- -------- logdev2 1024.0MB free_pages ----------- 35924 Objects on segment 'logsegment': table_name index_name indid partition_name ---------- ---------- ----- -------------- Objects currently bound to segment 'logsegment': table_name index_name indid ---------- ---------- ----- syslogs syslogs 0 total_size total_pages free_pages used_pages reserved_pages ----------------- --------------- --------------- --------------- --------------- 1024.0MB 262144 35924 1024 0 Execution time: 0,205 seconds sysusages dbid segmap lstart size vstart pad unreservedpgs crdate vdevno ------ ----------- ----------- ----------- ----------- ------ ------------- ------------------------- ----------- 4 11 0 9175040 0 (NULL) 810190 2012-03-21 23:53:35.463 3 4 11 9175040 2621440 18350080 (NULL) 925147 2012-03-21 23:53:35.463 3 4 11 11796480 1423360 23592960 (NULL) 1046486 2012-03-21 23:53:35.463 3 4 11 13219840 786432 26439680 (NULL) 619795 2012-03-21 23:53:35.463 3 4 11 14006272 524288 28012544 (NULL) 38677 2012-03-21 23:53:35.463 3 4 11 14530560 524288 29061120 (NULL) 442426 2012-03-21 23:53:35.463 3 4 11 15054848 7077888 30109696 (NULL) 2323823 2012-03-21 23:53:35.463 3 4 11 22132736 2621440 44265472 (NULL) 2104312 2012-03-21 23:53:35.463 3 4 11 24754176 4081664 49508352 (NULL) 1289936 2012-03-21 23:53:35.463 3 4 11 28835840 348160 57671680 (NULL) 90560 2012-03-21 23:53:35.463 3 4 16 29184000 813056 0 (NULL) 364 2012-03-21 23:53:35.463 4 4 16 29997056 524288 1626112 (NULL) 0 2012-03-21 23:53:35.463 4 4 16 30521344 2621440 2674688 (NULL) 27912 2012-03-21 23:53:35.463 4 4 16 33142784 262144 7917568 (NULL) 0 2012-03-21 23:53:35.463 4 4 16 33404928 2621440 8441856 (NULL) 756 2012-03-21 23:53:35.463 4 4 16 36026368 2629632 13684736 (NULL) 1297665 2012-03-21 23:53:35.463 4 4 0 38656000 3274752 0 (NULL) 2251030 2012-03-21 23:53:35.463 5 4 0 41930752 821248 6549504 (NULL) 818040 2012-03-21 23:53:35.463 5 4 4 42752000 262144 0 (NULL) 261120 2012-03-22 00:29:25.933 6 (19 rows)Execution time: 0,02 seconds ... |
| 23.03.2012, 10:15 |
scroodjsysusages dbid segmap lstart size vstart pad unreservedpgs crdate vdevno ------ ----------- ----------- ----------- ----------- ------ ------------- ------------------------- ----------- 4 0 38656000 3274752 0 (NULL) 2251030 2012-03-21 23:53:35.463 5 4 0 41930752 821248 6549504 (NULL) 818040 2012-03-21 23:53:35.463 5 (19 rows)Execution time: 0,02 seconds похоже что проблема может быть здесь с этих девайсов убраны все сегменты? не зря я просил прислать Код: sql 1. 2. 3. 4. там показано распределение сегментов по девайсам ... |
| 23.03.2012, 12:01 |
похоже что проблема может быть здесь с этих девайсов убраны все сегменты? не зря я просил прислать Код: sql 1. 2. 3. 4. там показано распределение сегментов по девайсам[/quot] на 5ом девайсе сегментов нет sp_helpdb data name db_size owner dbid created status ---- ------------- ----- ---- ------------ --------------------------------------------------------------------------------------------------- data 168024.0 MB sa 4 Мар 21, 2012 trunc log on chkpt, ddl in tran, allow nulls by default, abort tran on log full, mixed log and data device_fragments size usage created free kbytes ------------------------------ ------------- -------------------- ------------------------- ---------------- datadev 35840.0 MB data only Мар 21 2012 11:53PM 3228708 datadev 10240.0 MB data only Мар 21 2012 11:53PM 3700588 datadev 5560.0 MB data only Мар 21 2012 11:53PM 4185944 datadev 3072.0 MB data only Мар 21 2012 11:53PM 2479180 datadev 2048.0 MB data only Мар 21 2012 11:53PM 154708 datadev 2048.0 MB data only Мар 21 2012 11:53PM 1769704 datadev 27648.0 MB data only Мар 21 2012 11:53PM 9295292 datadev 10240.0 MB data only Мар 21 2012 11:53PM 8417248 datadev 15944.0 MB data only Мар 21 2012 11:53PM 5159744 datadev 1360.0 MB data only Мар 21 2012 11:53PM 362240 indexdev 3176.0 MB data only Мар 21 2012 11:53PM 1456 indexdev 2048.0 MB data only Мар 21 2012 11:53PM 0 indexdev 10240.0 MB data only Мар 21 2012 11:53PM 109352 indexdev 1024.0 MB data only Мар 21 2012 11:53PM 0 indexdev 10240.0 MB data only Мар 21 2012 11:53PM 3024 indexdev 10272.0 MB data only Мар 21 2012 11:53PM 5190660 logdev 12792.0 MB data only Мар 21 2012 11:53PM 9004120 logdev 3208.0 MB data only Мар 21 2012 11:53PM 3272160 logdev2 1024.0 MB log only Мар 22 2012 12:29AM not applicable -------------------------------------------------------------- log only free kbytes = 143696 device segment -------- ----------------------------- datadev data_seg datadev default datadev system indexdev index_seg logdev -- unused by any segments -- logdev2 logsegment Execution time: 0,483 seconds Базу я поднимал из дампа, предварительно создав девайся под данные, индексы и лог. исходя из размеров оригинальной базы. с которой делалася бэкап. Когда дамп поднялся..девайся и сегменты были перемешаны(лог попал на девайс под индексы) и я попытался вынести лог из под индекс_девайся ... |
| 23.03.2012, 16:12 |
scroodjБазу я поднимал из дампа, предварительно создав девайся под данные, индексы и лог. исходя из размеров оригинальной базы. с которой делалася бэкап. Когда дамп поднялся..девайся и сегменты были перемешаны(лог попал на девайс под индексы) и я попытался вынести лог из под индекс_девайся при создании БД надо исходить не только из размера, но и из расположения сегментов по девайсам попробуй растянуть logsegment на девайс logdev Код: sql 1. 2. ... |
| 23.03.2012, 18:08 |
komradscroodjБазу я поднимал из дампа, предварительно создав девайся под данные, индексы и лог. исходя из размеров оригинальной базы. с которой делалася бэкап. Когда дамп поднялся..девайся и сегменты были перемешаны(лог попал на девайс под индексы) и я попытался вынести лог из под индекс_девайся при создании БД надо исходить не только из размера, но и из расположения сегментов по девайсам попробуй растянуть logsegment на девайс logdev Код: sql 1. 2. ситуация не изменилась ... |
| 26.03.2012, 10:37 |
scroodj Код: sql 1. 2. 3. 4. там показано распределение сегментов по девайсам device_fragments size usage created free kbytes ------------------------------ ------------- -------------------- ------------------------- ---------------- logdev 12792.0 MB data only Мар 21 2012 11:53PM 9004120 logdev 3208.0 MB data only Мар 21 2012 11:53PM 3272160 device segment -------- ----------------------------- logdev -- unused by any segments -- [/quot] либо sp_helpdb брешет что на 12гиговом куске свободно 9 гиг и в master..sysusages запись неправильная, либо не syssegments брешет что не используется. Я думаю что брешет sysusages, такое часто бывает. Для переноса туда лога предлагаю воспользоваться процдурой sp_logdevice http://infocenter.sybase.com/help/index.jsp?topic=/com.sybase.help.ase_15.0.sprocs/html/sprocs/sprocs158.htm ... |
| 27.03.2012, 22:49 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010161]: |
46ms |
55ms |
| others: | 218ms |
| total: | 368ms |
